Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 09-25-2008 2:45 PM by rlplionel. 69 replies.
Rate:
Sort Posts:
Page 2 of 5 (70 items) < Previous 1 2 3 4 5 Next >
09-04-2008 10:45 AM In reply to
Offline krapug1
Not Ranked
Joined on 12-30-2004
East End of Long Island
Posts 277
Re: What Track Do You Use?
I use Fastrack for the main level of my layout, with some 0 gauge tubular used in my Union Station complex.  For switches I use Fastrack 036 and some 022 used with the adapter track.
 My elevated track section is Marx 034, using a combination of Marx metal track elevators and Lionel trestles.  This section uses no switches.
Ken
09-04-2008 10:49 AM In reply to
Offline traindaddy1
Top 500 Contributor
Joined on 01-05-2006
Northeast Bronx
Posts 1,319
Lionel O27 Tubular..I have an extremely tight budget and very limited income.  Also, being a "player" rather than "modeler", the track looks just fine.   Of course, when I close my eyes  Zzz [zzz] I  dream of Gargraves and Ross.  Thanks for asking.
09-04-2008 12:35 PM In reply to
Offline overall
Not Ranked
Joined on 12-26-2001
US
Posts 756
Traindaddy1,
You might think about using 027 profile track along with Ross Custom Switches. It comes in radii up to 054.The money saved on the track can go toward better switches. Just a thought.
George
09-04-2008 12:45 PM In reply to
Offline traindaddy1
Top 500 Contributor
Northeast Bronx
Posts 1,319
George......Thanks for the advice.
09-04-2008 12:53 PM In reply to
Offline ChiefEagles
Top 10 Contributor
Joined on 02-03-2004
Rolesville, NC
Posts 10,540
I used Reltrax.  No connectivity problems as I solder long sections together to help.  I think, once laid out and screwed down, it is not a problem.  The switches have been a problem but hopefully that will improve.  Fastrac is great too.  Some say noisey.  Toy trains are going to be noisey.  With homasote or soundstop underlayment, noise is reduced.  Gargraves andRoss switches seems the be the most popular.
09-04-2008 1:35 PM In reply to
Offline dougdagrump
Top 75 Contributor
Joined on 11-28-2003
Sunny SoCal
Posts 3,646
Wonder if anyone has experimented with expanding foam on the Fastrack to help deadin noise or does it get to rigid when it cures ?
09-04-2008 1:36 PM In reply to
Offline 3railguy
Top 200 Contributor
Joined on 05-04-2004
Kaukauna WI
Posts 2,138
See what you started Chief? Shame on you!!!
I have experienced practically all the track systems and have samplings stashed away. Tubular O31 has been my long time favorite but it is beginning to take a back seat to Lionel Fastrack. Fastrack is expensive but it looks and works great with postwar Lionel and MPC. It seems I can blast trains at full throttle through the switches and crossings without a hitch. I also like it for its ease of use and variety.
MTH Realtrax is OK I guess. I just don't care for the widely spaced ties, zero magnetic permability with magnetraction, and the way the contact strips work.
09-04-2008 1:39 PM In reply to
Offline phillyreading
Top 150 Contributor
Joined on 01-08-2005
Lake Worth FL
Posts 2,957
I use GarGraves and 027 on my second level and GarGraves and O gauge 042 track on the lower level with GarGraves switches. Used GarGraves switches for a replacement of Lionel switches(6-23010), problems with derailments solved for me. Other nice thing about GarGraves & Ross switches is that the motor can be replaced while the switch is still mounted in the layout.
Had to replace too many Lionel 6-23011 & 23010 switches, these switches are most unfriendly to Williams engines, something about using a Lionel 6-23010 or 23011 with a Williams engine, once you run a Williams engine within two track sections(any direction) of those switches they go bad inside the switch.
My upper level is 027 track with 27 inch curves around the ceiling of my train room.
Have not used Atlas O gauge track or Fastrac or MTH Realtrax. Tried to sell some new and never used Fastrac at local train show and no luck.
Lee F.
09-04-2008 2:49 PM In reply to
Offline jd-train
Not Ranked
Joined on 07-25-2006
Posts 46
My 5'x6' Christmas layout uses my older MTH Realtrax along with two 0-31 turnouts.
My new permanent 11'x14' (soon to be 11'x17') layout uses Ross turnouts, with Gargraves sectional for the curves, Gargraves flex track for the straights, and Gargraves uncoupler sections.
Jim
09-04-2008 3:25 PM In reply to
Offline 3railguy
Top 200 Contributor
Kaukauna WI
Posts 2,138
Lee F.
You are lucky if you got anything to work on those switches. What a disaster those switches were and they should be on the top ten list of toy train blunders. I pity dealers who were stuck with them.
09-04-2008 3:39 PM In reply to
Offline mpzpw3
Not Ranked
Joined on 05-28-2003
US
Posts 523
Interesting, and again, I'm wrong.
Here are the results so far (Sorry Marx and K-line track users, I'm lumping you in with Lionel tubular.):
Tubular: 10 people
Gargraves and or Ross: 3
Fastrack: 7
Realtrax: 3
Atlas: 2
Not really what I was expecting. I was thinking Ross and Gargraves would be right under tubular. Fastrack looks to be more popular than I thought. When the weekend is over, I will re-tally. Thanks to everyone who has posted!
09-04-2008 4:02 PM In reply to
Offline Southwest Chief
Top 500 Contributor
Joined on 12-09-2003
Anaheim CA/Bayfield CO
Posts 893
We use Ross track exclusively (both switches and track).  We have never experienced any troubles whatsoever and don't have to clean the track as much as HO.
09-04-2008 4:15 PM In reply to
Online ben10ben
Top 500 Contributor
Joined on 01-28-2003
Frankfort, Kentucky
Posts 1,755
"You are lucky if you got anything to work on those switches. What a disaster those switches were and they should be on the top ten list of toy train blunders. I pity dealers who were stuck with them."
I have three on my layout, and they have been absolutely flawless. They're considerably more reliable than postwar O22s, work consistently at lower voltage, and are much smoother. Plus, I like that I can make closer spaced yard sidings than is possible with O22s.
Kookjock also has several of these installed on his layout, and reports no trouble with them.
If anyone has any of these switches which they were "stuck" with, send me an e-mail and I'd be more than happy to take them off your hands. I love the ones I have.
09-04-2008 4:36 PM In reply to
Offline billbarman
Not Ranked
Joined on 05-14-2007
New york
Posts 262
On my old floor layout I used lionel fastrack and for a few years it worked perfectly then the train started to go extreamly fast on one part of the layout and extreamly slow on others. so I cleaned the track but it still happened. Then I started hear buzzing between where the tracks connected and it got really hot there. But I still like the system I used it for 3 years with no problems. Now I use tubular because theres nothing more reliable... Not to mention its cheap! Big Smile [:D]
09-04-2008 5:14 PM In reply to
Offline willpick
Not Ranked
Joined on 02-05-2002
Boca Raton, FL
Posts 336
Christmas tree layout is Realtrax, with 2 switches. So far, it's been flawless. Permanent layout is all Atlas. Had some problems with the switches, but fixed them all--.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
