Hi Guys
I have a number of old 50's electric semaphore signals which scale out quite well and work.
I intend to use them hiding the base could be a bit tricky
wiring the signals is straight forward as they are twin coil solenoid operated so wiring the signals and pairing the ones that should be paired is easy with a CDU
But how do I wire it so that stop stops the train and if possible caution slows the train neither is mentioned in the instructions, I guess that was not an issue back then
I know how to bypass the IRJ so a train that should ignore the back of the signal does with a diode.
But how do I do the rest of it
regards John Busby
