Hi!
I agree with Martin - if you can't/won't solder, you will have a hard time being successful in layout building. Most (I won't say all) track joints should be soldered if they are intended to be permanent for any length of time. This especially applies if you are using flex track. Wire joints can be succussfully made with the various types of connectors - to a point. Nothing beats a good soldered joint for proper electrical flow - and durability.
If you are a stranger to soldering, pick up a decent 45 w iron (Sears), some small diameter rosin core solder, READ the instructions, and practice, practice, practice. Its really quite easy but does take some knowledge to do it properly.
Just last month, my 41 year old son needed to solder a guitar pick-up wire. He told me he had never soldered before. I was shocked, as "my generation" was doing stuff like that as young teens - and I ASSUMED everybody knew how to do that. I should know better.
Anyway, I could have easily fixed the problem, but he bought his own iron and "learned the hard way" - but did get the job done.
ENJOY,
Mobilman44
PS: Don't test the in process or completed joint with your fingers to see if it is still hot.
