Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 01-03-2009 10:50 PM by jbinkley60. 31 replies.
Rate:
Sort Posts:
Page 1 of 3 (32 items) 1 2 3 Next >
01-01-2009 9:40 AM
Offline mobilman44
Top 500 Contributor
Joined on 09-17-2003
Southeast Texas
Posts 1,579
What is your Preference for Non-Sound HO Decoders?
Good Morning and a Very Happy New Year to you all!
As I am converting to DCC in a few months - along with rebuilding my layout - I figured its time I started asking your preference on decoder brands.  While I have 5 BLI Paragon locos with decoders, none of the Stewart, P2K, Atlas, Kato, or Spectrum locos are so equipped - so I better start shopping.
Before I actually ask the question, let me say that I know my way around a soldering iron and wiring (not electronics), and the new DCC system will be Digitrax Super Chief w/4 districts.
Sooo, my question is, what brand of non-sound decoders do you prefer?  I am more concerned about quality and availability and support - with price being somewhat secondary.
Thank you all in advance!
Mobilman44
01-01-2009 9:43 AM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,111
Re: What is your Preference for Non-Sound HO Decoders?
 NCE D13SRJ.  Inexpensive, loaded with features, has 4 light outputs, 9 pin interface (for easy decoder switchout).........
David B
01-01-2009 9:45 AM In reply to
Offline elansp
Not Ranked
Joined on 07-18-2007
Bergen County, NJ
Posts 164
Digitrax for me...
01-01-2009 10:12 AM In reply to
Offline jrbernier
Top 100 Contributor
Joined on 01-08-2001
Rochester, MN
Posts 3,147
  It depends on what you are looking for in a decoder.  You can buy basic 'fleet' decoders with 2 light function outputs and basic motor control in the $15 range.  If you are looking for 4-6 light function outputs and 'BEMF' motor control, you can spend up to $25 for a decoder.  NCE, TCS, and Digitrax all have decoders in both price ranges.
  The other part of the equation is 'form factor':
  • Lightboard Replacements - These are specific to a brand/model of engine and you basically 'swap out' the supplied light board with the new decoder based one - they will cost more.
  • Wired Decoders - Most of these are in a small package with a JST 9 pin connector on the end of them.  They may come with 9 loose wires or a JST to NMRA 8 pin cable so they can be plugged into a DCC Ready engine.  You can buy various lengths/styles of DCC harnesses that work with these 9 pin JST decoders.  This makes swapping out a decoder very convenient.  A lot of the newer Athearn RTR engines have an NMRA socket and a short harness supplied with them - decoder install is very quick.
Check out www.tonystrains.com or www.litchfieldstation.com and compare featues/prices to get a 'feel' for this.  There are a lot of dealers with very good decoder prices if you buy 'in bulk'(4-10 decoders).
  Older Steward F unit engines have no socket - I just hard wire them  Most P2K engines from about the mid 90's have a 8 pin socket, as do newer Kato/Atlas engines.  The above 2 web sites and the manufacturers web sites have a lot of model specific decoder install info - Look for it and read up.
Jim Bernier
01-01-2009 10:43 AM In reply to
Offline simon1966
Top 50 Contributor
Joined on 07-07-2003
Metro East St. Louis
Posts 4,205
I agree with all of the above.
I just picked up a 4 pack of the NCE D13SR decoders and these are an excellent low cost fleet decoder.  I used all 4 for hard wire applications in an eclectic mixture of locomotives.  In one of the applications (A 4 car Eurostar trains set) the 4 functions were very useful for adding control to interior lights in the passenger cars.
My absolute favorite non-sound decoders are from TCS.  The MC2 range in particular is a real favorite.  It is really small, which makes it great for tight spaces.  The TCS back EMF is superb and provides amazing low speed control.  Plus the goof proof warranty is hard to beat.  I also like the fact that TCS offers a range of harness models to compliment the decoders which can be helpful in particular applications.
