Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 03-21-2009 6:45 PM by tinman1. 11 replies.
Rate:
Sort Posts:
Page 1 of 1 (12 items)
03-20-2009 4:30 PM
Offline UncBob
Not Ranked
Joined on 02-24-2009
Posts 137
Radius help for a new guy
 Radius is measured --to the inside track--to the outside track --center line ?
03-20-2009 4:47 PM In reply to
Offline JWARNELL
Not Ranked
Joined on 09-29-2005
Fort Worth, Texas
Posts 73
Re: Radius help for a new guy
I have always assumed that it was the center line.
03-20-2009 5:11 PM In reply to
Offline Doc in CT
Not Ranked
Joined on 02-04-2009
Enfield, CT
Posts 270
 Radius is measured from the center point of the curve to the centerline of the track. HO track is 11/4 in wide, with standard cork roadbed just under 2in wide.
So a 18in radius curve needs a width of about 38in for a full circle.
Checkout Beginners Page Consist from NMRA.
BTW the NTRAK standard is  24in radius for mainline, 18 for branch.
03-20-2009 5:47 PM In reply to
Offline UncBob
Not Ranked
Posts 137
 Many thanks
Since I have a 4 X 9.5 , I am going with a 22 outside oval and 18 inside oval with a cross over at the bottom
I will be close to the edges with the 22 but with a wall on the one side of the long dimension and a 2 'high plexiglass  on the exposed side I should be safe from catastrophic  derailments (kind that land on the floor0
Will run Mountains, Mikados and Consolidations on the 22 and Consolidations, Moguls and Americans on the 18 with ocassional crossovers --no cars longer than 40 ft
03-20-2009 8:39 PM In reply to
Offline dehusman
Top 50 Contributor
Joined on 09-20-2003
Omaha, NE
Posts 5,078
UncBob:
Probably but chances are not well, especially the mountain.  Mountains usually like something in the 24-30 in radius range and look funky on small radius curves, below 30".
03-20-2009 9:21 PM In reply to
Offline UncBob
Not Ranked
Posts 137
 Been running IHC moutains on 22 and no problems  and they look great pulling 16 coal cars
Thing is I have had just a plain painted green homosote over plywood with one 22 oval for years and have decided to  expand and do scenery etc and get a little more serious with 2 train capability
Been using Bachman snap track and am converting over to Atlas 100
03-20-2009 9:23 PM In reply to
Offline nw_fan
Not Ranked
Joined on 11-22-2006
Dayton, OH
Posts 77
 22" may not be optimal, but it will accomodate 95% of everything on the market.
03-20-2009 9:43 PM In reply to
Offline UncBob
Not Ranked
Posts 137
 Here is a pic I just snapped of the Mountain --I am testing my new track before tacking permanently and balasting
03-20-2009 10:20 PM In reply to
Offline tinman1
Not Ranked
Joined on 06-07-2008
central Ohio
Posts 268
Radius measurements can be from any point on the track to the same point on the opposite side. Just watch you don't try going from outside to outside rails. It would be measured from left-most rail to left-most rail on the opposite side, etc.
edit- I would also clarify a little, if you are driving a nail in the center of the circle and drawing the circle, it would be the centerline.
03-20-2009 11:31 PM In reply to
Offline Texas Zepher
Top 50 Contributor
Joined on 10-12-2004
Colorful Colorado
Posts 6,219
tinman1:
That would be the diameter.  To get the radius one would have to divide by 2.  And this method only works when the track turns 180 degrees or more.
03-21-2009 5:01 AM In reply to
Offline duckdogger
Not Ranked
Joined on 09-14-2006
NE Phoenix AZ
Posts 239
 Aren't we speaking of an arc (a segment of a circle's circumference) when we discuss radius issues?  It's a point of reference and what we actually incorporate into our layout.
03-21-2009 6:45 PM In reply to
Offline tinman1
Not Ranked
central Ohio
Posts 268
My error. Radius is from the reference point in the center, more useful than diameter, especially with less than 180 arcs. Diameter is great just to see if the track will actually fit , provided that one remembers to add the width of one track to it. (ie; a 18"r will not fit on a 36" table. In HO it needs 38"min, from edge to edge).
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
