I guess just under 200 diesels (and two Santa Fe Northerns). Most of my engines are Santa Fe, and are units that were in service in 1989 with a couple of exceptions. I tend to build my roster around certain diesels that were common in the area I model. There are no "blue boxes", most are Atlas and Kato, with some P2K and other stragglers. I do have a few Genesis.
Bob
Alot...seriously....over 50
Very few of them are stock, most are kitbashed from minor to almost scratchbuilt, happens when you're sans layout for 3 years and are stuck with the workbench being your primary outlet.
Have fun with your trains
Wow! I am really impressed with some of these lists. My hat is off to all of you.
I have seven.
Modern and running well (HO scale): a BNSF SD40-2, a UP SW1200 (can't recall manufacturers).
From my 1950s model RR: an HO Varney F3 and an American Flyer S-scale 4-4-2.
Another HO Varney F3 bought several years ago.
Recently bought used in not-running condition: an Athearn HO F3 and an HO GG1 (with working pantographs) of questionable vintage.Although it's not a locomotive, I also have an HO Budd RDC (can't recall the manufacturer) from 1953.
You made me curious, so I went downstairs and counted. Currently on the layout (and almost all used during last op session) are 156 first and second generation diesels. Stored under the layout awaiting paint and decoders are another 30 or so. Just don't let the wife know.
Larry
http://www.trainboard.com/railimages/showgallery.php/ppuser/8745/cat/500
http://www.youtube.com/user/ClinchValleySD40
http://www.flickr.com/photos/52481330@N05/
http://www.trainboard.com/railimages/showgallery.php/cat/500/page/1/ppuser/8745/sl/c
I have three engines...a GP38-3, a GP38-2 and an AC4400CW...all painted for Canadian Pacific.
I wouldn't answer that question until at least the third date!
Randy
I have 20.
14 Missouri Pacific for the prototype I'm modeling. I have either pictures, train orders, accident reports, or 1st hand information proving the engines I selected ran on the particular line I model.
They include:
one MP15DC - which the Mopac tried to run as road engines when they first arrived
Three GP15-1 - smokey valley parts which will be replaced once Athearn releases theirs
one GP7U - Atlas
one GP28 - kitbash from Athearn RTR GP35
one GP38 - Atlas
two GP38-2 - Athearn
two U23B - Atlas
one B23-7 - Atlas
one GP35 - Athearn RTR
one SD40 - Athearn RTR
Because I also enjoy the Rock Island and they have a line that crossed mine I included some of their engines.
one U33B - Atlas kitbash
one GP35 - Kato
one GP38-2 - Athearn
one GP7 - Atlas
one GP40 - Atlas
I also have a SDL39 for the MILW. Love the look of the engine so I couldn't resist. It's the only non-prototypical engine for my line.
Nate
I am a N-scale modeler and for the most part have my equipment in storage until I obtain a home that will house my layout and can only estimate the quantity at between 200 and 300 with list growing because I keep adding while I travel for my job.
I visit hobby shops in the areas that I work and often hit eBay for locos and rolling stock.
Powered engines for actual use on my layout ? Seven - two home road (Chicago, St. Paul, Minneapolis & Omaha - "Omaha Road") yard switchers, one parent company (Chicago & Northwestern) road switcher, and 4 neighbouring companies (MSTL, GN, NP, MILW) road switchers for dropping off or picking up interchange traffic.
Of which maybe 4 will be on the layout at the same time - the two home road yard switchers and a couple of road switchers either delivering a cut of cars or picking up a cut of cars from my yard.
Roster=====CMO GE 44-ton switcher #51 CMO GE 70-ton switcher #53 CNW FM H16-44 #1514 MSTL Alco S1 #142 MILW Alco RS3 #2475 GN Alco RS3 #228 NP EMD GP7 #569
Last digit of road number is DCC id.
And yeah - I know that the Omaha road didn't have GE 44-ton and GE 70-ton yard switchers in Minneapolis in 1957.
I am using a bit of artistic license here - like pretending that GN GE 44-ton switcher #5201, sold as an industrial switcher to Iron and Steel Products Co in 1948 and renumbered #51, instead was sold to the Omaha road, was renumbered #51 and used at the West Minneapolis yard, along with a GE 70-tonner #53 aquired from somewhere else.
CMO had a mix of other switchers in the 50-series of road numbers when it was merged into C&NW in 1957 (#55 was an EMD SW-1, #56-57 were Alco S1s, #58, 59 and 60 were Baldwin VO-660s), so it is not such a stretch to assume that #51 and #53 could have been GE switchers.
