Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 05-16-2008 6:46 AM by HV Branch. 11 replies.
Rate:
Sort Posts:
Page 1 of 1 (12 items)
05-13-2008 9:37 AM
Offline HV Branch
Not Ranked
Joined on 12-11-2006
Ohio
Posts 22
Hocking Valley Rail Problems
I hate to bother you people again but I need some feed back. Running HO with Peco large radius turnouts,I built one end of a dog bone using 24 inch radius for the curves with two Peco turnouts coming off the mainline to make the loop. My 2-8-0's, 2-8-4's and the 4-8-2 all make it around the loop no problem. Then I got a 2-10-4 Texas and you quessed it, the T1 will not run the curve.If the front trucks make it into the curve the lead drivers lift up and over the rail. I have tried everything to make it work to no avail. I am thinking about tearing the loop out and relaying to a 26 inch curve but that would mean widening the bench work on that end, a large job. Broadway Imports say the T1 will handle 24" curves but mine doesn't. I am frustrated, I really like that Texas monster.
Thanks for the vent.
05-13-2008 9:44 AM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 9,982
Re: Hocking Valley Rail Problems
You may even have to go wider than 26" if your loco doesn't have blind drivers. Can you set up a temporary 26" loop to check it before you dive into modifying your bench work?
05-13-2008 9:51 AM In reply to
Offline ChrisNH
Not Ranked
Joined on 08-15-2006
New Hampshire
Posts 457
Is it possible that you ended up with a bit less then 24" during track laying?
If you do redo the section,  try putting in easements (if you have not already) to help guide the loco into the turn.
Good luck!
Chris
05-13-2008 9:54 AM In reply to
Offline 4merroad4man
Not Ranked
Joined on 07-13-2006
Austin, TX
Posts 415
Do your curves have easements?  If not, this can be the beginning of your problem.  Have you placed an NMRA gauge on the curve to check to see if it narrow?  The gauge should be exact or slightly wide.  Is your curve less than 24 inch by centerline?  Does the 2-10-4 have blind drivers?  If not, the wheelbase is too long, no matter what BLI says.
05-13-2008 10:02 AM In reply to
Not Ranked
Austin, TX
Posts 415
Just got on BLI's site.  This is a BlueLine locomotive, so check the wheel gauge with your NMRA gauge.  Also, the web page for this locomotive does not state it will handle a 24 inch radius curve in the specifications, though it does state that the locomotive will handle Code 100 through Code 70 rail.  Does your paperwork state the 24 inch radius commitment?  The web page DOES say however, that specifications will change without notice.  It does look as if the No. 3 driver is blind.
05-14-2008 6:46 AM In reply to
Offline HV Branch
Not Ranked
Ohio
Posts 22
Model RR did a product review sometime in 2004 on the BLI Pennsy J-1 stating it would handle 24" radius, about three pages before that review a BLI ad on the C&0 Texas T1 claims 24" minimum radius, so I bought it.It don't. The third driver is indeed a "blind driver"(no wheel flange). I joined two pieces of code 100 flex track at 26" radius hooked up an old power pack and bingo the T1 moved around that curve fine. I run all C&O steam, DCC w/sound and the idea of a major tear down to change the radius is terrible. I do not want to put a good looking, beautiful sound,$300.00 engine on a display track, or turn it into a planter. Sooooooo it looks like I should break out the tools and tear up the Old Town loop.
Thanks,
Ron
05-14-2008 9:22 AM In reply to
Offline loathar
Top 10 Contributor
Amish country Tenn.
Posts 9,982
In that case, I'd get out a track gauge and start checking my track work. I've had problem spots that were being caused by out of gauge track 3' away. Just run it slow and watch carefully where it starts to derail. Check your wheel gauge too.
05-14-2008 10:25 AM In reply to
Offline selector
Top 10 Contributor
Joined on 02-07-2005
Vancouver Island, BC
Posts 14,888
With the obvious differences as advertised, the Blueline T-1 is identical to the Paragon T-1.  In that respect, BLI announced that its engines of that type were good for 24" minimums.  Model Railroader Mag claimed that it is actually better than that and good down to 22".  I agree because I could barely make my PRR J1 work on my non-eased 22" radius EZ-Track.  24" is entirely satisfactory for these engines.
HV, you are experiencing what every modeller experiences when he introduces a much larger steamer to his trackwork.  I was no exeception, and neither are you it seems.  Every such engine, starting with my first 4-6-6-4, then my first 4-8-4, followed by the 2-10-4, and my last headbanger was the T1 Duplex 4-4-4-4 from BLI.  Without exception I had to tweak parts of my trackwork.  Usually that meant getting what amounted to kinks at joins smoother, or making sure rails were matched at nearly the same level along curves, and so on.
As loathar has guessed, you will probably find that this engine will behave once it makes you jump through some hoops.  If that means a substantial re-do of your loop, well...what else is there? Big Smile [:D]
You are now officially in "the club." Cool [8D]
-Crandell
05-15-2008 6:34 AM In reply to
Offline HV Branch
Not Ranked
Ohio
Posts 22
Thanks for the comments. I guess I am looking for the easy way out of this, I dread tearing up track and road bed,then adding to the width of the bench work to go to 26". Let me explain this. My bench work is  24 inches wide heading north. On the right hand side (East) the main line goes straight and makes a left turn (West) into a stub end,six track yard.
The left hand side (West), also running north takes a 24" curve to the left runs through an 8 inch straight section and curves back to the right also a 24" curve then runs straight north into the same yard into a turning Wye some 50 inches west of the first track. That T1 handles those two 24" curves OK.
The problem comes in when I decided to put in the Dog Bone loop to allow continuous running. I bought two Peco large radius turnouts and placed them on each side of the layout intending to join them with a 24" curve to make the loop. The T1 Texas will not run through the diverging leg of either turnout into a 24 " curve.
05-15-2008 7:02 AM In reply to
Offline Don Z
Top 200 Contributor
Joined on 08-24-2005
Austin, TX
Posts 1,793
Not being an expert on Peco turnouts, my answer may be incorrect. I looked at the turnouts on Walther's web page and if I understand you correctly, you are using a turnout that has a 60" radius diverging leg. You are then attaching flex track to the turnout that is shaped to a 24" radius. If you didn't build a transition easement into that 24" radius, you have created a kink in the curvature of the rails that I would think could be trouble for just about any locomotive that would travel through the turnout. Perhaps reworking just the area of track closest to the turnout will fix the issue. Put your head down as close to the track as possible and follow the curve of the rail with your eye. Is it a smooth, constant curve or do you see a sharp transition point where the radii change? If you see a sudden change, I'd bet that is where your problem lies.
Don Z.
05-15-2008 12:09 PM In reply to
Offline selector
Top 10 Contributor
Posts 14,888
Good point, Don.  Even more, if the Peco turnout is not the Streamline N. American style, but is a British curved diverging route of the older Peco style, it will be the same problem.  Either way, I am betting there is either uneven rail heights that encourages a wallow someplace or there is a short 2-4" section where the actual radius is nearer to 21"-23".
05-16-2008 6:46 AM In reply to
Offline HV Branch
Not Ranked
Ohio
Posts 22
Well gentlemen I think we got it. I found a Peco medium radius turnout in my stash and put it down on the east side of the dog bone and after loosening up the rail on the diverging leg, that T1 took the 24" curve without a wobble. So I just got off line from Walthers and ordered another medium turnout for the west side of the dogbone,plus a track gauge just to be sure.Oh yeah my Government bribe check showed up yesterday, can you say "Twin T-1 Texas".
Thanks,
Ron
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
