General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 03-31-2009 1:38 PM by jeffrey-wimberly. 17 replies.
Rate:
Sort Posts:
Page 1 of 2 (18 items) 1 2 Next >
03-29-2009 10:23 PM
Offline pitshop
Not Ranked
Joined on 12-23-2008
Summerville, SC
Posts 71
Are the track cleaning cars all they're cracked up to be??
I've discovered over the weekend that my track needs to be cleaned, only after about an hour of running trains this past week and after cleaning about 5 feet of track with a pencil eraser, I'm wondering about purchasing a track cleaning car, but wondered if they beat good ole' elbow grease and patience (which I have little of when I can't run the train!)
Does anybody have any opinions on if they are worth purchasing and if so, which one is a preferred model? I'm modeling HO scale.
Skip
03-29-2009 11:06 PM In reply to
Offline BRAKIE
Top 25 Contributor
Joined on 10-23-2001
OH
Posts 7,038
Re: Are the track cleaning cars all they're cracked up to be??
Try 91% rubbing alcohol and a clean rag-preferably white and cut into squares.I use old T-shirts.
I also wrap the bottle cap in the rag-this save you from running your fingers over the rail with the rag.Place 2 fingers on the bottle cap as you clean..
03-30-2009 12:08 AM In reply to
Offline last mountain & eastern hogger
Not Ranked
Joined on 08-11-2006
Saskatchewan
Posts 563
The LM&E runs a MOW track cleaning train.
It is made up of two Centerline cars, one running wet and one running dry followed by a masonite pad car and then a hopper dragging a weighted piece of leather (rough side down) underneath.  That leather kit came from a fellow in Texas, I believe.  But can't remember his name right now.  But if you mount it correctly the car will even go backwards through turnouts without any problems.
The wet car runs with either 70% alcohol or Goo-Gone, I really can't see much difference between the two fluids for the cleaning.
I am very satisfied with the Centerline cars.     I much prefer to run trains than to hand scrub track.
Johnboy out............
03-30-2009 7:09 AM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,132
I've got a CMX "clean machine" car.  It's one of the high-priced track cleaners, but it does a great job.  I tried it with alcohol, which worked OK, but the recommended lacquer thinner works even better.
I have subways, and most of the track is "underground."  So, it's hard to clean by hand, even with liftoffs making most of the track pretty accessible.  I had always planned to use a cleaner car, and when I ran the CMX for the first time I was really happy that my trains started working again down there.
I need to run mine about once every 4 months.
03-30-2009 7:22 AM In reply to
Offline pastorbob
Not Ranked
Joined on 12-03-2002
Posts 696
I have an older Centerline car on the workbench, bumped by a work train with two CMX track cleaners, one running liquid, then a gondola, then the second CMX running a dry pad.  Works great on my 3 deck Santa Fe with a lot of hidden track.
Bob
03-30-2009 7:53 AM In reply to
Offline wedudler
Top 500 Contributor
Joined on 09-16-2004
Germany
Posts 1,090
 I use a CMX tank car for wet run, a scratch build caboose (like Centerline ) with every other train. And I use a rubber. Best way : running trains!
 Wolfgang
03-30-2009 10:40 AM In reply to
Offline TA462
Top 75 Contributor
Joined on 06-07-2004
PORT HOPE, ONTARIO
Posts 3,587
Are the track cleaning cars all they are cracked up to be?  If your talking about the CMX Clean Machine then yes they are.  I don't believe you will find a better car and although they are expensive they are worth every penny.   I clean my track about once every 5-6 months and make a work train out of it.  I use alcohol in mine, I tried GOO GONE once but it left a film on the rails that I didn't like.
03-30-2009 11:04 AM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 5,684
wedudler:
And I use a rubber.
Well, I guess you can't be too careful nowadays....
03-30-2009 1:49 PM In reply to
Offline PaulWhitt20
Not Ranked
Joined on 08-13-2004
Posts 68
Hi,
Sounds like these CMX cars are good. Is there any reason why I should not use one on Unitrack? What is the best stuff to put in them?
Thanks
Paul
03-30-2009 2:00 PM In reply to
Offline cudaken
Top 150 Contributor
Joined on 06-20-2006
St Louis
Posts 2,360
Skip, I use Trailing track cleaning cars, I have 3 at $13.95 each and work well. I usually run a track cleaning train with one car being pushed and 2 being dragged. I bought them about two years ago and have not touched my bright boy after that.
            Cuda Ken
03-30-2009 2:34 PM In reply to
Offline donhalshanks
Not Ranked
Joined on 01-18-2001
US
Posts 360
Use the "gleam" method described in detail many times in prior threads of the forum..... and you hardly ever have to clean track.
Hal
03-30-2009 2:35 PM In reply to
Offline howmus
Top 100 Contributor
Joined on 12-30-2004
Finger Lakes
Posts 3,130
I would also recommend the CMX machine.  Does an excellent job of cleaning.
PaulWhitt20:
I have used both alcohol and the Lacquer Thinner.  While the lacquer thinner does an excellent job of cleaning the track, it also does a great job of melting anything plastic that is in the ROW.  I am using the Atlas turnouts and flex track and have had no trouble with the ties, but there are plastic guard rails in their turnouts that don't take to it well.........  I highly recommend 91% alcohol.  It does a good job.  I only run the car once every couple months and seldom have any problems with the track.
03-30-2009 5:59 PM In reply to
Offline pastorbob
Not Ranked
Posts 696
donhalshanks:
Hal
I don't think I want to "gleam" my track, three decks, a lot of hidden track.  I will stick with my two CMX cars.
Bob
03-30-2009 8:15 PM In reply to
Offline hcc25rl
Not Ranked
Joined on 08-14-2006
Burnsville, MN
Posts 120
Sir - Track cleaning cars are a TOOL that can be used in conjunction with "elbow grease", Good trackwork, careful attention to as clean a layout room as possible and proper routine maintenance of your locos and rolling stock.
Jimmy
03-30-2009 11:00 PM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 9,982
I still use elbow grease to clean all my track, but the use of a $15 Walthers and a couple home made masonite track cleaning cars has really cut down on the manual cleaning.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
