General Discussion (Classic Trains)
Like Classic Trains magazine itself, this forum celebrates the "golden years of railroading." Covering the railroad scene from the late 1920s to the late 1970s, this forum section is everything from giant steam locomotives and colorful streamliners, to the dieselization-era. Share your recollections here! If you're new here, please read our forum policies.
Last post 03-15-2010 3:38 AM by daveklepper. 1051 replies.
Rate:
Sort Posts:
Page 2 of 71 (1052 items) < Previous 1 2 3 4 5 Next > ... Last »
04-13-2009 8:55 AM In reply to
Offline daveklepper
Top 75 Contributor
Joined on 06-18-2002
Posts 4,107
Re: Classic Train Questions Part Deux (50 Years or Older)
1.   What was the longest interuruban line between two major cities in the USA, with or without through service, but under one management?.
2.   What was the longest interurban run, not necessarily the above, in the USA.?
3.   Which interuruban lines ran sleeping cars and between which points?
One hint:   Al the interubans involved in the answers also provided freight srvice.
04-14-2009 7:01 AM In reply to
Offline passengerfan
Top 150 Contributor
Joined on 03-23-2004
Central Valley California
Posts 2,790
One of the answers to part 3 would it be Illinois Terminal between Peoria and St. Louis.
Al - in - Stockton
04-14-2009 7:06 PM In reply to
Offline al-in-chgo
Top 150 Contributor
Joined on 10-23-2006
Chicago, Ill.
Posts 2,717
  -  "2.   What was the longest interurban run, not necessarily the above, in the USA.?"
Longer than Chicago to South Bend, or Chicago to Milwaukee?  -  a.s.
04-16-2009 4:10 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
The Illinois Terminal answer is correct, but is only one of three.   You are allowed to do research to find the other two.
Yes, longer than the North Shore and longer than the CSS&SB.
04-16-2009 8:18 AM In reply to
Offline henry6
Top 150 Contributor
Joined on 12-21-2001
Posts 2,329
Wasn't the Empire State Railways line across NY longer...from Rochester to Utica at least.
And then Ohio and Indiana had some very long runs, too.
Gave a map to the Warehous Pt. Trolley Museum back in the 60's that showed all lines in the 20's and you could figure out how to travel by interuban virtually from Portland ME to Chicago with a few gaps but many changes and little sleeping.
04-16-2009 11:27 PM In reply to
Offline wanswheel
Top 500 Contributor
Joined on 11-12-2005
Posts 913
Sam Insull controlled interurban lines from Milwaukee to Louisville but there doesn't seem to have been any direct continuity of tracks between the two cities. Cincinnati and Toledo at far ends of Ohio were connected by the Cincinnati & Lake Erie Railroad. I don't know of two major cities further apart on one interurban line. The longest passenger interurban run was Cincinnati to Detroit, C&LE and the Eastern Michigan-Toledo Railway.  An even longer interurban freight run was Cleveland through Toledo to Cincinnati, Lake Shore Electric and C&LE.
http://www.indianahistory.com/ihs_press/web_publications/railroad/keenan.html
http://www.davesrailpix.com/cle/htm/cle44.htm
Interstate had a sleeper Indianapolis to Louisville.
Oregon Electric had a sleeper Portland to Eugene.
Mike
04-17-2009 7:43 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
Mike, you are sufficiently close to getting all the answers that I have to declair you winner.   You have now listed all the sleepers, Peoria - St. Louis on the Illinois Terminal, Portland to Eugene on the Oregon Electric, and earlier posted Indianapolis to Louisville on the Indiana Railroad, formerly Interstate Corporation.
