Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 02-01-2008 10:08 PM by Markettimer. 4 replies.
Rate:
Sort Posts:
Page 1 of 1 (5 items)
01-31-2008 11:47 PM
Offline Markettimer
Not Ranked
Joined on 11-26-2006
Posts 11
Fastrack Accessory Wire Connectors
Hi and excuse me if this question has been asked and answered a thousand times.  I am looking for a source for the insulated female quick connectors that are used on Fastrack accessory and terminal wires.  I have been to several hardwares, Radio Shack, etc. and can't find any that are small enough.  I really don't want to buy them from Lionel if I can help it due to cost.  I believe they need to be compatible for 18 gauge wire.  Can anyone help?  Thanks!  Jim
02-01-2008 6:29 AM In reply to
Offline Roger Bielen
Top 200 Contributor
Joined on 07-23-2003
Watkinsville, GA
Posts 2,153
Re: Fastrack Accessory Wire Connectors
Forget the connectors and solder the wire to the tabs leaving about 12" of wire.  Then you can use a wire nut to attach longer wires.
02-01-2008 8:10 AM In reply to
Offline lmsjim
Not Ranked
Joined on 03-14-2005
Culpeper, VA
Posts 37
I agree with Roger solder them. I did find the small ones at Lowes and a lot cheaper than Radio Shack sells them but after having the come loose several times I went back and started solder them all. Much better solution and never had any problems since.
02-01-2008 8:11 AM In reply to
Offline bfskinner
Top 500 Contributor
Joined on 02-17-2007
Posts 890
Markettimer,
McMaster-Carr calls them Quick Disconnect Terminals, female, size .110 inch tab width, .20 inch tab thickness, in two wire sizes, 22-18 and 16-14 AWG. Look in their online catalog under "Lighting and Electrical." They also sell crimping tools and heat-shrink tubing -- see below.
You are right to insist on the correct size as there have been reports of overheating (scorching of carpet, etc.) caused by ones that were too loose. These are an exact fit for FasTrack.
These fit very tightly. I bought the uninsulated type and use heat-shrink tube insulation where necessary. Sold in bags of 10 or a 100. Very prompt shipping.
Soldering is good too, as long as you don't melt the nearby plastic, or get a "cold" solder joint trying to avoid it.
                            http://www.mcmaster.com/
02-01-2008 10:08 PM In reply to
Offline Markettimer
Not Ranked
Posts 11
I'll try that.  Thanks!  Jim
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
