Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 12-24-2008 11:28 PM by Texas Zepher. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
12-22-2008 3:02 PM
Offline NR5A
Not Ranked
Joined on 12-20-2008
Posts 8
First Layout?
I'm probably biting off more than I can chew, but is it possible to build a N scale layout on a 2' x 4' board its about all the space I can spare. Ok now comes the part thats going to kill it. i want it to be mountains, either logging or coal mining. Would like a tressile bridge and a stream under it. Would be steam 1940's area or earlier. I don't know where or how to start a layout like this. I've seen several track layyouts this size but they are all flat. Any ideas? Jerry F.
12-22-2008 3:27 PM In reply to
Offline West Penn Nscale
Not Ranked
Joined on 10-23-2007
Washington PA
Posts 72
Re: First Layout?
http://www.youtube.com/watch?v=veEvKHFGd5s
 Jerry, Take  a look at Dave Vollmer's PRR Nscale layout, I think you get a ton of ideas from this layout...
Good Luck
12-22-2008 4:03 PM In reply to
Offline ARTHILL
Top 75 Contributor
Joined on 03-09-2005
New Brighton, MN
Posts 3,843
Re: First Layout?
Welcome to the forum. What you want can be done. If you make the mountians out of foam you can have huge mountians and canyons. Pick out the theme. Draw a simple track plan that works. I built a 4x8 HO once that had three levels of track in a continuous overlapping loop with a three level trestle and a mountian and a water fall and a lake and a small yard. Build it and have fun. Later you can do it over or include it in a larger layout.
12-23-2008 5:11 PM In reply to
Offline cuyama
Top 500 Contributor
Joined on 12-27-2001
Northern CA Bay Area
Posts 1,138
Re: First Layout?
Randy Gustafson's multi-level N scale logging layout is even smaller than you are contemplating (something like 18"X36"). Tight curves and streep grades, but it shows how much can be done in N scale. There's a hidden turnback loop below the visible scene.
The layout was described in the July 1995 Model Railroader.
There have been many examples of a 2X4 N scale layouts with grades and topography. Although they are somewhat expensive compared to alternative methods, the Woodland Scenics pre-cut foam grades work well for grade changes.
Byron
Model RR Blog
12-23-2008 5:47 PM In reply to
Offline NR5A
Not Ranked
Posts 8
Re: First Layout?
Wow, thanks for the info. I guess I can do what I want. Next step subscribe to the magazine then figure out how to get that issue and study it.
Jerry - NR5A
12-23-2008 5:51 PM In reply to
Offline steinjr
Top 500 Contributor
Joined on 07-25-2006
Sorumsand, Norway
Posts 1,757
Re: First Layout?
NR5A:
Jerry - NR5A
 You don't need to subscribe to get back issues (although a subscription is, IMO, worth it).
 Here you can order back issues.
http://www.trains.com/mrr/default.aspx?c=bi&id=6
 Smile,
 Stein
12-24-2008 6:58 PM In reply to
Offline Kenfolk
Not Ranked
Joined on 10-16-2007
Tennessee
Posts 688
Re: First Layout?
I model in n-scale and think you should have no problem doing that with a 2 x 4 size.  Mine is 2 x 8 (with an even narrower segment in the middle that allowed me to set it up as a shelf above my workbench. Go for it, and keep us posted on your progress.
12-24-2008 11:28 PM In reply to
Offline Texas Zepher
Top 50 Contributor
Joined on 10-12-2004
Colorful Colorado
Posts 6,219
Re: First Layout?
NR5A:
is it possible to build a N scale layout on a 2' x 4' board ... i want it to be mountains, either logging or coal mining. Would like a tressile bridge and a stream under it.
My first "Pine Ridge & North River was a 2' x 4' with that theme.   I have no pictures or track plan from it, but I did expand it to a 2' x 8' in 1978 as below. Well, I should not say expanded.  I started over from scratch.  On a 2' x 4' the grade up to the mine obviously had to be much steeper, the mine smaller (no run around at the mine), and less room for the industries below.   The upper bridge over the river had a water fall immediately behind it.  The river was fairly far below grade level.   Note the radical (for the time) hidden storage area.
The mine had its own switching locomotive that worked the cars through the mine.  It would make trips with full cars down to town to put on the interchange track (the long dog leg one toward the center), and pick up empties & supplies for the mine.  Through trains and the local that took the hoppers away lived in the hidden yard.  At shows, the hidden tracks were accessible from behind so a person could 0-5-0 different trains onto the out most track.  That way a spectator would not see the same train circulating over and over.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
