General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 10-16-2008 6:39 PM by vsmith. 15 replies.
Rate:
Sort Posts:
Page 1 of 2 (16 items) 1 2 Next >
10-15-2008 6:26 PM
Offline simon1966
Top 50 Contributor
Joined on 07-07-2003
Metro East St. Louis
Posts 4,205
Tip for those that don't like the wasted space on the forum
Lots of folks are complaining about the small dialog section in the middle and the waste of space due to the column of advertising on the right. Here is a tip to solve the issue.  IE7 has a very nice zoom feature in status bar (bottom right of your web browser).  Use that tool to set the image at 125% or 150% and the advertising is pushed off the screen to the right and you get almost a complete display width of forum dialog.  I am fairly sure that the latest version of Firefox has a similar feature.  This forum layout is the perfect place to use this feature and solve a problem for yourself.
10-16-2008 12:19 AM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-13-2005
Southwest US
Posts 7,239
Re: Tip for those that don't like the wasted space on the forum
To those, "Lots of folks..."  If that's your most serious problem, you don't have any.
10-16-2008 12:55 AM In reply to
Offline citylimits
Not Ranked
Joined on 11-01-2004
Modeling the Seaboard Air Line Ry.
Posts 410
simon1966:
Yep, that, does it.
Cheers
Bruce
10-16-2008 1:19 AM In reply to
Offline R. T. POTEET
Top 100 Contributor
Joined on 04-04-2006
THE FAR, FAR REACHES OF THE WILD, WILD WEST!
Posts 3,232
I discovered that if you go to about 150% and then Zoom-In a couple of times you will completely loose the images at the right of your screen.
10-16-2008 7:56 AM In reply to
Offline cacole
Top 25 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 8,589
With FireFox, you press CTRL + as many times as needed to get the screen size you like.  If you overdo it, press CTRL - to recover.
A strange thing I have noticed with IE7 is that after enlarging the screen to 125% the page links are one number off; i.e., to go to the second page I have to click on number 3; for page 3 click on page 4, etc.  This seems to be more a problem with the screen enlargement than the forum software, though because if I go back to 100% screen size the page numbers are right..
10-16-2008 9:04 AM In reply to
Offline jacon12
Top 100 Contributor
Joined on 11-13-2002
US
Posts 2,940
 I use a mouse that has a scroll wheel so I hold down the control button, turn the wheel and thus size the screen to fit my monitor or however it is comfortable for me.  So far Windows has remembered this for this website and it's the same when I visit again.  Very easy problem to correct.
JaRRell
10-16-2008 9:15 AM In reply to
Offline Dean-58
Not Ranked
Joined on 04-18-2008
Duluth, MN
Posts 207
Y'know, back in the '50s people were constantly writing to MR to complain about the advertising content! They never seemed to realize that without advertising a publication would cost a fortune to purchase.  (Besides, are you interested in trains or not?)  I don't suppose managing a website is any different: you've got to pay for the publication somehow, without charging the readers for it!
10-16-2008 10:18 AM In reply to
Offline vsmith
Top 10 Contributor
Joined on 12-20-2001
Smoggy L.A.
Posts 9,246
simon1966:
Well feed me corn and watch me grow! That helps alot! Thanks
Never knew that was there, helps with reading the smaller text also!
10-16-2008 10:37 AM In reply to
Offline WSOR 3801
Top 500 Contributor
Joined on 12-06-2004
WSOR Northern Div.
Posts 1,102
Dean-58:
Maybe the size of the ads could go down for subscribers.  Be another bonus.  I subscribe to MR & Trains, and usually get all the special issues (and Classic Trains) as well.
10-16-2008 10:57 AM In reply to
Offline tcwright973
Not Ranked
Joined on 05-02-2005
Pittsburgh, PA
Posts 309
jacon12:
JaRRell
Thanks for that tip. I never knew you could do that, and here I thought I knew what I was doing. But then, I'm also someone who not only understands why there are ads on these web sites, but enjoys them. I like seeing what's new, what's available, and at what cost. So they don't bother me one bit.
10-16-2008 11:09 AM In reply to
Offline Dallas Model Works
Top 500 Contributor
Joined on 09-06-2006
Dallas, TX
Posts 778
For me, the issue is not so much the right hand column (for reasons which may be apparent ) but the amount of header stuff at the top of the page.
I have huge monitors yet still have to scroll down quite a bit to even get to the forum threads.
10-16-2008 11:18 AM In reply to
Online Don Z
Top 200 Contributor
Joined on 08-24-2005
Austin, TX
Posts 1,792
Dallas Model Works:
Craig,
I'm using a 22.5" wide screen monitor with my display at 1680x1050 and I can see the first post on the page when I pick a thread. Maybe your resolution is set too low....
Don Z.
10-16-2008 12:09 PM In reply to
Top 500 Contributor
Dallas, TX
Posts 778
Don Z:
Dallas Model Works:
Craig,
Don Z.
Thanks Don
All monitors are set to max res.
On the 30" and 22" widescreens I can see a number threads.
It's on the 21" CRT monitors that I have the issue. The are set to highest resolution but once you factor in the toolbars on the browser plus two separate headers (one for trains.com, one for mr.com) at the top of the page, that's a lot of real estate taken up.
I could hit F11, but I am trying to multi-task! ;-)
Craig
10-16-2008 12:31 PM In reply to
Offline Autobus Prime
Top 500 Contributor
Joined on 05-05-2005
The mystic shores of Lake Eerie
Posts 1,357
tomikawaTT:
 3T:
That's true, but there are two opposing forces at work here:
1.  Don't sweat the small stuff (as you correctly state).
2.  Problems tend to grow to fit the available tolerance.
I suggest a quick look at an old copy of POPULAR MECHANICS, and its current heir, which NUKEES has renamed POPULAR ADVERTISING INSERTS.
I really like the 1960s MR covers, with little more than a title, a price, and a photo.  It's almost artistic-like.  Our present-day periodicals are so "busy".
(Of course, then you look at 1960s RMC, which looks like the back pages of a comic book. :) )
10-16-2008 5:23 PM In reply to
Offline Texas Zepher
Top 50 Contributor
Joined on 10-12-2004
Colorful Colorado
Posts 6,216
That is a cool hint but it doesn't increase the amount of information available on the left hand side of the screen.  It just makes it bigger.   That is my real issue.  Reading the messages makes me feel like I am reading a column in a news paper rather than "letters" from other forum members.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
