General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 03-16-2009 1:04 PM by don7. 23 replies.
Rate:
Sort Posts:
HolbrookBill
Joined on
03-12-2009
Looking for a decent, SHORT steam switcher
I originally posted this in the "Kids and Model Railroading" forum but I haven't had any responses yet, so I figured I'd give it a shot here.
My eight year old son and I attended the local train show last weekend and when we got home he pulled out all my old train stuff. We found a small place in his room to put up a 2' x 4' switching layout and I've got the board together and even have some track in place.
The biggest problem is that with the track plan we have there's not a lot of room for cars and an engine on the sidings. I have a 70's Mantua 0-4-0 tank switcher that would be the perfect engine for switching this track IF it ran well ( and it NEVER ran well as a switcher ). Even an 0-4-0 with a tender is a little too long for this layout.
I'm looking for something similar in size, and it HAS to be a steam engine ( so my son says ). Does anyone have any suggestions on what I can use? I'd like to keep costs down, but I'm willing to pay a little more for quality... It also needs to be pretty smooth, since I know that if the engine is jerky and/or too fast that he'll lose interest. Does anyone know if the newer Mantua 0-4-0T engines are any good?
THANKS!
ndbprr
Joined on
09-10-2002
Re: Looking for a decent, SHORT steam switcher
For an eight year old I might consider a Thomas the tank engine. Walthers has Thomas and Percy on sale this month for $29.98 each. Don't know how they run but they should be ok. You would have to add some couplers to them but it isn't too hard to do. There are several small diesels you could use when you run but someone else will have to comment about the samller tank engine steamers.
DigitalGriffin
Joined on
12-09-2004
York, Pa.
No one has made a real quality detailed "Ready To Run" 0-4-0T in years. :-(
Try life-life 0-4-0T. It uses a can motor. You can get them for about $12 off eBay. And there's few detail parts that will break off. (A boon for young children). However it's not the best at running at slow speeds.
Bowser also makes a very similar 0-4-0T with a can motor. And it's made in the USA. This one has an actual seperate main rod connecting to a seperate crosshead, attached to a piston rod. It even uses a gear tower for reduced slow speed action.
If he takes care of it, you can super detail it later on with a valve gear kit, proper air compressors, proper whistle, and bell.
http://bowser-trains.com/hoemrrs/dockside/dockside.htm
Regretably for a loop, you'll have 10" radius turns. Nothing out on the market will take these kind of turns. :-(
davidmbedard
Joined on
03-26-2004
Calgary, Alberta, Canada
The Bachmann Spectrum 0-6-0T is top quality and reliable. And if it matters, the unit is DCC ready.
David B
DigitalGriffin
Joined on
12-09-2004
York, Pa.
davidmbedard:The Bachmann Spectrum 0-6-0T is top quality and reliable. And if it matters, the unit is DCC ready.
I love my 3! But the old 0-6-0T has been discontinued for over a year. A new version with DC/DCC installed already is coming out this summer. It's <$100 at most shops.
HolbrookBill
Joined on
03-12-2009
I think the Life-Like are recent versions of the Mantua engine I had, but I'm not sure I trust them. The 70s version I had ran WAY too fast when it ran at all.
I had looked into the Bowser engines, and they DO look great. I'm not worried about the engine getting damaged, since he's pretty responsible. I'll have to see if I can find a decent one somewhere!
And we're realistic about trying to do a loop - there's NO way it will happen in 2' x 4' in HO! He's more interested in a switching track plan - but even that is TIGHT. If he keeps up his interest in it, we'll EVENTUALLY expand things.
Bill
lvanhen
Joined on
07-09-2004
northern nj
ndbprr:
I have Thomas, Percy, & James for the grandsons. Thomas is a Hornby loco, and Percy & James are both Bachmann. They all run very good, even over switches!! I don't think you'll find anything shorter than Percy!! Good luck!!
HolbrookBill
Joined on
03-12-2009
While he still watches Thomas the Tank Engine on TV, he's more interested in a "realistic" railroad.
Percy IS pretty short, but I would need to mount a different body on him, somehow. I think that would take a little more time than he's willing to wait.
Darth Santa Fe
Joined on
06-21-2005
I've heard good things about the new Mantua Classics 0-6-0T, so that's one option. And like others have said, the Bachmann Spectrum 0-6-0T is excellent.
The Bowser 0-4-0T has one of the smoothest drives around, but because of the short wheel base, you may want to add extra electrical pickups to it, like track sliders on the ends.
The Life-Like 0-4-0T has a fast running motor and a high speed gear ratio, and will run far beyond realistic speeds.
HolbrookBill
Joined on
03-12-2009
Any idea where I CAN find a Bowser 0-4-0T? I understand they're not making steam any more!
ESlade4
Joined on
01-18-2008
I or my 8 year old step son has the life-like 0-4-0T and Thomas, the LL likes to run better at higher speed probably because of it's short wheelbase, it was easier to put knuckle couplers on than I think Thomas would be. I haven't had any maintence issues with either to this point.
carknocker1
Joined on
01-05-2007
Northern Ill.
I recently picked up a New Mantua 060 Tank engine . It is DCC ready , It runs really well and at slow speeds ideal for switching .
Darth Santa Fe
Joined on
06-21-2005
HolbrookBill:Any idea where I CAN find a Bowser 0-4-0T? I understand they're not making steam any more!
Bowser still has some left for sale: http://www.bowserorders.com/.sc/ms/sch/ee?search=dockside (scroll to the bottom of the page) They're currently $60 each, and I don't see the detail kit or valve gear kit, so it would be stuck as a basic model (unless you can find the right parts somewhere). I hate to say, because I'm a supporter of Bowser products, but you may be better off with the Mantua or Spectrum switchers.
DigitalGriffin
Joined on
12-09-2004
York, Pa.
Call them and place an order! They have them in stock. But once the stock is gone, that's it!
TomDiehl
Joined on
02-20-2001
Poconos, PA
HolbrookBill:
THANKS!
I have four of the Mantua/Tyco 0-4-0T's curently running on my layout. One of them is the "newer" plastic body. The first thing I'd suggest is to take it apart and give it a good overall cleaning. Start by cleaning the motor out and adding a drop of oil to each end of the motor shaft, you'll see the bearings. For cleaning the contact surfaces and wheels, I'd recommend a typing eraser, the kind you sharpen like a pencil. Buff the bottom plate of the motor and the frame where the motor contacts the frame. This will give you better conduction. Next, clean the "V" shaped pickup. Last, reassemble the locomotive, turn it upside down, apply power through leads from the power pack, and clean the wheel treads.
One question I'm going to ask since I didn't see it addressed above, is "what kind of power pack do you have?" If it's the small block shaped one that came with a train set, it's more likely the cause of your poor running than any locomotive, in fact, the best loco will run poorly with this type power pack, and it will NOT control a can motored loco. Toss that thing and get a decent power pack. Or keep it and only use it for wheel cleaning as suggested above.
Also, did you clean the track, since it's been in storage for years?
