You can get the manual turnouts either with the switch machine and no electronics (you probably want the #6)......
Standard line
& #6 (same as the electric one only no electronics)
or without the switch machine (if you want to slap a tortise on that puppy right away)......
Take note though, the "#6" & "custom line" turnouts and they are a bit finer in detail and are a larger # frog too (means a gentler curve....thats a good thing, though it does take a little more room).
