General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 02-22-2008 8:37 PM by reklein. 24 replies.
Rate:
Sort Posts:
Page 1 of 2 (25 items) 1 2 Next >
02-20-2008 10:16 AM
Offline Dave Vollmer
Top 150 Contributor
Joined on 11-26-2003
Bellevue, NE
Posts 2,718
Tricks to make a tiny layout look bigger...
One of the most common comments I get from people who visit my website is that they are surprised to learn that my layout is only 36 by 80 inches.  They say they can't tell that just from the photographs.  I take that as a compliment, because I generally photograph the layout in such a way as to disguise the small size.
But I have to come clean...  The only reason I can get away with making such an obviously tiny layout (the table is simply a hollow-core interior door mounted on folding legs) look larger is because I used tried-and-true techniques for making it look bigger.  None of these techniques are my own; they were discovered by other modelers just like yourselves.
My layout is very heavily based (that is to say probably 80-90%) on Lou Sassi's Mohawk Division project layout in the December 1993 Model Railroader.  It's a tribute to Lou Sassi's genius (not mine) that the layout incorporates so many tricks essential to making the small look big.  It also shows that a plan made for 70's Conrail in NY is useable for a 50's PRR in PA!
1.  Scenic divider:  This is a big one for roundy-round table layouts like mine.  Most MR project layouts use one, and they range from the low ridge of trees on the N scale Carolina Central to a no-kidding backdrop down the middle like on the HO Alkali Central.  Lou Sassi's plan for the Mohawk Division used the town and a low ridge to divide the layout in half and make the loopy-nature of the layout less obvious.  I ended up making the low ridge much higher to hide a coal mine, but it serves the same purpose.  The layout is effectively split in half, making both sides appear farther apart.
2.  Scenery above and below track-level:  Any time you can add some vertical elements to an otherwise horizontal endeavor, you can make it appear bigger.  Lou's plan includes two scenes that go below track level; both involve roads undercutting the railroad, with one also including a sizeable stream.  I kept both scenic elements, but swapped out Lou's very neat-looking steel bridge for a signature Pennsy stone arch bridge.
3.  Scenic boundaries:  Lou's plan effectively uses roads to divide scenes, even on the same side of the layout.  Again, I kept these elements in my incarnation of the plan because they worked so well in his.  US Route 522 follows the scenic divider down the middle on my plan, and PA Route 45 ducks under the Jack's Run Bridge, separating East Mifflin from Jack's Run on the more scenic side of the layout.  Areas of trees and low brush, typical of Central Pennsylvania, are also used to further sub-divide scenes.
4.  Perspective:  I have many free-standing trees on my layout, but the mountains are covered with a forest canopy made from an assortment of Woodland Scenics Foliage Clusters, polyfiber balls, lichen, and Z-scale pines.  The size of the trees decreases slightly with elevation to give a bit of perspective.  Also, the ridge on my layout is too narrow to be realistic.  But the actual width can only be determined by looking at in from an angle which is rarely seen.  Usually it's viewed on the broad side, so the insufficient depth is not so obvious.
It was either John Olsen or Malcolm Furlow who suggested that he viewed his layout as a camera would.  So his scenes were made distinct from one another.  That philosophy has helped many a small layout (John Allen's first G&D comes to mind) look much bigger than it was.
Kudos to Lou Sassi also for his awsome design!
Here the scenic divider splits East Mifflin from the Berwind-White Eureka #43 Mine.
US522 divides the layout length-wise.
PA Route 45 divides Jack's Run from East Mifflin and M Interlocking (just out of sight to the right).
02-20-2008 11:12 AM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 10,017
Re: Tricks to make a tiny layout look bigger...
Attaboy Dave!
02-20-2008 11:14 AM In reply to
Top 150 Contributor
Bellevue, NE
Posts 2,718
 loathar wrote:
Attaboy Dave!
Smile,Wink, & Grin [swg]I get it...!  As the line from Airplane goes: "Irony can be pretty ironic sometimes!"
02-20-2008 12:12 PM In reply to
Offline BCSJ
Not Ranked
Joined on 03-27-2007
Posts 247
Dave has some good insights into making a small layout seem bigger. Here are a few more thoughts on the subject.
My first complete (well track work was completed) layout was a HO 4x8 twice around. By dividing up the railroad into a series of vignettes it seemed much bigger than it was (especially to a camera!)
* An absolutely flat trackplan will tend to seem smaller. I think my layout seemed bigger because the two laps of the twice around went up and down to different levels.
* There was a row of hills/mountains running down the length of the layout that separated it into a front side and back side.
Front side of the hills (hills on left)
Back side of hills (previous picture taken over the hills on the left)
Warning! If you put a view block down the center of the layout (hills or backdrop) you'll need to walk around the layout to see what's happening over there! Be sure the controls for electrically controlled turnouts (and electromagnet uncouplers) are on the same side you'll be on when running trains there (yep, been there, done that, rewired the controls...)
* Bridges can further divide a layout into separate scenes - left of bridge, right of bridge, and under the bridge.
* Tracks that are at different levels will seem to further away from each other. This is true even if the elevation difference is only an inch. John Allen used this in the Port area of his final G&D.
The bridges and mini-gulch break up this scene into three parts. The elevation difference between front and rear tracks created a further division of the scene making it appear that the two tracks were going very different places.
* Tunnels are big time scene separators. Track running through a cut is also a good scene separator.
* On a smaller layout, the amount of detailing that is feasible (in a given amount of modeling time) is much higher than on a large layout. The more detailed the scenes, the more time one's eyes spend on that scene effectively making each scene into their own vignette.
