Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 03-03-2008 7:33 PM by Brutus. 15 replies.
Rate:
Sort Posts:
Page 1 of 2 (16 items) 1 2 Next >
02-29-2008 5:04 PM
Offline FJ and G
Top 50 Contributor
Joined on 08-04-2003
Posts 6,483
Fairly radical Williams Bash
Here’s my 7/8” scale critter on O gauge track just finished building using a Williams floor and motor (floor was chopped several inches) and a Lionel truck for the front). The lights are on front and back using a separate circuit but since daylight, hard to see. Entire body and trucks are made with thick gauge steel. It was a bear to work with but adds a lot of weight and character
components inside critter and first testing prior to doing body work and detailing:
http://www.youtube.com/watch?v=Pcu4zC4Xo3k
02-29-2008 8:57 PM In reply to
Offline crip
Not Ranked
Joined on 08-21-2005
Spring Lake,Michigan
Posts 177
Re: Fairly radical Williams Bash
In this age of prebuilt,moneys no object trains and structures(I'm guilty myself) it is refreshing to see your
scratch/home built trains. Keep up the good work!
Mark
02-29-2008 10:10 PM In reply to
Offline Brutus
Top 75 Contributor
Joined on 12-04-2004
St. Louis, MO
Posts 3,805
Excelent job, David!
02-29-2008 10:23 PM In reply to
Offline rogruth
Not Ranked
Joined on 01-09-2001
US
Posts 274
It really looks like something that could be found on  an industrial railroad.
Nice work.
03-01-2008 5:02 AM In reply to
Offline kpolak
Top 150 Contributor
Joined on 03-06-2006
Ann Arbor, Michigan
Posts 2,338
Another winner!
I was thinking of you a while back...Trains did an article on transporting molton steel and slag in Gary, IN.
How's the book comming?
Kurt
03-01-2008 6:33 AM In reply to
Online dwiemer
Top 75 Contributor
Joined on 03-15-2005
Southwest Georgia
Posts 4,046
Dave, I think you must have the most fun out of anyone letting your mind go and coming up with these great ideas.  A great project and I look forward to seeing more.
dennis
03-01-2008 6:56 AM In reply to
Offline trigtrax
Not Ranked
Joined on 05-24-2005
Posts 384
That is cool! Now since I work with Steel myself I have a million questions
What do you cut with?
How did you emboss the cab sides?
Do you solder or weld your parts together?
What gauge steel did you use?
Keep it up.. This hobby needs more tinkerers.
03-01-2008 7:56 AM In reply to
Offline FJ and G
Top 50 Contributor
Posts 6,483
Thanks, all. I took a break from the book to do this but beginning today, back to writing. Hard to be torn between hobbies with so little time to do any!
I don't know the gauge steel but it is a bit thicker than strap iron, used in the construction industry. I used a dremel cutoff wheel to go thru the steel. It took a lot of wheels and a lot of grinding and filing the resultant rough edges. I tried my hand at soldering the steel with a propane torch but it didn't work too well for me. Perhaps the wrong flux and solder. I ended up using three types of epoxies: 24 hour, 5 minute and the putty type. Then filing and grinding and sanding the resulting mess. Soldering would have been the way to go, however. That and mechanical fasteners, using mini bolts. But didn't want to do a lot of drilling and stuff. But had I more time, it would have been the way to go, I'm sure. For bending, I used pliers, duckbill pliers and a hammer and a piece of 1:1 rail. Bending was the most frustrating part, esp. where there are multiple inward bends, the tools get in the way. That and the bend sometimes isn't where you want it and curves in the wrong way or isn't a clean curve. I used a lot of metal and rework and it still isn't right. Rivets made with a heavy duty center punch and sledge hammer.
I'm sure I used all of the wrong techniques and working with steel is pretty frustrating, but OTOH, it was an enjoyable learning experience. I did the who thing in probably 25-30 hours. I realize that to really do a more professional job I'd need several times that time.
03-01-2008 10:43 AM In reply to
Offline 1688torpedo
Top 200 Contributor
Joined on 10-21-2004
15 mi east of Cleveland
Posts 2,085
Hello Dave!
Nice kitbashing job there. If you install a Plow on front you'll have something to clear the Snow from your Driveway.Wink [;)]Wink [;)]Clown [:o)] Maybe Bob K can do a performance review with it as I'm sure Wisconsin has plenty of snow to deal with. Superb Job. Take Care.Wink [;)]Smile [:)]
03-01-2008 8:34 PM In reply to
Offline wrmcclellan
Top 150 Contributor
Joined on 07-22-2003
North Texas
Posts 2,911
Dave - very cool!
03-01-2008 9:46 PM In reply to
Offline trigtrax
Not Ranked
Posts 384
Don't sell yourself short. Anybody can buy or build a model of a train by bashing a plastic kit. You created a unique piece of folk art there. I really like it!!
03-02-2008 9:10 PM In reply to
Offline jefelectric
Top 150 Contributor
Joined on 12-06-2003
Central PA
Posts 2,322
David,
Very nice little engine.  I neve tried anything like that so I am not the one to give advice, but on  your next project with steel/iron try using acid flux and a really heavy iron heated with a gas/propane flame.  That is what all the old tin workers used to use.  I've watched them solder some pretty heavy stuff that way, notice I said watched as I never tried it.  Brass and copper is all I have ever done.
03-03-2008 12:47 AM In reply to
Offline dbaker48
Top 150 Contributor
Joined on 12-20-2005
Sunny So. Cal.
Posts 2,567
David -- ANOTHER fantastic job !!!!   I MISS  BB !!!!!!
03-03-2008 5:15 AM In reply to
Offline trainbrain
Not Ranked
Joined on 07-14-2006
Southern NH
Posts 229
Nice job.  Must be nice to have NO snow in the yard!
03-03-2008 7:46 AM In reply to
Offline FJ and G
Top 50 Contributor
Posts 6,483
Thanks for tip, John.
Here's 2 more photos plus recent video of BB hunting
http://www.youtube.com/watch?v=WN93tJW_nV4
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
