General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 02-05-2008 9:01 AM by secondhandmodeler. 3 replies.
Rate:
Sort Posts:
Page 1 of 1 (4 items)
02-05-2008 8:22 AM
Offline Trainman11
Not Ranked
Joined on 01-12-2008
Posts 35
Styrofoam for benchwork
I am looking for some advice: I want to use some high dinesty Styrofoam for my benchwork top. I'll been looking at 4x8x3/4" Blueboard. I cannot find anything else where I live but 3/4 thichness. That should be strong enought and hold up good should it. I've been out of the hobby for several years, and getting back into it again. Would appreicate any advice.     Thanks David
02-05-2008 8:41 AM In reply to
Offline secondhandmodeler
Top 500 Contributor
Joined on 06-12-2007
Mankato MN
Posts 941
Re: Styrofoam for benchwork
Welcome to the forum.  If you are not going to put any sort of bracing(plywood) under the foam, I would double up the thickness.  This will give you more rigidity and also allow you to carve down into the foam to create below track contours.  To find out everything you need to know on this and other subjects, try the search function.  There are countless threads on this very subject.   I believe there are a few current ones in the 'Layout' section as we speak. Good luck!
02-05-2008 8:48 AM In reply to
Offline Trainman11
Not Ranked
Posts 35
Corey: I have 4x8x1/2 cdx plywood on the benchwork. I also have braces build on the legs as well
02-05-2008 9:01 AM In reply to
Top 500 Contributor
Mankato MN
Posts 941
You probably don't need to double up, unless you want to be able to carve deep depressions.  The 1.5" foam will work just fine.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
