#16 AWG (the size wire used in lamp cords) is enough for buses on all but the largest layouts. Lots of people use #14 AWG house wire 'cause its readily available and mechanically rugged. Electrically its bigger than necessary, but that doesn't hurt anything. I don't use #12 AWG house wire because it is too stiff to bend easily with long nose pliers. Feeder wires (short feeders that is) can be thinner. #22 or #24 AWG or even smaller works.
You can find a "copper wire table" on the Internet. Such a table will give you the diameter in inches and the resistance in ohms per foot, or ohms per 1000 feet.
As a rule of thumb, the wire is thick enough if the voltage drop is less than one volt. Voltage drop V = IR where I is current (in HO use 1 amp for planning purposes) and R is the resistance of the wire going out AND coming back. Or, for HO, just keep resistance down below one ohm.
