Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 12-24-2008 12:48 PM by fredswain. 4 replies.
Rate:
Sort Posts:
Page 1 of 1 (5 items)
12-23-2008 6:55 PM
Offline jat875
Not Ranked
Joined on 12-18-2008
Posts 13
4X8 Layout
I need some different ideas on track layout. This is all i can come up with.  Does anyone have any ideas for a 4X8 o scale layout.
http://i197.photobucket.com/albums/aa41/jat875/IMG00309.jpg
12-23-2008 7:46 PM In reply to
Offline Texas Zepher
Top 50 Contributor
Joined on 10-12-2004
Colorful Colorado
Posts 6,467
Re: 4X8 Layout
 Ok, I have lots of ideas.  If the picture is what you currently have it looks like a simple figure-8 inside of an oval.  Are the two totally separate?  Is there only the one train or are multiple run at the same time?  Is this a simple AC power supply or do you have Lionel's or MTS's control system?
What exactly do you think it is lacking?
Idea:
1.  Put two turnouts on the figure-8 so the train can reverse itself.
2.  Add a turnout on the outside loop for a stub end siding that fits into the narrow part of the figure-8.
3. Add two turnouts connecting the two loops together so the train can move from one to the other.
4. Add four turnouts and a crossing at one end connecting the two loops together so that a train can go from either loop to the other in either direction.
5. Totally remove the inside figure-8 and replace with lots of industries to switch cars in and out of.
6. Totally remove the inside figure-8 and add two passing sidings to make a single track mainline where two trains can meet and pass each other.
Some of these ideas are obviously mutually exclusive.
I don't know how many of these would fit on a 4 x 8 but there are lots of good ideas.  Note especially O-2, O-3, O-7.
http://www.atlaso.com/O%203Rail%20NS%20web/index.htm
12-23-2008 9:15 PM In reply to
Offline superbe
Not Ranked
Joined on 02-13-2007
Shenandoah Valley "The Home Of Patsy Cline"
Posts 399
Re: 4X8 Layout
I'd add two suggestions to the good ones already posted. It looke like you have some space in the right hand corner to add to the layout. If you are not ready to do this now place a spur so you can link to it in the future.
Second, my layout top is flat like yours but with foam on top of the plywood. If I had it to do over I'd use WS's foam system or use their idea of having different levels of foam to get away from the perfectly flat surface.
Just my 2cts.worth.
Good luck and keep posting pictures of your progress.
Bob
12-23-2008 11:14 PM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 10,017
Re: 4X8 Layout
Here's some ideas from the Atlas 3 rail site.
Of course not all are 4x8's.
EDIT-Ooops! I didn't see that Texas Zepher already posted that link.
12-24-2008 12:48 PM In reply to
Offline fredswain
Not Ranked
Joined on 08-30-2006
Posts 446
Re: 4X8 Layout
Check out the current 4 part series in Classic Toy Trains Magazine. It's a 4 X 8 logging themed layout. Here's a link to a video of it running:
http://www.trains.com/ctt/default.aspx?c=a&id=1474
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
