jbinkley60:
rrinker:
Not for motor control - just dial up the loco on the opposite end when you go 'backwards' with the consist so you have control of the lights and horn adn bell in the 'lead' loco.
Like so: 1000--1001--1002 all consisted with Advanced Consisting on consist 10, with 1002 leading. Dial 10 on the right throttle to control speed and direction of the consist. Dial 1002 on the left to control the lights and horn without all that silly "which function is active in a consist" programming. Now you reach the end of the line and want to go back the other way. Keep 10 on the right knob, but now dial 1000 on the left so when you blow the horn the one in 1000 sounds instead of 1002. Or if 1001 is the only unit with a sound decoder, dial that one on the left.
--Randy
You can do that with universal consisting too. That is actually what I tested. The difference was the right knob was the top locomotive 4 digit address, not a 2 digit advanced consist address. It should work exactly as you describe for advanced consisting too.
Well, the idea was to save on slot usage by using CV19 consisting. On a 3 unit consist that only saves one, because you have the consist address plus the lead loco selected, but on a 4 unit consist it saves 2, 5 units saves 3, etc.
Something else to work on, a JMRI script that periodically clears idle slots. Rather than have someone constantly checking to keep the system from running out of slots, it probably could be automated, so slots are cleared faster than the command station does it to avoid slot full errors.
--Randy
--Randy
