Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Need help with wiring rotary audio switch
  • Member since
    January 2007
  • 180 posts
Posted by Otis on Sunday, June 1, 2008 12:43 PM
Here I go again with puzzles re: my stationary decoder sound experiment.
I have gone to rotary switches to isolate the DSX decoders and audio transformers from one another instead of using parallel terminal strips. But in my limited way, I did not puzzle out a correct solution.
This diagram shows the wiring.  But of course, the transformers make a complete circuit from each side....that is, instead of being isolated, both Points A have continuity, both B etc.
If it was not a transformer being connected, the Points A, B, C etc would not have a common connection.
Did I use the wrong rotary switch?  Or will I have to put in two completely separate rotary switches?
(BTW, everything works very well when I connect each audio circuit independently.  I just want the conveniece of a switch instead needing to have 6 separate jacks and physically switching them as needed.)
Thanks for any feedback.
  • Member since
    April 2004
  • 318 posts
Posted by lonewoof on Sunday, June 1, 2008 2:07 PM
So, do you have a problem with the way it is wired?
Looks to me like that should work OK. You could have connected ALL the BLACK transformer leads together, and to the BLACK output; then you'd only have to switch the RED leads. Only need a ONE-pole 4 (or 6) position switch.
/Lone
Remember: In South Carolina, North is southeast of Due West... HIOAg /Bill
  • Member since
    January 2007
  • 180 posts
Posted by Otis on Sunday, June 1, 2008 2:50 PM
Thanks.
Well, I may have traced back the problem.  I have a faulty audio plug.  No outward sign of a problem, but looses contact when it flexes with insertion of male jack.  Duh! Banged Head [banghead]
  • Member since
    February 2008
  • 419 posts
Posted by UpNorth on Sunday, June 1, 2008 4:46 PM
Duh! Banged Head [banghead]   Don't you just love electronics...
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
