Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 03-02-2008 1:46 PM by lionel2. 19 replies.
Rate:
Sort Posts:
Page 2 of 2 (20 items) < Previous 1 2
03-01-2008 10:58 PM In reply to
Offline lionel2
Top 500 Contributor
Joined on 01-26-2007
Posts 780
Re: Fixing my Standard Gauge 390E!!
Will this little switch hurt the value of my 10E???  Yes, it indeed does put the engine in neutral and cuts all power routed to the motor, its like a little silver switch with a rounded top of lever.  Because on the bottom of the frame there are little holes as if these switches just screw down onto those holes, like they were meant to be added onto the frame, as an addition of soome sort.  thanks.
03-02-2008 8:22 AM In reply to
Offline brwebster
Not Ranked
Joined on 07-09-2005
Gormley, Ont., Canada
Posts 628
I doubt it hurts the value much if at all, just as long as the installation wasn't a butcher job.  The value is really dependant on it's condition, it's color and it's running gear type.  To the operator this added kill switch would be benefitial, especially with more than one E-unit controlled engine on the layout at the same time.  I can only assume but your factory looking kill switch ( sounds like you are discribing a toggle switch) could be mounted on the frame where a manual reverse switch would normally go.  I think all # 10 frames were stamped to accept this, no matter if the engine was E equiped or not.
Bruce Webster
03-02-2008 9:55 AM In reply to
Offline lionel2
Top 500 Contributor
Posts 780
Yes, Its a toggle switch.  But, is it okay for a steam loco to have one of these toggle switches right on top of the boiler?? pretruding through the boiler.  Is this a normal add-on to steam locos?? thanks.
03-02-2008 1:41 PM In reply to
Offline 1688torpedo
Top 200 Contributor
Joined on 10-21-2004
15 mi east of Cleveland
Posts 2,079
Hello Lionel2!
The Toggle Switch sounds like a Home-made Job as Lionel never used them to reverse engines. The Lever should be flat, not round. Toggle Switches are not a normal add on anyway although some have used them in their engines for reversing anyhow. Take Care.
03-02-2008 1:46 PM In reply to
Offline lionel2
Top 500 Contributor
Posts 780
Well, My 10E has a 3 position e-unit in it.  because when i throttle down it will change to neutral throttle up its in reverse, throttle down its in neutral and so forth.  I took it apart and found that it does indeed have an e-unit in it.  and this toggle switch does not reverse the 10E, it only cuts power to motor like an on/off switch.  I believe the power wire from pickup is wired to this toggle then to the e-unit.  when i flip the switch the loco remains in place and does not move but the lights do light up, but no movement, like its in neutral or no power to motor.  thanks.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
