John,
Thanks! I sort of tried that last night with the following wiring connections using a ZW transformer:
Terminal 1 went to transformer terminal A
Terminal 2 went to controller 96C
Terminal 3 went to transformer terminal U and a seperate wire to the other pole on the controller (doesn't sound right but that's what the schematic looked like.
Terminal 4 & Terminal 5 not hooked up because I was not using the automatic raising feature.
It didn't work. I am getting power to the brdige because I checkedit with a voltmeter, 16 amps.
What am I doing wrong? The brdige light did light when I eliminated the controller and wired directly to the transformer. Thanks for any help you can give me.
