General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 09-05-2008 10:58 PM by Heartland Division CB&Q. 46 replies.
Rate:
Sort Posts:
Page 1 of 4 (47 items) 1 2 3 4 Next >
02-24-2008 8:59 AM
Offline Heartland Division CB&Q
Top 150 Contributor
Joined on 01-25-2007
Kentucky
Posts 2,712
A method to make rock strata
Here's a brief description of how I make rock strata. There are other ways to make rock strata, but this method works best for me.
I will be typing directly into the forum now. If you will bear with me while I do that, I will appreciate it.
First here's a couple of completed locations that include scenic details. I sometimes include some stone retailing walls in a scene to add variety.
NEXT >>>>>> "Before and after"
02-24-2008 9:02 AM In reply to
Offline bogp40
Top 150 Contributor
Joined on 07-28-2004
Weymouth, Ma.
Posts 2,817
Re: A method to make rock strata
GARRY, Like the look of the retaining wall blended into the rock. Is that a casting or scored/ carved?
02-24-2008 9:03 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
BEFORE:
In this location, the lower line is descending from left to right. Meanwhile, there's the mainline ascending from left to right. Above it is the end of a branch line that enters the scene from the right.
02-24-2008 9:05 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
Hello Bob k..  good to hear from you. I'm explaining as I go.
02-24-2008 9:08 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
AFTER:
Here's the completed rock strata. The scene is not totally done becuase I should add more scenic materials and some details.
>>>>>>>> NEXT ..... stuff you need.
02-24-2008 9:12 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
You need the following material:
Plaster of Paris, construction adhesive, lightweight spackling compound, spray bottle with water and dish detergent, artist acrylic paints.
You need the following tools:
Calk gun (adhesive), flat pan (cheap, disposable, aluminum broiler pan), utility knife, common putty knife, small wire brush, single edge razor (in wallpaper hanger tool that hold blade)
02-24-2008 9:19 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
STEP ONE:
Mix plaster making it more watery than normal and pour into pan to about 1/4" thickness. The thickness can be varyable to some extent because it will make final result more realistic.
Break plaster into pieces.
The pieces in the bucket are to be broken into smaller pieces when the are installed.
02-24-2008 9:30 AM In reply to
Offline pcarrell
Top 25 Contributor
Joined on 02-17-2005
In the State of insanity!
Posts 7,976
Gerry, this looks like something even I could do!  I think I know where you're going with this, but I'm looking forward to more.....especially the retaining walls and the transitions.  Those are quite noteworthy!
Top 150 Contributor
Kentucky
Posts 2,712
Next step is to install broken plaster pieces using construction adhesive. Each plaster piece should be broken to an appropriate size.  Try to select pieces that fit together closely. You do not want perfection, however, as you fit pieces together. It will look better for some rocks to protrude more than others. I will take care of gaps between pieces in the next step.
If a pieces has lumps on top or bottom surfaces, srape them off. Use plenty of adhesive by try to keep it from oozing to the visable face of the strata.
The blue foam board is optional, but it will make the strata more sturdy if you place it behind the palster pieces and use adhesive to hold the plaster pieces to it.
02-24-2008 9:31 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
Hello Philip.  It's good to hear from you as well.
02-24-2008 9:39 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
I should have mentioned earlier to protect trackwork as needed with plywood or other suitable material.
Now, it's time for gooey hands.
The cracks need to be filled. I've tried using plaster for this part, but lighweight spackling compound works better. Spray the rocks with a solution of water and dish detergent. Only use a tiny amount of detergent because you do not want bubbles all over the place.
Then, get a handful of spackling compound and work it into the cracks. Spray more detergent water onto the surfaces as needed. Try to get all of the spackling compound into the cracks.
NEXT: BEGIN COLORING.
02-24-2008 9:48 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
Here's why I prefer plaster over other materials such as broken ceiling tiles. The plaster can be made to have more realistic colors.
It's important to remember to use only watered down colors. You need a very thin mix. Each layer of color will make only a small change in the color of the surface. It will take many layers of different colors. Each layer must be completely dry before another layer is applied.
Important. Remember ........... Very thin coats.  Dry completely before next color is applied.
My choice for the first color may surprise some of you. I will post the picture next.
02-24-2008 9:54 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
Before painting cut out some of the adhesive that oozed out. If some still remains, however, don't worry. You will not see it later on.
The first color is YELLOW. Trust me. I know it looks like the family pet had some sort of an accident, but use yellow on the first coat anyhow.
Some of the yellow is too dark. After it's dry, I lightly brush the part that's too dark with a wire brush using only horizontal strokes.
02-24-2008 10:01 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
After the yellow is completely dry, mix a small amount of raw siena color with water. Each color will have a few drops of acrylic mixed with about 4 oz. of water.
As with the yellow paint, a use a one inch paint brush to quickly spread the color on all exposed surfaces. Work the color into each of the crevices.
02-24-2008 10:11 AM In reply to
Top 150 Contributor
Kentucky
Posts 2,712
After the raw siena is dry, you can start to see how the surfaces may appear at the end of the process.
There may be areas where it will look better if there are more crevices. You can add crevices with a putty knife. Use a board to keep the putty knife horizontal. Press a corner of the knife into the dry plaster and pull the knife backward along the board. Repeat until the groove looks deep enough. The length of each groove should be variable Perhaps, 2 oto 4 inches is about right. Then use the knife to chisel out small random chunks of plaster either above or below each of the grooves.
Then use a wire brush horizontally to remove extra acrylic colors as needed.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
