Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 01-07-2009 4:24 PM by JamesShannon. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
01-04-2009 2:53 PM
Offline Fred Bear
Not Ranked
Joined on 01-09-2006
Foothills of Wva
Posts 679
Artificial Christmas tree branches for pine trees
Found an old artificial Christmas tree and with a pair of scissors, made some wonderful pines, all size, some really big trees that tend to be a bit expensive.  Has anyone else experimented with this? Jake
01-06-2009 4:56 PM In reply to
Offline GregM
Not Ranked
Joined on 03-22-2004
Ohio
Posts 603
Re: Artificial Christmas tree branches for pine trees
I remember seeing this on a video quite a while ago.  However, I don't remember what video it was on.   If I ever run across it again, I will update this thread.
01-06-2009 6:00 PM In reply to
Offline Fred Bear
Not Ranked
Foothills of Wva
Posts 679
Thanks much, I appreciate it. Jake
01-06-2009 6:41 PM In reply to
Offline brianel027
Top 200 Contributor
Joined on 11-04-2003
The ROMAN Empire State
Posts 1,912
Yep Jake and I've mentioned this one a few times. You can often find an older (and actually better quality) artificial tree at a yard sale. I find some of the older ones actually have more "needles" on them, thus appearing as thicker trees when you are all done.
The older ones I've used have twisted metal that the "needles" are wrapped into, so I have found a hack saw necessary to cut the branches down to tree height. I have experimented with trying to glue Lifelike Grass to the branches, but haven't found a glue that holds the grass material for any great length of time without the grass coming loose. I tried a spay glue made by 3M and it worked good initially, but the grass soon came loose.
But I have spray painted them for greater variety. I start with brown paint right up close to get the color to the twisted metal. Then I use various shades of green and blue to do the "needles" spaying that color on from a little more distance to get the color on the outshape of the tree, while retaining some brown on the metal core. Of course, I do this after I have shaped the "needles" so that I have some pine trees of variety of appearances.
I tend to use my better looking or shall I say more detailed trees up front, and then the artificial tree pine trees for the back ground. And as you said Jake, you can made some pretty big trees, which are nice to have around the layout for variety. Or you can put a taller pine in the center of some smaller more detailed trees.
I got a half dozen plain pine trees, but with flocking on them, sold at RiteAid with their holiday decorations for half off. I've discovered a trick to help these trees retain their flocking material. This goes for hobby made trees from other companies. I make up a mix of watered down wood glue, similar to what I use for gluing down ballast or scenic material. Then I soak the trees in that for 5 minutes or so to let the glue soak in. Then I put the wet trees in a pie tin and allow the excess glue to drip off, turning the trees gfrequently to allow equal excess to drip off all sides. Once the majority of glue has dripped off, I will speed the process up and either put them out in direct sun (in the summer) or use a blow dryer.
I've had good luck with this and it does keep the flocking from coming off, which without doing I found does happen over time. I've also done this to my LifeLike "lollypop" types of trees (spring trees, apple trees, fall foilage trees, etc). I got a whole load of them very cheaply years ago when a Woolworth's closed. I also take those and shape them a little bit. I've also removed the plastic base and after some reshaping, will glue one tree on to the top of another matching tree to make a much taller one. I also replace the plastic bases of some trees, using dried out real pine branches taken from tossed out real CHRISTmas trees. I'll drill a tiny hole into the top of the branch and insert the tree into that.... gives a little more height variety.
Years ago at a pet shop I found an aquarium decorative plant I think was called FoxFir or something of the like. I was kind of a branchy looking plant that was colored various shades of brown. I use this on my layout, cutting them down to a couple inches in height, and then placing them in bunches close together which gives the appearance of smaller leaf-less trees. What I like is I can get these up close to the track and because they are soft plastic, there's no damage to trains or trees if they get hit by an engine or unusually wide car.
01-06-2009 7:01 PM In reply to
Offline Fred Bear
Not Ranked
Foothills of Wva
Posts 679
Thanks for the tips on this, much appreciated, Jake
01-06-2009 7:18 PM In reply to
Offline dwiemer
Top 75 Contributor
Joined on 03-15-2005
Southwest Georgia
Posts 3,740
I believe this was also written about on the "tips and Tricks" section of CTT awhile ago.  As Brianel has suggested, probably better to use these in the background with more detailed trees up front.
dennis
01-06-2009 10:26 PM In reply to
Offline Texas Chief
Not Ranked
Joined on 08-13-2006
Central Illinois
Posts 252
How about some PICs ?
Dick
Texas Chief
01-06-2009 11:31 PM In reply to
Offline brianel027
Top 200 Contributor
Posts 1,912
I'd love to Dick, but I can no longer get photos to post here for the life of me? I never had trouble before the format change here. I can still post them to the OGR forum with no trouble, but here... it's a major headache.
I've read Bob's instructions several times and they don't really help. I don't even even get the "preview" button he speaks of when opening the "Insert/Edit Image" window. Could be my computer too?
So to compensate, I tried to describe the process as much as I could. They say a photo is worth a thousand words. But since I can't get photos to post here anymore, I went with the first option!
01-07-2009 11:31 AM In reply to
Offline R. T. POTEET
Top 100 Contributor
Joined on 04-04-2006
THE FAR, FAR REACHES OF THE WILD, WILD WEST!
Posts 3,232
Check out the January, '85 Model Railroader for an article titled A Source for Large Pine Trees which covers this topic
I have an acquaintance who, somtime in the late '80s, visited whatever BIG LOTS was called before they changed their name right after Christmas and came away with a couple of tall artificial trees that rendered him about 800 evergreen armatures of varying heights for less than four cents apiece. I even ran into a fellow modeler in a K-Mart store right after Christmas a couple of years ago and he was buying one of these artificial trees with the string of lights already attached. He said that he had bought one of these a few years before and, even though it took a little bit of doing, he came away with a string of lights in addition to evergreen armatures. It is a way to save a few bucks if you have a layout that needs pine trees.
01-07-2009 4:24 PM In reply to
Offline JamesShannon
Not Ranked
Joined on 12-08-2004
Posts 39
Any pictures?
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
