Hi all-
It's been a LONG time since Physics 101, and I'm finding I'm having trouble getting some basic wiring up and going. So here is what I've done so far:
I have a point to point layout with almost all of track laid and a good number of feeder wires soldered into place. I wanted to test my track plan operationally and start running trains around the layout. I have a DC power pack and a non-DCC equipped loco that I was going to use for these tests. I ran a pair of feeders from the transformer (which is located roughly in the middle of the layout) to one end and used insulated staples to hold the wire in place and screwed terminating caps on the end of the bus wires so that there was no exposed copper.
I then (stupidly in retrospect) started connecting feeder wires to the bus wires using tap splices and had roughly 5 pairs connected. However there was no power to the track. I assumed I had a short somewhere caused by debris on the tracks, but careful examination revealed nothing. I then started cutting off the feeder wires one by one in an attempt to isolate the issues to a shorted wire, etc. but there was no problem. Finally, in a moment of desperation I soldered a pair of feeder wires to the END of my bus wires and connected them to the layout. PRESTO! Things started working just fine (albeit I now have a bunch of shortened feeder wires that I need to reconnect to the bus wires).
Based on my (admittedly limited) knowldge of basic electricity then it shouldn't matter if I have power the wires just coming to a stub end, but things certainly seem to be pointing that way. Also, as a test, I created a small loop of wire that I connected to two of my feeders and then connected these loops to my power pack. Nothing reaches the tracks. I have power coming out of the booster but still nothing reaching the track
So that comes to my question: I plan on making this layout DCC in the near future (I have the Zephyr system, but I don't have the decoder equipped locos on hand) and my understanding is that I could simply swap out the power pack for the Zephyr at the right time, but my experiences are pointing to a different conclusion.
Any help on this would be greatly appreciated.
~rb