Same with the MSTL Alco S1. MSTL didn't have any S1s - but they had an S2, aquired in 1941, and consequenly numbered 741 (engine no 7 bought in 1941). I am postulating that they also got an S1 in 1942, and numbered it #142. C&NW had S1s, but I like the paint scheme of MSTL.
The rest of the road numbers (CNW, GN, NP, MILW) are historical for the company and type of engine, courtesy of http://www.thedieselshop.us and http://utahrails.net/cnw/cnw-index.php
Smile, Stein, very much approaching rivet counter levels, no doubt
Ah, well, I wanted to show a list of my 91 locos too, but my list is in table format with snapshots of my locos imbedded so I can remember what is what when I see one way down at the end of the line, but can't remember which loco # it is. I keep the list next to my controller.
So anyway I thought I would show how they look when not on the layout.
About 77 are in the cabinets, and the steamers are all in 4 of those camera cases (on the floor for the moment). I use another empty case with form-fit foam cutouts to carry locos to and from the layout as I have nearly had several knocked out of my hand by swinging doors otherwise.
My advice to all model railroaders is simple:
Buy locomotives ... and lots of them!
Overbrook RRI totally REFUSE to EVER put any of my 27 locomotives into any display case. So I guess that is the answer, I have 27 locomotives all on the layout, none in storage or in a display case.
Ah, Mr. O. I feel for you. So I guess you are at your LIMIT with 27, then. Whereas I have 20+ on my layout and still the rest in display cases from which I swap them around regularly(as noted in my earlier post in this thread)......giving me room to SHOP for MORE.
Well from have my first 4x8 layout, I've bought four locomotives. The motors in the GP-35's worked great for awhile, now when I turn them on all they do is scream. Well they were the 35 dollar starter DCC locomotives, the 8-40 CW are my best and favorite at the moment. I would like to get the newer GE's with sound.
CSX GP-35 4402
CSX GP-35 4406
CSX 8-40 CW 7661
CSX 8-40 CW 7662
Well, you seemed a little shrill. I guess if there is one thing I have seen in a forum with over half a million posts is that there are very few rules and even fewer admonishments applicable to model railroading and railroaders.
About 200 or so. 63 in Espee, 44 in BN, 16 in MRL, 15 in SBD, 16 in C&NW, 13 in Oregon Central & Pacific, 6 in Amtrak, 4 in Mountain Pine Lumber, 1 in Southern and about six miscellanous units.
Hi!
Sorry it took so long to reply - been in "trainless" Fredericksburg Texas for the Holiday.......
I have collected a "plethora" of HO ATSF & IC locos representing the '30s thru '50s. At last count, there were 65. Note that I have several ABBA combinations with the b units powered, and I counted each b unit as an individual loco. If you were to truly call ABBA or AB consists as 1 loco, then I am down to 44. However, I am selling off some on Ebay this month, trying to get the number down to a more manageable group. Diesel switchers are mostly P2K, with a couple of Kato and Stewarts. F Unit consists (F3, F7, F7, FT, FT, FT - all ABBAs) are Stewarts. E units and Alco PAs are P2Ks, and Alco RS are Atlas. Steamers are 4 BLI Paragon, 3 Bachmann Spectrum. Oh, almost forgot, got a new BLI RSD-15 Paragon that is in their shop as it is silent........
About half of the above are new in the box or test run only. I had the collector fever for 5 or 6 years and now realize that I can't use them all.......
ENJOY,
Mobilman44
ENJOY !
Living in southeast Texas, formerly modeling the "postwar" Santa Fe and Illinois Central
More than 2 dozen and mostly Athern ,got a couple old tyco's, 1 kato, and 2 old Bachmann steamers.
HamltnblueThere's nothing distastefull about collecting Engines or anything else.
It was about a year ago when I took everything down and boxed thing up to do a complete rebuild of my layout. I know I have more than 150 engines now from my last count. Allot of mine are older, but about a third of them are newer with DCC and some with sound. I would hate to count how many parts engines I have or one that are in parts only condition. I hate to throw anything away or part with it sometimes when it comes to my train item. I am about do for a downsize of some of the engines again on Ebay. I have a few freinds that always tell me, "you cant run them all at once"! I guess I like making an old or bad running loco run like a top and tinker with them, parts is parts I guess.
