General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 08-19-2008 2:50 PM by Flashwave. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
08-19-2008 11:34 AM
Offline Southwest Chief
Top 500 Contributor
Joined on 12-09-2003
Anaheim CA/Bayfield CO
Posts 892
Digital Font HO Decals?
Does anyone produce a digital number set in HO scale?
I checked Microscale and did not find any digital fonts.  I probably could make my own decals since I only need black digital numbers.  I found several free digital fonts online.  The only problem is getting them small enough to print for HO scale.
08-19-2008 11:51 AM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,609
Re: Digital Font HO Decals?
It's not hard to make your own decals.  Plain black-on-clear is the easiest of all.  If you can download the font you want, you can use MS Word or other word processors to set the size of the characters ("point size") and print whatever size you want.
08-19-2008 12:26 PM In reply to
Top 500 Contributor
Posts 892
The font I have can only go down to "point size" 1 in Word.  It can probably get a lot smaller in PaintShopPro.  Hmm I'll have to figure out how to make a vector first.
I need the numbers for an Amtrak Superliner II Sleeping car ID.  I have a SupII sleeper for my Southwest Chief trainset and the SupII's have digital number readouts.  So the plan is to get the numbers small enough to fit.  I might even back light it with a small suface mount greenish LED.
Can't tell much of what this is, but it's the best photo I have saved:
08-19-2008 1:10 PM In reply to
Top 10 Contributor
Bedford, MA, USA
Posts 9,609
Another way to make it smaller is to make the graphic in MS Paint.  Make it nice and big.  This also lets you set up the background color.  That way, you can just print it on plain paper, cut it out and you won't need a decal.
Once you get the whole image the way you want it in Paint, save the file.  Then open up Word and use Insert-Picture-From File and select your image.  You can then re-size the entire picture in Word to get the size you want.  This gets around any minimum point-size limitation you may have with the font.
By right-clicking on the image, you can bring up a "Properties" box.  That will allow you to change the size by typing in height and width in inches, which gives you very fine control over the final size of the picture.
08-19-2008 1:19 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,311
I make up my decals in MS Paint and use the printers scaling to reduce their size.
08-19-2008 1:21 PM In reply to
Offline danmerkel
Not Ranked
Joined on 11-15-2002
Findlay, Ohio
Posts 280
You can shrink the size by making the dots per inch higher... an image that is done at 150dpi will get 75% smaller if you go down to 600dpi.
Also, when working at such small sizes, it is easy enought to construct just what you need, one pixel at a time.  If you have Paint Shop Pro, use the paintbrush tool, set it to one pixel in size then magnify the image to about x15.  That makes it real easy to click the pixels off and make up whatever you want or need.
At 600dpi, an HO scale, 3" letter is only about twenty pixels tall.
Hope this helps...
dlm
Offline edo1039
Not Ranked
Joined on 01-02-2002
Summerfield,Florida
Posts 270
Matt check your email.sent you some info.
08-19-2008 1:32 PM In reply to
Top 500 Contributor
Posts 892
Wow so much great help in so little time, I'm impressed.  Thanks all.
Eeek MS Paint Dead [xx(]  My sister is big into texturing and when she upgraded to PhotoShop, she gave me her old PaintShopPro8.  I'm a little spoiled not having to use MSPaint.
I've also used MS Word to "shrink" many images.  Works pretty well, but not always as clear as the original.  A lot depends on the original.
All of the custom decals I've done over the years have been in G scale.  Pretty easy to get the right sizes in this large scale Wink [;)]
Oh, if anyone was thinking of trying something similar, I believe the digital font I'm using came from here:
Digital Font
08-19-2008 2:08 PM In reply to
Offline rs2mike
Top 500 Contributor
Joined on 10-06-2007
ohio
Posts 952
interesting, I am going to havwe to try this out.  Seeing as Pine River Falls Railroad is freelanced and the rub ons' never give you enough letters, it should work out to be a lot cheaper.  Excellent thread.
08-19-2008 2:50 PM In reply to
Offline Flashwave
Top 150 Contributor
Joined on 06-12-2007
Indiana
Posts 2,528
Digital Font
Ah ha. Then what ypou may try is to haul the pic into Pintshop or Photshop, open up the image properties, unclck the image constrictions, and crank the resolution to 45000 in Paintshop or 30k in Photo.   (Maximums for them) they should stay the same size. Then reduce them to the size you need. They'll be much clearer.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
