General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 04-06-2009 11:17 PM by onequiknova. 20 replies.
Rate:
Sort Posts:
Page 1 of 2 (21 items) 1 2 Next >
04-05-2009 1:42 PM
Offline rmbarry
Not Ranked
Joined on 08-09-2004
Tewksbury, MA
Posts 49
Compressor for an Air Brush
I am getting reading to start using my air bursh, but I do not know if I can use my Porter Cable pancake air compressor that powers my nail guns, or should I puchase an air compressor made specfically for air brushes?  What have others used or recommend?
Thank You,
Ray Barry
04-05-2009 1:52 PM In reply to
Offline Don Z
Top 500 Contributor
Joined on 08-24-2005
Austin, TX
Posts 1,816
Re: Compressor for an Air Brush
Ray,
I regularly use my 6HP 60 gallon vertical compressor to spray with my airbrush. I drop the pressure to about 23psi with the regulator and it works fine. It helps to have a moisture filter on your compressor.
Don Z.
04-05-2009 2:23 PM In reply to
Offline Blind Bruce
Top 500 Contributor
Joined on 01-27-2005
Winnipeg Canada
Posts 1,039
I have the same compressor as you. It works just fine with my two airbrushes. As said above, a moisture trap and regulator is a must for the best results.
04-05-2009 8:16 PM In reply to
Offline onequiknova
Not Ranked
Joined on 07-17-2003
Illinois
Posts 216
I bought a small 2 gallon air compressor from Menards for about 50$ on sale.  It's about the same size as the compressors they sell specificly for air brushing, but for a fraction of the price. I also added a combination regulator and moisture trap.
 John
04-06-2009 8:21 AM In reply to
Offline Medina1128
Top 500 Contributor
Joined on 04-12-2003
Clinton, MO, US
Posts 1,681
I bought my compressor from the same place I got my airbrush. They have a lifetime warranty on their products, too.
Airbrush City
04-06-2009 8:56 AM In reply to
Offline cwclark
Top 100 Contributor
Joined on 01-30-2004
Crosby, Texas
Posts 3,529
  Your pancake compressor will work fine. You might want to consider installing a pressure regulator with a built-in moisture trap and an in-line paper filter between the compressor and the airbrush.  This will ensure no dirt, oil, or water will get to the airbrush components and the paint.
       I use a small 2 gallon compressor that I purchased  at Walmart for around $60.00 and it works well with my badger single action and my paasche double action airbrushes....chuck
04-06-2009 9:07 AM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,323
 Any compressor, large or small, with a regulator will work. I use a Campbell Hausfeld compressor rated for a max of 128 psi to supply my airbrush. I have the regulator locked down to 28 psi. A moisture trap is also desirable as this will catch any water coming from the air tank and keep it out of your paint.
04-06-2009 9:10 AM In reply to
Offline shayfan84325
Top 500 Contributor
Joined on 11-06-2007
Utah
Posts 826
I agree with all of the previous advice, but I suggest getting a regulator that is designed for use with an airbrush.  I usually paint at around 8 psi and clean it at about 15.  I find that the higher pressure makes it harder to control the paint and air volume, and that all that air tends to blow parts around.  You also get a lot more overspray with higher pressure.
The big regulatopr that you have on that pancake compessor may not reliably adjust to such low pressure.
If you are using acrylic paints, your pressure values may be different than mine.  I use Floquil paints with organic solvents.  I've never used the model maker's acrylic paints, so I don't know how they are different from the more toxic stuff.
04-06-2009 9:14 AM In reply to
Offline rmbarry
Not Ranked
Tewksbury, MA
Posts 49
 Where would I find a a pressure regulator with a built-in moisture trap and an in-line paper filter?  Is this a speciality item, or should my local Home Depot or hobby store carry this item?
Ray
04-06-2009 9:47 AM In reply to
Top 500 Contributor
Utah
Posts 826
rmbarry:
I did a quick search and found this one:
http://www.artsuppliesonline.com/catalog.cfm?cata_id=2860
I think you can get them for less if you shop around.
Edit:  I found this one for under $20.  I think it's the same as mine.
http://www.tcpglobal.com/airbrushdepot/itemdetail.aspx?itemno=ABD+TFR-2000
04-06-2009 9:54 AM In reply to
Offline reklein
Top 500 Contributor
Joined on 07-22-2004
Lewiston ID
Posts 1,668
HD has the regulators and traps. Look in the tool dept. where the compressor acc. are located. I used to work there. BILL
04-06-2009 9:55 AM In reply to
Offline cwclark
Top 100 Contributor
Crosby, Texas
Posts 3,529
This is a badger airbrush regulator with a moinsture trap that is around $45.00 -$50-00. Do a search and you may find one on sale somewhere.
The inline paper filter can be purchased at anywhere that sells air compressors....chuck
04-06-2009 10:44 AM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 10,017
Harbor Freight has a bunch of filters/regulators too.
http://search.harborfreight.com/cpisearch/web/search.do?keyword=air+filters
04-06-2009 11:20 AM In reply to
Offline MECman
Not Ranked
Joined on 07-21-2006
Posts 23
Without meaning to hijack the thread, I have a related question. I have a small Pasche airbrush compressor that doesn't have a tank attached. Rather than paint with the compressor running constantly, I have thought about buying one of the stand alone tanks sold at HD and other places. That way, I could fill it up out in the garage and bring the tank into the basement for painting at the spray booth. Than I won't annoy my wife with constant noise. Does this idea have merit? David
04-06-2009 11:40 AM In reply to
Offline Blind Bruce
Top 500 Contributor
Winnipeg Canada
Posts 1,039
David, using the small  Pasche would work but it would take a whole bunch of time to do it. Unless you have a larger compressor in the garage, I wouldn't recommend it.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