The longest through run of any interurban schedule was the Cincinnati and Lake Erie's through Detroit - Cincinnati service, but it didn't last and involved a different company moving its car between Toledo and Detroit.   So the longest single through run of one company was San Francisco to Chico California on the Sacremento Northern,   This began only after the Bay Bridge was opened and lasted only a few years until SN cut back interurban operations to Pittsburgh, CA, and then went freight-only.  Its Chico local service lasted until after WWII (the only Birney cars ever run with 3rd rail shoes; to get them to and from the Sacramento shops), and its Sacramento local service ran into WWII but was then merged into Pacific Gas and Elecctric's operation until busses were substituted.  Chico had the last nickle fare in the USA.   Between Sacramento and Pittsburgh, SN trains, both freight and passenger, use a railroad car car ferry, with energized trolley wire on the ferryboat.  Use of this boat, the Ramon, lasted through diesezation in the Post WWII. era.   But in very rough weather, passengers had to use the ferry without movement of the railcars onto the ferry, just a train meeting the boat at the other side.
The longest point-to-pont travel on a single interurban system was from Fort Wayne to Louisville on the Indiana Railroad, but a change of cars in Indianapolis was always necessary.   And the Insull empire was all connected but required some travel over non-Insull lines, specifically, the Northern Indiana east of South bend connecting to the independent Winona.
It is Mike's turn to ask.
04-19-2009 12:39 AM In reply to
Offline wanswheel
Top 500 Contributor
Posts 913
What bridge named for a 20th century Congressman and Senator from Illinois is probably the most expensive thing ever built by an interurban railroad?
04-19-2009 5:42 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
The Illinois Terminal's entrance into St. Louis, which is still in use as a road vehicular bridge, and I think was named for Senator McKinley, and was built by the interurban line, not by the highway department.
04-20-2009 4:06 AM In reply to
04-20-2009 10:12 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
The Pennsy in general designed its own equpment and built a lot of it in its own shops.  Name as many OTHER railroads, other than PRR subsidiaries, including PRSL, that used distinctive PRR-designed equipment as their own:  Locomotives, freight cars, passenger cars.  This can include terminal railroads and switching operations and second-hand applications.   Even rapid transit and interurban lines if you can think of any.
 Like the Chicago and Eastern Illinois used Erie Stillwell-design commuter coaches.
04-22-2009 8:10 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
Have I stumped everybody? If so, will the regulars please say so?  I will then give the answers that I know and ask another question.
04-22-2009 8:43 AM In reply to
Offline henry6
Top 150 Contributor
Posts 2,329
Looks and sounds like a very complicated question...one in which one's own geography would be helpful and harmful.  H&M (the Tubes) also had Stillwell designed cars, for instance; the LIRR was 99% Pennsy; LV had great PRR influence because of it stock ownershp as did N&W as seen in its position light signals.   How many modeled themselves after the PRR if only because they interchanged soley with them?  The question leads to a lot of wandering.
04-22-2009 10:41 AM In reply to
Offline al-in-chgo
Top 150 Contributor
Chicago, Ill.
Posts 2,717
daveklepper:
I can speak only for myself, but I am plumb out of guesses.  -  a.s.
04-23-2009 5:27 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,107
Here is what I know:    The B&O bought some round-top ("wagon-top") steel 40-ft boxcars that always seemed identacle to me to the PRR's, and these were the only two railroads that had them.   The B-6 0-6-0 switcher was the standard for Washington Union Station, not lettered PRR but Washington Union Sttation.  The H&M had Stilwell designed cars but not identacle to the Erie's by any imagination, but although financially completely independent from the Pennsy, did buy identacle cars to the 50 that the Pennsy bought for the Newark  -  Hudson Terminal (World Trade Center) joint service.  These were a Gibbs design, not Stillwell.  And the Gibbs-designed cars built by the PRR for the Long Island Railroad were duplicated as the first steel cars for IRT subway which opened with copper-clad composite cars that were later transferred to the 2nd and 3rd Avenu elevated lines.   The IRT cut center doors into them later, which the LIRR never did.
I'll keep this open for a while in case anyone can add even one more and thus be the winner.   I believe one railroad did copy the N-5 caboose.    Somebody know which one?
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
