General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 10-29-2008 10:39 AM by DanRaitz. 5 replies.
Rate:
Sort Posts:
Page 1 of 1 (6 items)
10-27-2008 7:11 PM
Offline mk55
Not Ranked
Joined on 07-14-2007
belle vernon
Posts 15
decals
i have decals wanting to make/print my own....how do i go about doing that?
10-27-2008 7:43 PM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,624
Re: decals
Well, this may end up sounding complicated, but it's really not.  Yeah, it's a lot of steps, but every one is pretty simple.
First, get the right kind of paper, and think carefully about your decals.  For an inkjet printer,  you need inkjet paper, and for a laser printer you need....Aw, c'mon, why do I always see the same hands?  Right!  Laser paper.  Well, duh...
Your printer can not print white.  How do I know?  Because you don't have an Alps printer.  How do I know what kind of printer you don't have?  Because if you had an Alps printer, you would probably already know this, and you wouldn't take your chances with some online train guy like me.  So, you don't have an Alps printer, and you can't print white.  With me so far?
So what if you can't print white?  Well, that's a problem if you're planning to print a white C&O logo to put on a black hopper.  You can't do it.  So, we get back to the planning part.  Think about printing dark items on light backgrounds.  That is much simpler, and it's really a better place to start.
I use Microsoft Word to print my decals.  For text, it's easy.  Load the font, type the words.  You can even pick the colors.  For graphics, you can import the picture into Word (Insert-Picture-From File) and then size it the way you want it.  Change the margins to get as high as you can on the page, and as far to the left as you can.  That decal paper is expensive.  Use a little, cut the top off cleanly, and you can use the same piece of paper again.
Now, Grasshopper, is the time for patience.  You have decals printed on decal paper, and you just can't wait to put them on.  Wait.  Go to sleep, and dream of distant places, and whistles sounding through the hills.  While your mind is dreaming, more likely of exams you forgot to study for and classes you went to in your underwear, your decals have dried thoroughly.  Apply decal sealant, either a spray or Micro Scale's Liquid Decal Film.  Go to work, or those classes which you hopefully really have studied for.  If nothing else, put something on over your underwear.  Return to your humble abode, and repeat the sealing process.  Wait a few hours, or do the sleep-and-dream thing, or the classes thing.  When everything is really dry, your decals are ready.
But is the surface of your model ready?  It should be clean and very smooth, mostly.  Use a gloss or satin coat for a smooth surface.  If you want a really crummy, beat-up old looking decal, use a surface covered with Dul-Cote.  (That's not sarcasm, by the way.  I've put most of my decals on this way, intentionally.)  Once the surface is ready, use a decal placement solution, like Microscale's MicroSet, to get the decal on smoothly.  If the surface has naturally uneven texture, like a grating on the side of a locomotive, Microscale's MicroSol will help fit the decal down into the grooves.  I use a small, cheap paintbrush to apply these and to nudge the decal in place.
Finally, seal the decal surface after it's all dry.  You may find that the edges curl up, or the decal doesn't go down smoothly.  Use a little more MicroSol to re-soften and smooth down the decal.  Once it's totally flat and dry, give it some more gloss, satin or flat surface spray to seal it.
Here's a trolley I did with my own decals, on a satin-finish surface:
And this is a couple of posters I put on a wood fence, wanting it to look like the weather had gotten to it:
When I started this, I knew nothing.  The first time I put one of my home-made decals in water, it dissolved completely, because I didn't know I had to seal it.  It's a learning process, and each time you do it, you'll learn a bit more.  Have fun, and let's see some pictures when you've got one you're proud of.
10-27-2008 8:02 PM In reply to
Offline GAPPLEG
Top 500 Contributor
Joined on 01-07-2002
ERIE PA.
Posts 1,656
Re: decals
Follow the above advice and your on the right road. Been doing my own for years: all the below:
And all these vehicles done by me:
http://s50.photobucket.com/albums/f317/GAPPLEG/VEHICLES/
10-28-2008 12:41 PM In reply to
Offline HarryHotspur
Not Ranked
Joined on 10-06-2004
Posts 608
Re: decals
 Mr. B -
Lots of good info. Thanks.
- Harry
10-28-2008 3:31 PM In reply to
Offline shayfan84325
Top 500 Contributor
Joined on 11-06-2007
Utah
Posts 826
Re: decals
To do white lettering on clear decals you can do a photo screen-printing process.  The equipment will cost about $30 and you still create your layout with your computer.  The drying/fixing/applying/finishing is the same.
This website will tell you more about the process:
http://www.photoezsilkscreen.com/about.htm
10-29-2008 10:39 AM In reply to
Offline DanRaitz
Not Ranked
Joined on 09-07-2002
Grand Rapids, MN, USA
Posts 177
Re: decals
I used the SuperCal system http://www.supercaldecals.com , to make the decals for lettering and numbering my private leasing units.
Dan
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
