Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 02-25-2009 8:54 PM by train_frk-0079. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
02-01-2009 12:09 AM
Offline train_frk-0079
Not Ranked
Joined on 01-30-2009
Peotone, IL
Posts 71
Cork roadbed or caulk?
I have seen most railroads with conventional cork roadbed, and they were flawless.  A few days ago, I also saw a new type of roadbed, caulk.  This brought up a question while I was reading a blog reading.  Is caulk better than conventional roadbed?  Is this a new way of laying track that not many people know about?  If you know anything about this, sound off.
Peace
02-01-2009 10:20 AM In reply to
Offline DeadheadGreg
Not Ranked
Joined on 12-24-2007
Delmar, NY
Posts 668
Re: Cork roadbed or caulk?
i dont think ive ever heard of anyone thats used caulk, straight up, for roadbed.  You can use caulk to ATTACH your roadbed....  but using it AS roadbed would seem to be a huuuuuge hassle.
You'd have to keep a uniform thickness, you'd have to have something to make sure it kept a somewhat uniform width, you'd have to somehow give it a proper ballast profile, you'd only be able to do a little bit at a time to get the track attached to it before it tried...
it would be a huge hassle dude.
 If anything, what you probably read about was someone laying an industrial spur or some yard trackage, where roadbed isn't used, and they were just using the caulk to attach the track to the subroadbed.
Offline locoi1sa
Top 500 Contributor
Joined on 07-13-2006
Posts 965
 Some people use caulking to stick the track to the roadbed. You can glue the cork and use caulking to glue the track to the cork.
     Pete
02-01-2009 5:52 PM In reply to
Offline RFinch
Not Ranked
Joined on 02-18-2002
Posts 374
 I think the caulk he's talking about is the kind that comes in strips in rolls and can be purchased in Lowes or Home Depot.  I believe that this method was described in this forum a while ago.  You might do a search in the forum topics under strip caulk used as roadbed.  I plan to use Midwest brand N scale cork roadbed on my new layout.  After it's attached with latex caulk to the extruded blue foam sub-roadbed, I plan to paint it with earth tone or grey latex paint to seal it from drying out.  After the paint is dry, I'll attach the track with a thin layer of latex caulk.
Bob
02-02-2009 1:39 AM In reply to
Offline gjvjr50
Not Ranked
Joined on 10-14-2006
Posts 45
 Not sure but I think the caulk they talk about is similar to the black sticky type with cork imbeded in it used to rap refregerent lines to prevent sweating.  It is also self sticking so you might not need any glue or whatever to stick down or to stick track too?
02-02-2009 7:04 AM In reply to
Online tstage
Top 10 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,720
train,
I know of vinyl roadbed but not caulk.  Do you have a link to the blog that you are referring to?
02-02-2009 11:11 AM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-13-2005
Southwest US
Posts 7,244
I have a roll of grey goop, about 1/16 thick, purchased at Home Depot, that could probably be used for N scale roadbed.  It's close kin to the adhesive pads used to stick bathroom accessories to the side of the shower enclosure, but not as tenacious.  IIRC, the now-vanished outer packaging included caulking sinks and tubs among its potential uses.
Personally, I would never use it for ANYTHING on my model railroad.  It has a consistency similar to gently-chewed bubble gum, oozes under load and loses its stick-to-it-iveness quickly once exposed to air.  Not characteristics that go well with bulletproof trackwork.  The one time I tried to use it to anchor temporary track to plywood it proved even more temporary than the trackwork!
There may be other, more suitable, products out there.  I personally use latex caulk to attach extruded foam roadbed (cut from fan-fold underlayment) to the plywood subgrade and to attach flex track to the roadbed.
02-06-2009 11:12 PM In reply to
Offline Allegheny2-6-6-6
Top 500 Contributor
Joined on 03-24-2007
Posts 1,020
 I think what he might be refering to is what is commonly known as topper tape. It's the foam that comes in a roll that you put between a pick up bed and the "topper" or "cap" It's suslaly gray in color and has a foam texture with a peel off backing to revel the glue impregnated in it. I've actually seen it used on one of Allen Kellers Great Model Railroad videos but I can't recall who's railroad it was. Actually pretty impressive, inexpensive way to do it.
02-08-2009 9:55 AM In reply to
Offline pcarrell
Top 25 Contributor
Joined on 02-17-2005
In the State of insanity!
Posts 7,976
I've been using this rope caulk for a few years now and it's great!  Dirt cheap too!
(Click any pic to enlarge)
It comes in a roll like this........
And I use a wodden wall paper roller (the kind used to do the edges when hanging the paper) to smooth it and create trasitions in rail height easily.
It's flexible, and stays that way for many years, so it's quiet, and it's very easy to work with.
I can lay dozens of feet of it in just minutes, and since it's just a little tacky, it stays where I put it with no further adhesive.  Ballast and scenery will hold it in place when all is said and done.  I pull it apart lengthwise for N scale widths, for HO just use it straight from the package.
This was all layed in about ten minutes and is ready for track.
(This shows with the track installed, but it was part of that which went down in about ten minutes.  Obviously, the track took longer.  The cheap latex caulk I use to secure the track sticks to this stuff well too.)
I don't know if this is what you're talking about, but it works for me!
02-25-2009 8:54 PM In reply to
Not Ranked
Peotone, IL
Posts 71
You guys were right.  I went to my friend, and he cleared it up for me.  Thanks for you input.
Peace
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