* Roads can provide separation of scenes on either side of them. They also lead the eye to places you want the eyes to be led. When they hit a corner the mind tends to think of the 'around the corner' as a different place. For example here are two pictures taken of the same corner but from different ends.
Looking at the corner one way
And looking at the same corner the opposite way
A grade crossing effectively divides a scene into 'before the x-ing' and 'after the x-ing' segments.
* A row of trees can be a good separator - field on one side, town of the other.
* Even a well placed fence can help create a mini-vignette.
I'm sure there are more tricks. Anyone else?
Regards,
Charlie Comstock
02-20-2008 12:15 PM In reply to
Offline SilverSpike
Top 150 Contributor
Joined on 08-11-2002
Wake Forest, NC
Posts 2,888
Thumbs Up [tup] Thumbs Up [tup] Great tips Dave!
I really appreciate learning how you have perfected the highlighted model railroading techniques and reading this short "how to" from your first hand research and knowledge is even better.
This is a perfect example of giving back to the hobby with a positive contribution.
You are on the right track now (pun intended)!
Thanks again,
Ryan
02-20-2008 12:31 PM In reply to
Top 150 Contributor
Bellevue, NE
Posts 2,718
Charlie,
Now that's what I'm talking about...!  I wouldn't have guessed 4x8.  Looks like a 5x10 at least.  Great job on taking advantage of the vertical!
Good call on cuts dividing scenes, too.
I have one as well:
This cut seperates East Mifflin from LEW Interlocking at the west end of Lewisport, PA, and hides the end of the narrow ridge that seperates the town.
The rocks, BTW (I know, off-topic) are Flexrock foam castings.  I never could get plaster castings to look right.  So, I took the easy-way out.  With a few layers and colors of paint, you can't tell they're foam.
02-20-2008 5:23 PM In reply to
Offline luvadj
Not Ranked
Joined on 08-31-2007
Lake Havasu City, AZ
Posts 555
I was one of those people who didn't believe that it was that small...great work Dave and a great tutorial as well...thanks.
02-20-2008 5:28 PM In reply to
Offline Vail and Southwestern RR
Top 200 Contributor
Joined on 07-12-2006
Vail, AZ
Posts 1,854
I read the title to this thread, without seeing Dave's name as the poster.  I though, Dave Vollmer would be the guy to talk about that!  Then, I saw, HE WAS!
02-20-2008 5:36 PM In reply to
Offline vsmith
Top 10 Contributor
Joined on 12-20-2001
Smoggy L.A.
Posts 9,328
John Allen discovered that by using large mirrors strategicly placed around the layout backdrop, he could use the reflections of other areas to make the layout seem infinitely larger.
02-20-2008 5:42 PM In reply to
Offline Big Ugly Waz
Not Ranked
Joined on 10-28-2007
Northern NSW, Australia
Posts 107
Hi Dave,
I know this is a bit off topic, but it's the second time today I have typed these questions for you, I started a while ago and got caught up with work and when I went to post the thread had been locked. ( not surprised )
How do you create the smoke in your photos ? Can you manipulate the smoke to get it to "lay down" across the top of the train or "push out" from the engine like there is a strong wind blowing ? Just curious as I think it enhances the sense of realism of your model steam photos, and it's something I want to play around with till I get the time to start building a proper layout in the garage.
Cheers, and thank's in advance,
Warren
02-20-2008 6:08 PM In reply to
Offline vsmith
Top 10 Contributor
Smoggy L.A.
Posts 9,328
 Big Ugly Waz wrote:
Hi Dave,
Warren
I'm not answering for Dave but it looks like a little digital magic with Photoshop, same as I did in my signature pic.
02-20-2008 6:26 PM In reply to
Offline andrechapelon
Top 150 Contributor
Joined on 09-01-2002
California & Maine
Posts 2,684
I was about to say that Dave was able to create the impression that his layout was larger because, like Sir Isaac Newton, he "stood on the shoulders of giants". It then occurred to me that if Dave actually did stand on the shoulders of giants, it would have the effect of making his layout seem smaller.
[12 step meeting]
Hi, my name is Andre and I have a warped sense of humor. It's been 3 days since I created my last pun, 2 days and 3 hours since I wrote a twisted limerick, 23 hours and 12 minutes since I told the joke that ended with a line about a frog in a blender and only 5 minutes since I quoted Marx. That's Groucho, not Karl.
I'd like to give myself over to a higher power, but unfortunately that higher power went by the name of William Claude Fields. I'm doomed.
[/12 step meeting]
Andre
02-20-2008 6:30 PM In reply to
Top 150 Contributor
Bellevue, NE
Posts 2,718
 Big Ugly Waz wrote:
Hi Dave,
Warren
Warren,
It's done with the airbrush tool in Paint Shop Pro 7.  You can manipulate the sharpness, transparency, and color as well as the size of the spray.
I don't think my smoke looks as good as it could if I cropped in real smoke, but it helps the steamers look less like plastic and more like the living, breathing steel creatures they represent.
02-20-2008 9:05 PM In reply to
Offline ICRR1964
Top 500 Contributor
Joined on 11-10-2005
Central Illinois
Posts 815
I have done this allot in the past Dave, and you are right. I never thought of it that way either. There is nothing nicer than seeing a loco come storming out along a tree line, it does make things seem bigger and more open. I don't mind making them either. I still do make all my own trees by hand, with bell wire, lichen and clay or a hot glue gun. Was telling steinjr about it a week ago. I have to figure out how to post a picture or two of one of my older layouts.
02-20-2008 9:57 PM In reply to
Offline New Haven I-5
Top 500 Contributor
Joined on 11-10-2007
Southern California
Posts 1,477
 Great work eveyone! That Dave, he can sure model like a pro Model Railroader!Big Smile [:D]
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
