Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 10-31-2008 6:50 PM by davidmbedard. 3 replies.
Rate:
Sort Posts:
Page 1 of 1 (4 items)
10-31-2008 4:44 PM
Offline Gerome
Not Ranked
Joined on 12-18-2007
Posts 115
Want to ask ques. re. this NCE decoder before I sent it back.
I have used many, many NCE D13SRs, but I seem to have one now that has a weird "delay".  The decoder works in all respects, reading and writing CVs and will respond correctly, eventually---
And that is the problem.  This decoder (in an Atlas/kato C-424 that works in all respects, clean wheels etc.) has a full 5 second+ delay before responding to the throttle.  It will run at the correct speed once it gets itself wound up, and so on, but the delay is weird.
It is not any CV voltage setting giving the problem.  It has a delay at all settings.
Think it is a glitch.  I wondered if anyone had a similar occurence.
10-31-2008 5:16 PM In reply to
Offline cacole
Top 25 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 8,589
Re: Want to ask ques. re. this NCE decoder before I sent it back.
Are you sure CVs 3 and 4 are set to 0?  It sounds like they have a higher value, and they are the Momentum CVs.
10-31-2008 5:40 PM In reply to
Online rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 7,584
 When all else fails, try a decoder reset. On the D13SR's, set CV30=2 for a reset. It might be a programming glitch, or a bad decoder. By at least resetting the decoder to factory defaults you can see if it's a programming glitch.
                      --Randy
10-31-2008 6:50 PM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,109
 Here is a silly question.....have you tried a reset?  If so, I would check your wires to make sure you arent playing with a crimped wire somewhere.
If everything checks out, then absolutely send it back to NCE....they will take good care of you.
David B
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
