Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 07-27-2008 11:27 PM by ChiefEagles. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
07-27-2008 12:23 PM
Offline coldstorage5
Not Ranked
Joined on 01-01-2008
Posts 37
What should be the table top??
Hi Im ready to build my (12 by 6 ) L shaped lay out.....  What should the table top be???
Should I use Homosote???  Should I put the Homosote on top of plywood???
What is the advantage of Homosote???
Thanx  CS
07-27-2008 1:01 PM In reply to
Offline willpick
Not Ranked
Joined on 02-05-2002
Boca Raton, FL
Posts 336
Re: What should be the table top??
For plywood, I'd use 1/2" minimum, if you can afford 3/4", it's better than 1/2". Make sure you properly brace  the legs. I'd also brace the underside at 24" intervals or less. Homasote can be expensive, there are alternatives- cork roadbed, foam roadbed(from Woodland Scenics), and Viynlbed and Homabed. I used a cheaper alternative--- HushBoard from Georgia Pacific. It's not as dense as Homasote, but it still holds nails & screws like Homasote. But it's 30-40% cheaper----
If you use Homasote/HushBoard, attach it to the plywood with plain old white glue or construction adhesive. Screw the Homasote down until the glue dries, then remove the screws. If you screw the track down, be sure to use screws that do not penetrate into the plywood(you want to keep from transmitting the sound into the plywood).
07-27-2008 1:55 PM In reply to
Offline Sturgeon-Phish
Top 150 Contributor
Joined on 03-02-2005
Southern Ohio
Posts 2,333
I used 1/2" OSB.  Usually it is cheaper than plywood, and has one fairly smooth side.  24" O.C. spacing is more than adequate.  This setup is what is used for new construction roof framing!  I would then put down foam or go with homasote or similar product.  I did not and regret it.  My layout can get very noisy.
IMHO get your table the best it can be in the front end to avoid problems later.  A lot of the strength comes from the bracing between the top and the legs.  1 x 3 set at 45 degrees on all leg / table joints.  Also, use sheetrock screws to put it together.  Love those things!
Do a few searches.  There are several threads of construction progress of tables.
Jim
07-27-2008 1:56 PM In reply to
Offline traindaddy1
Top 500 Contributor
Joined on 01-05-2006
Northeast Bronx
Posts 1,319
I like the Homasote board and mostly agree with 'willpick' about the plywood.  While 3/4" is probably desireable, I have found that 3/8" or 1/2" is less expensive and lighter.  I think that with the Homasote, it will work as well. (But that's only my My 2 cents [2c])  Good luck and post some pictures on your progress.
07-27-2008 3:52 PM In reply to
Offline ogauge
Not Ranked
Joined on 12-27-2007
W.Lafayette, IN
Posts 406
I've been thinking about a different combination of "stuff" to quiet the noise some.    Might try 3/4 osb or chip board, pretty dense so thats a good start.  Next glue carpet padding to the top of that.  Next use pink or blue foam glues to the padding.  Could probably use homosote glued down as well.  Then to hold the track down use some of those  plastic drywall anchors that screw in  to grab the drywall and then the #4 screws  in the anchors.  The idea with the carpet padding is to put a seperate layer between the base and the track support.  The track support would float on the pad and transfer much less sound to the base than just homosote glued down.  Anyway, its just an idea and it probably would be cost prohibitive as well although the carpet padding is really cheap.
07-27-2008 6:25 PM In reply to
Offline chuck
Top 500 Contributor
Joined on 07-12-2006
Plymouth, MI
Posts 1,606
Are you planning on dancing around on the table top?  I know O gauge die cast is heavier than HO but 3/4" plywood?  OSB is less expensive than plywood but the material is often harder on tools (saw blades/drill bits) as is MDF.  Homasote and most sound deadening material has little or no structural strength.  It works well for isolating vibrations (aka sounds) but needs to be installed on top of something else that has structural strength.
07-27-2008 6:44 PM In reply to
Offline ogauge
Not Ranked
W.Lafayette, IN
Posts 406
Even with homosote on it, half inch plywood seems to vibrate quite a bit.  My only reason for the 3/4"osb is that is is more dense and should vibrate less, than the 1/2" plywood.
07-27-2008 11:27 PM In reply to
Offline ChiefEagles
Top 10 Contributor
Joined on 02-03-2004
Rolesville, NC
Posts 10,545
Check on Soundstop by Celetex.  Not the cheap stuff.  This is just like Homasote but is wood fibers.  Usually cheaper but does the same thing.  Down South, Homasote is real expensive and has to be special ordered.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
