Trains.com
Where can I find extra railroad ties for Lionel 0-27 tubular track?
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Tuesday, March 24, 2009 9:44 AM
Where can I find those extra railroad ties for my kind of track? I know they make them for regular O-guage. I am going to need HUNDREDS of these little guys.
Give me steam locomotives or give me DEATH!
Berkshire Junction, bringing fourth the cry of the Iron Horse since 1900.
  • Member since
    May 2004
  • 2,115 posts
Posted by 3railguy on Tuesday, March 24, 2009 9:57 AM
If you need a ton of them, it's likely you're going to pay a ton if they are sold individually (I don't know of any sources). Often times you see bulk deals on O27 track dirt cheap where the rail is corroded but the ties are still in good shape. You can cannibalize the track for the ties and insulators. Count on a 75% successful cannibalization and buy extra track pieces.
John Long Give me Magnetraction or give me Death.
  • Member since
    April 2007
  • 8,153 posts
Posted by sir james I on Tuesday, March 24, 2009 10:49 AM
It depends how good you want it to be. When I used 027 track I would cut popsickle sticks and stain them. Not the right height but gave a nice tie rail look. And cheap.
"IT's GOOD TO BE THE KING",by Mel Brooks
  Charter Member- Tardis Train Crew (TTC)   - Detroit3railers-  Detroit Historical society Glancy Modular trains- Charter member BTTS
  • Member since
    February 2007
  • 373 posts
Posted by ezmike on Tuesday, March 24, 2009 11:30 AM
I don't have my copy of CTT here at work, but there is a vendor ad in every issue for plastic ties for both O in black and O27 in brown. They sell in bulk lots of 100 I think. Or, you can do what Frank53 and many others I suppose do, find strips of bass wood or balsa at a craft store like Michael's or AC Moore in the height and width of the O27 ties, paint it and cut as many as you need. These stores sell these strips in 2 - 3 foot lenghts at around 99 cents each.
Mike
  • Member since
    July 2004
  • 155 posts
Posted by tjsprague on Tuesday, March 24, 2009 12:30 PM
Berk765
Three R Plastics.
http://www.8thstreet.org/3R/
Hundreds won't cost too much. alternative is to cut strips of wood, you can get the right shape and height at Lowes or Home Depot, then stain them all.
Tim
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, March 24, 2009 1:24 PM
Popsicle sticks.  They are 3/8-inch wide, compared to 1/2 inch for the exposed part of an O27 tie, but when mixed in with the metal ties, they give the impression of narrower ties generally without being different enough to stand out.
Bob Nelson
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Tuesday, March 24, 2009 3:54 PM
Thanks for all your help guys. I want my track to look very realistic. It's going to be a hi rail layout.
  • Member since
    December 2007
  • 211 posts
Posted by asch on Tuesday, March 24, 2009 8:01 PM
Berk
I would go with the popsicle sticks. I made over 6000 for my layout and love them. Once they are painted and ballasted they look great. You can buy a thousand count box at wal-mart for about 6 dollars and make 2,000 ties from them. I paint them in a very quick way. First I place a bunch on a strip of ductape, then I spray them flat black with a light overspray of red and grey primer. The tape works great because they stay in place and you can peel them off one at a time for placement.
hope this helps!
BTW great layout pic and video!
Growing Older But Not Up!
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Tuesday, March 24, 2009 9:05 PM
asch
Berk
hope this helps!
Thanks!! Sounds like a great idea. I already have the paint for that. It sounds alot cheaper also. The only thing I would dread doing is cutting all those ties one by one with my dremel tool, lucky I have one of those!!
  • Member since
    December 2007
  • 211 posts
Posted by asch on Tuesday, March 24, 2009 10:59 PM
I found that using a side cutter like a Kline tool works great. These are also known as lineman pliers. I would just do a few (hundred) while watching tv.
  • Member since
    November 2015
  • 3,584 posts
Posted by Sturgeon-Phish on Wednesday, March 25, 2009 6:56 AM
I used 1/4" black foam board cut to size.  If I were to do it over I would get some pine and cut strips to size.  Even using #3 there is enough clear wood for something as small as a tie.
Here is what the foam ties look like
Jim
  • Member since
    April 2003
  • 5,231 posts
Posted by spankybird on Wednesday, March 25, 2009 8:00 AM
Here is another source of ties. These come in both black and brown, ) 'O' and 027. These are the ones that I used. They do not have the clamping plate for the rails. Approx price is $13.95 per bag of maybe 200 or 250. You should check current pricing as it has been some time since I ordered these.
Great Plains Hi-Rail
4707 Sherwood Drive
Regina, Saskatchewan, Canada S4R 4B7
I am a person with a very active inner child. This is why my wife loves me so. Willoughby, Ohio - the home of the CP & E RR. OTTS Founder www.spankybird.shutterfly.com
  • Member since
    May 2004
  • 2,115 posts
Posted by 3railguy on Wednesday, March 25, 2009 10:22 AM
I do not know why but when I made my first post, I was convinced you were looking specifically for O27 metal ties. What the guys posted is the way you want to go. If you go home made, personally, I would stain them verses painting them because stain looks more realistic and is much easier to apply than paint.
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 12:22 PM
In my opinion, if you are going to add extra ties, do not forget this important step. You can see where I have done this in the photo below.