I also run Digitrax decoders and have no complaints about them.
All 3 are good manufacturers.
01-01-2009 11:57 AM In reply to
Offline TA462
Top 75 Contributor
Joined on 06-07-2004
PORT HOPE, ONTARIO
Posts 3,587
I'm a fan of Digitrax decoders and in my 5 years in the hobby using Digitrax decoders and DCC equipment I have never had a decoder fail.
01-01-2009 12:22 PM In reply to
Offline New Haven I-5
Top 500 Contributor
Joined on 11-10-2007
Southern California
Posts 1,476
Digitrax & NCE decoders.
01-01-2009 2:33 PM In reply to
Offline jbinkley60
Top 200 Contributor
Joined on 02-19-2006
Gahanna, Ohio
Posts 1,820
mobilman44:
Mobilman44
I use Digitrax decoders in all of mine.  If you use the DH165 series decoders you can always add sound later.  Many of the 165s have built-in current limiting for the lights so no bulb changes to worry about.  Most of mine have been drop in or plug in conversions that go very quickly.
01-01-2009 7:27 PM In reply to
Offline joe27
Not Ranked
Joined on 08-08-2008
Posts 38
I have used Digitrax and TCS decoders for my older engines where all that was needed was the basics. Personally I like the way that the TCS decoders work much better than the Digitrax. Some of my Athearn blue box engines had a low speed growl with the Digitrax. When I switched to TCS the growl went away and the engine had a lot better low speed performance.
"Hope this helps,
Joe
01-01-2009 7:39 PM In reply to
Offline draftingplans
Not Ranked
Joined on 01-27-2002
Alexandria MN
Posts 33
 NCE D13SRJ, 4 function for most applications as stated before. Use a PNP harness if the loco calls for it or hard wire it in. I have installed about 30 of them and have not had a failure yet.
Another source of decoders and great information about what decoder to use in locomotives is from Tim Smith at Empire Northern Models. Tim's store is only a few blocks from NCE.
Great prices and especially if you need a number of decoders.
01-01-2009 10:11 PM In reply to
Offline Mark R.
Top 500 Contributor
Joined on 04-25-2004
Posts 890
TCS all the way for me - have over 50 of them in use. Great running characteristics, very quiet, best price for all you get including the Goof Proof warantee .... I fried two of them (my own error) and they were replaced no questions asked !!!
Mark.
01-02-2009 6:41 AM In reply to
Offline locoi1sa
Top 500 Contributor
Joined on 07-13-2006
Posts 965
 TCS,NCE or Lenz. TCS is the way to go for performance and great lighting features. There rule 17 dimm when stopped and F4 is great. When used with LEDs the dimming is adjustable. NCE for the excelent ditch lights they have.
01-02-2009 8:52 AM In reply to
Offline fmilhaupt
Not Ranked
Joined on 05-29-2003
SE Michigan
Posts 432
While I use Digitrax as the control system, I much prefer NCE's decoders, for the simple reason that I prefer the way that NCE decoders support LEDs for lighting effects.
01-02-2009 8:53 AM In reply to
Offline Phoebe Vet
Top 200 Contributor
Joined on 09-21-2007
Charlotte, NC
Posts 2,210
I have decoders from Digitrax, TCS, Bachmann (I think they are made by Lens), and Tsunami.  I have been happy with them all.  Once installed and operating properly, I have never had a decoder fail.
01-02-2009 9:15 AM In reply to
Offline jbinkley60
Top 200 Contributor
Gahanna, Ohio
Posts 1,820
fmilhaupt:
I am curious by your statement.  I've always used Digitrax decoders and have never had the reason to look at NCE and others.  What specifically do you like about the NCE decoders that I may be missing out on or is it how they've implemented the lighting effect feature ?  I do agree that the FX3 functions that DIgitrax implements in the 163/165 series can be a little complex to program in the CVs but I've not found myself wanting for something else yet.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
