Jake1210 wrote: |
| You can file it by hand with a mill file, but that is very difficult and can misshape the points or the notches in the stock rail. Recently FastTracks came out with a tool similar to the PointForm that allows you to file the notch in the stock rail and taper the point rails, I believe it was called the StockAid. Look on their website, (handlaidtrack.com) it should be under 'point building tools' on the left. |
Say what?
This arthritic old coot (I can say that, but you had better not!) has been shaping rail for hand-laid turnouts with a BIG mill file since well before FastTracks came into business. All it takes is a delicate hand, a close eye for what is going on and a good idea of where you are trying to go.
Granted that quick, sloppy, careless work can result in worthless scrap. In my experience, the more usual reason for unsatisfactory results is the use of little needle files where a 1" by 12" flat file would be a better choice.
Chuck (modeling Central Japan in September, 1964 - on hand-laid specialwork)