Be sure to slide a tie under the existing metal tie to close off the opening seen from the side - particularly if you are going to ballast your track.
The ties I am using are left over from the 50's, and I cut them into quarters and insert a "stub" into the end under the hollow metal tie.
Also, if you are going to ballast, it will look more realistic if you use good ballast and grime it liberally.
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 12:26 PM
Other things:
Before you secure your track, decide if you are going to pain the rails. Major mistake on my part trying to paint the rails after the track is down.
Super elevate your curves by placing a 1/16' thick strip of wood or wire or chipboard under the tie to the outside. That 1/16th makes a difference.
When ballasting, lay in your ballast and apply your glue and then apply weight - 10 or so pounds to hold everything down until teh glue is firmly set.
  • Member since
    January 2001
  • 1,136 posts
Posted by Kooljock1 on Wednesday, March 25, 2009 2:46 PM
 While I'm a big fan of Frank53's layout, I'm also a big fan of the ties from 3r Plastics.  I used the "O" Gauge variety:
 Jon Cool
Now broadcasting world-wide at http://www.wkol.com Weekdays 5:00 AM-10:00AM!
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Wednesday, March 25, 2009 5:29 PM
Looks awesome!! I would like for my track to look like that eventually. I wonder if there are cheaper ways to get ballast? Like crushed run from a rock quarry, and then sift it to get the smaller granuals out. And I think I would use a paint marker to paint the rails, but I will just have to wait and see about that.
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 6:13 PM
Berk765
Dennis Brennan's Ballast - well worth the price.
Painting the rails, I use Floquill roof brown. You can probably use just about any similar brown that you can get at Wal-Mart in their "Colorplace" line of sprays, which are $1.97. Paint before you permanently secure your track. Mask off the ties, spray on in light coats, use thinner to wipe down the top of the rail.
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Wednesday, March 25, 2009 6:38 PM
Frank53
Berk765
Sounds like a good plan, but I have already secured my track down
  • Member since
    February 2008
  • 554 posts
Posted by runtime on Wednesday, March 25, 2009 7:32 PM
Ahh, Frank53, the details, the details...there in lies the difference! Thanks again for sharing.
BTW, do you use cork roadbed as a foundation?
  • Member since
    December 2001
  • 1,475 posts
Posted by overall on Wednesday, March 25, 2009 8:10 PM
I recommend the ones from 3 R plastics. I have used them on my own layout and they look great.
George
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 8:27 PM
Berk765
Then mask it off in place and paint lengths of one rail at a time - starting with the furthest outer rail from you, to the center, than to the closest outer rail. In this way, you do not have to remask a lot. You can leave the step about wiping down the rails with thinner until last - even if it takes a span of days, as the paint comes right off the rails.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Wednesday, March 25, 2009 8:27 PM
There are no open ends to plug on O27 metal ties, in accordance with the overall superiority of O27 tubular track to O31.
Be cautious about superelevating toy-train curves.  It can exacerbate the problem of pulling cars off the track on curves.  I have suggested negative superelevation as a possible cure but have never tried it.
You can cut a bunch of ties to the required two-inch length at one time by stacking the Popsicle sticks.
Four 3/8-inch Popsicle sticks look good between each pair of metal ties.
Bob Nelson
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 8:28 PM
runtime
Yes, probably over kill, but I use it anyway.
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Wednesday, March 25, 2009 10:10 PM
Frank53
Berk765
Ok, that'l work. Thanks!!
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Wednesday, March 25, 2009 10:42 PM
lionelsoni
There are no open ends to plug on O27 metal ties.
I never knew that - learn something new everyday.
lionelsoni
Let's not get carried away now Bob.
lionelsoni
I have not had such a problem myself. I can see how it can happen. SInce I have taken to running shorter trains, perhaps that's the reason.
  • Member since
    February 2007
  • 373 posts
Posted by ezmike on Thursday, March 26, 2009 2:33 PM
Frank,
Are you putting cut pieces of old O27 ties inside the O gauge ties as filler? I thought you were putting pieces of the wood you used.
Mike
  • Member since
    January 2005
  • 1,991 posts
Posted by Frank53 on Thursday, March 26, 2009 2:48 PM
I am placing wooden ties inside of the metal ties to make them blend in.
  • Member since
    February 2014
  • 83 posts
Posted by Serows1 on Thursday, March 26, 2009 2:58 PM
 I am also using 027 Lionel tubular track and I purchased a bunch of plastic ties from 3R plastics, they are molded to look like real wood ties and they look great.  I will take a picture tonight and post it later so you can see what I am talking about.
Paul
  • Member since
    July 2004
  • 20 posts
Posted by ozoneone on Friday, March 27, 2009 3:17 PM
Frank53
Berk765
I am also a scale railroad modeler, in HO currently.  We generally lay our track (secure) and spray paint it (all one color), ballast, and then clean the tops of the rails.  If you look at photos of real railroad track, the sides of the rail are generally very close to the color of the ties in most cases.  On some branch lines and sidings the rail sides may be more of a rust color compared to the brown of the ties though.  This will certainly save a lot of masking time and result in even more realistic looking track.  Floquil "Rail Brown" is the color I use most for this.  Here's a random photo:
http://www.world-mysteries.com/dwp_tracks1cl.jpg
 Good luck.
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
