Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-29-2008 9:17 AM by Vernon/IN. 13 replies.
Rate:
Sort Posts:
Page 1 of 1 (14 items)
11-08-2008 4:36 PM
Offline Railfan Andy
Not Ranked
Joined on 09-26-2008
Lewisburg Pa.
Posts 24
Which system is right for me?
 Hi everyone.  I currently have the Digitrax Zephyr as my DCC system.  I don't really like it and I would like to get  a new system.  I would like to have more mobility with a DCC system.  I was looking at an NCE system, because you have wireless throttles.  The wireless throttle idea seems nice, even though I have a small switching layout, the wireless option is nice because I have to move around alot to get to my different industries.  Also, with the digitrax system, when I running a locomotive, sometimes the engine will stop and then start up again.  Especially with a sound loco, it will continue to run, but will stop and then start up again.  I would like a simple DCC system with a wireless or tethered throttle.  Also, it only has to have one throttle, at a reasonably low cost.
11-08-2008 4:59 PM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,111
Re: Which system is right for me?
 Well, you already have a fine system.  Just add a UT4 and a couple of UP5s and you are set.  UT4s can be used wirelessly out of the box if you buy a UR90.  If you want Radio, then you will need a UT4R and UR91.
In terms of your sound locos starting and stopping, that is a pickup problem, not a DCC system problem.
 David B
11-08-2008 5:22 PM In reply to
Not Ranked
Lewisburg Pa.
Posts 24
 Thanks David, I'll consider it.  What are the throttles that are obong with more capabilituies that is put out by digitrax?
11-08-2008 9:18 PM In reply to
Offline mfm37
Not Ranked
Joined on 07-04-2008
Posts 417
 Big one is a DT400
Smaller one is the UT4.
 I agree with David, the stalling is caused by poor pickup between the track and the loco not the DCC system. Solve that before upgrading any thing because the trouble will continue.
Martin Myers
11-08-2008 9:41 PM In reply to
Not Ranked
Lewisburg Pa.
Posts 24
 Hey Thanks Martin and David.  I guess I'll clean the wheels of my loco, and now that I think of it, that's really the only one that does that?
Thanks,  Cheers,
Andy
11-09-2008 7:30 AM In reply to
Top 50 Contributor
Posts 5,111
 Not all sound-equipped locomotives are made equal.  If you gave us some more information, we might be able to help.  What locomotive?  Which decoders?  What scale...etc....
David B
11-09-2008 9:30 AM In reply to
Offline jrbernier
Top 100 Contributor
Joined on 01-08-2001
Rochester, MN
Posts 3,147
Andy,
  Full function throttles like the DT400 or DT400R will work.  To go radio 'wireless', you will need to get:
  • UR91 radio wireless base unit(uncludes wall plate and plug-in)
  • DT400R(for full function) or a UT4R(utility throttle)
 The UT4/UT4R series throttles are limited in function(like building consists, and programming).  I would buy at least one DT400/DT400R throttle.  A friend of mine has a single DT400R throttle he uses to 'program' with and build locomotive consists for his operating sessions.  He then 'steals' the consist with one of his four UT4R throttles and hands the UT4R to the engineer of the train.  He does not want the operating crews to to have a powerful DT400R in their hands.  This reduces the chance of accidently breaking up a consist or other 'pranks'.
  The UR90 'infared' base station and the DT400/UT4 throttles use infared beams to comunicate.  Though they are not limited to 'line of sight', you better have lots of white paint in the ceilings/walls of your train room so the signal can 'bounce'.  Also, make sure no one is standing in front of the UR90 base station!
  The DCS050 'Zephyr' is a great command station.  The 'built in' throttle is limited, but is included in the base price.  The system has a lot of features:
  • Operate up to 10 engines at once
  • Full CV 'read back'
  • Can be expanded
  • Can have a computer interface added
Jim Bernier
11-09-2008 3:04 PM In reply to
Not Ranked
Lewisburg Pa.
Posts 24
 David,
  I have been using the new Atlas North Shore GP38 wit sound installed.  It's in HO scale.  I'm not sure what decoder it has in it, probably Atlas.
11-09-2008 3:56 PM In reply to
Top 50 Contributor
Posts 5,111
 Is this factory installed sound or aftermarket?
It is a good lesson.  It is best to keep a chart somewhere, where you list which locomotive has which decoder.  And it is important to give the specifc model of the decoder (ie:  Digitrax DH123).
David B
11-09-2008 5:33 PM In reply to
Not Ranked
Lewisburg Pa.
Posts 24
 Good tip David, I'll try it.  Oh, and by the way, it was a factory installed decoder.
11-09-2008 6:00 PM In reply to
Offline jrbernier
Top 100 Contributor
Rochester, MN
Posts 3,147
Andy,
  Your Atlas engine should have a QSI sound decoder.
Jim
11-09-2008 7:05 PM In reply to
Top 50 Contributor
Posts 5,111
 Yup, a QSI decoder.  It should run like a dream.....
Here are a few things to check.
1.  Place the loco on the track and aquire it.  Pickup the front truck, then the rear truck.  There is a possibility that one of the wires from one of the trucks has come dislodged from the decoder.
2.  Are your wheels in gauge?
3.  Are your wheels clean?
David B
11-10-2008 5:20 PM In reply to
Not Ranked
Lewisburg Pa.
Posts 24
 Yea Jim, I remember getting the QSI manual with the loco.
11-29-2008 9:17 AM In reply to
Offline Vernon/IN
Not Ranked
Joined on 09-21-2007
Central Indiana
Posts 37
davidmbedard:
David B
David makes a good point.  It is a good idea to keep track of the decoder and the associated CV settings.  If you get the Digitrax PR3 and download DecoderPro, you will be able to program your decoders and maintain a database of the CV settings.  You will also be able to work with the sound projects of certain Digitrax sound decoders.
I hope this helps.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
