Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 01-07-2008 9:17 PM by Rob94hawk. 6 replies.
Rate:
Sort Posts:
Page 1 of 1 (7 items)
01-06-2008 11:49 PM
Offline Rob94hawk
Not Ranked
Joined on 01-06-2008
Posts 3
Train store gives me an 8 pin MRC decoder for my 9 pin Athearn F59?!? Uh, now what?
I asked for a decoder with sound for my Athearn F59 Sounder which is supposed to be DCC ready so he gives me an 8 pin MRC #1626!! So much for plug and play! Is there an 9 to 8 pin adapter or am I going to have to solder this thing on somehow? Thanx
01-07-2008 11:55 AM In reply to
Offline ndbprr
Top 50 Contributor
Joined on 09-10-2002
Posts 4,897
Re: Train store gives me an 8 pin MRC decoder for my 9 pin Athearn F59?!? Uh, now what?
Sounds like one of three things happened:
1. He sold you the wrong one
2. He sold you what he had in stock to make the sale
3. He has no idea which is the right one.
Personally I would return it and probably start shopping elsewhere if it is 2 or 3
01-07-2008 3:17 PM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 5,684
Did you specify it was for an engine with a 9-pin set-up??
You should be able to find an eight-pin to nine-pin short adapting harness. However, if the decoder has a separate eight-pin harness (i.e. the eight pin is not an integral part of the decoder like a "plug and play" one) then the harness is probably an 8-pin on one end and 9-pin on the decoder end. If you remove the harness you may be able to plug the decoder in??
Otherwise you could use an adapter harness, but you might end up with a situation where you have a 9-pin decoder connected to a harness to convert it to 8-pin, connected to a harness to convert it back to 9-pin.
Smile [:)]
01-07-2008 6:33 PM In reply to
Offline Li'lJugs
Not Ranked
Joined on 01-13-2007
Posts 38
Umm,  could you maybe go back to the store and ask for the correct decoder?
Did you know you needed a 9 pin decoder when you left with the 8 pin?
01-07-2008 6:57 PM In reply to
Offline Rob94hawk
Not Ranked
Posts 3
I was holding the loco in my hand at the time because he had it in stock. I'll try to find an adapter if not I'll pay someone to install it in my UP DD40AX and buy the right one for the Athearn F59PHI.
01-07-2008 9:01 PM In reply to
Offline Tilden
Top 500 Contributor
Joined on 01-12-2004
Posts 780
Rob, don't think you will have much luck getting an adapter for the 8 pin.  I'm thinking your best bet would be to get a Digitrax harness, cut the 8 pin plugh off and solder the decoder wires to wires on the Digitrax harness.  MRC changed their 1650 decoder (to the 1651) so it would accomodate the 9 pin plug. (It comes with a harness that has an 8 pin plug).
I don't believe MRC makes a 9 pin sound decoder, or for that matter a sound decoder appropriate for an F59.
As for the DD40Ax conversion, is it a Spectrum DD40Ax?  I've converted one and can give you some tips/ideas if you'd like.
Tilden
01-07-2008 9:17 PM In reply to
Offline Rob94hawk
Not Ranked
Posts 3
Tilden
 Yes it's a Spectrum DD40. I'll take any advise you can give me. Thank you!
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
