General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 10-02-2007 1:30 PM by Wisconsin Railfan. 132 replies.
Rate:
Sort Posts:
Page 8 of 9 (133 items) « First ... < Previous 5 6 7 8 9 Next >
10-01-2007 8:25 PM In reply to
Offline TrainManTy
Top 75 Contributor
Joined on 12-11-2006
Central Massachusetts
Posts 3,674
Re: Weekend Photo Fun 9-28-2007 Thru 9-30-2007
Lookin' good!Thumbs Up [tup]
10-01-2007 9:03 PM In reply to
Online jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,313
I devised a way to get rid of the heat developed by the motor and decoder. I took the dynamic brake housing off the shell and used my Dremel tool to open up the top of the shell. I then cut the grills out of the sides of the dynamic brake housing. Now the top of the shell doesn't heat up after the loco has been running for a while.
10-01-2007 9:41 PM In reply to
Offline Don Z
Top 500 Contributor
Joined on 08-24-2005
Austin, TX
Posts 1,815
Wouldn't it look much better if you cut out the dynamic brake fan and replaced it with a Cannon & Co. fan ( http://www.walthers.com/exec/productinfo/191-1851 ) with the see through grid that would allow the heat to rise out of the hood instead of ripping a hole in the side of the hood?
Don Z.
10-01-2007 10:12 PM In reply to
Top 10 Contributor
Sundown, Louisiana
Posts 13,313
I can't use what I don't have.
10-01-2007 10:15 PM In reply to
Offline Mark R.
Top 500 Contributor
Joined on 04-25-2004
Posts 906
Naw - THIS oughta make her breathe better !!! ....
Mark.
10-01-2007 10:20 PM In reply to
Top 10 Contributor
Sundown, Louisiana
Posts 13,313
Sheesh, why didn't I think of that.Laugh [(-D]
10-01-2007 10:46 PM In reply to
Offline CMSTPP
Top 500 Contributor
Joined on 08-21-2005
Along the old Milwaukee Road.
Posts 1,157
Well, it seems that things are looking good here. I am enjoying looking over the last few pics here..Wink [;)]
Anyway, I have been busy weathering up my locomotives.
U25B #5058 gets the treatment. This is nowhere compared to how the real thing looked and believe me, I will not be going there. I just need to finish the trucks and then it will be dine. Just enough to give the idea.
U28B #132 also gets the treatments. This locomotive looks pretty good. Actually looks like it has been working and rightfully so. These locomotives deal with some pretty serious grades and heavy trains.
This is my new GP40. I picked this one up for my B-day a couple of days ago. I am going to give it some treatment but not as much. It's a "newer" locomotive in the Milwaukee Roads eyes.
Sorry if the pics are a little blurry. I took them tonight and was a getting a little tired.
Happy railroadingLaugh [(-D]
James
10-01-2007 10:58 PM In reply to
Offline UP2CSX
Not Ranked
Joined on 06-20-2007
Prattville AL
Posts 741
Mark,
Now that's funny. Kind of a drag racing SD45.Big Smile [:D] Jeff, if you need to do something like this again, use your Dremel tool to drill a series of holes in the fan grilles and then use an exacto knoife to open them up. You'll get more cooling and it won't even be noticeable if you do it right.
10-02-2007 1:43 AM In reply to
Offline Southwest Chief
Top 500 Contributor
Joined on 12-09-2003
Anaheim CA/Bayfield CO
Posts 892
I was really busy this weekend working on my Santa Fe #3482 dorm kitbash:
For more information see this thread (page 3 has more photos of this kitbash):
3482 Kitbash
10-02-2007 4:39 AM In reply to
Offline jktrains
Top 500 Contributor
Joined on 10-13-2006
Northeast OH
Posts 903
http://i136.photobucket.com/albums/q186/forum-1/P1010001-4.jpg[/IMG]
http://i136.photobucket.com/albums/q186/forum-1/P1010002-2.jpg[/IMG]
http://i136.photobucket.com/albums/q186/forum-1/P1010005-2.jpg[/IMG]
http://i136.photobucket.com/albums/q186/forum-1/P1010003-4.jpg[/IMG]
Jeff - Listen to DonZ.  You've now taken a perfectly good shell/loco and ruined it.  Cannon fans would have been a good solution and improved the appearance of the loco. You solution has done the opposite.  You might as well have just drilled a bunch of holes in the roof and sides.
Everyone else - don't listen to Jeff!  This is NOT what you should do to your loco if heat is an issue.
There should not be that much heat being generated from either the loco or the decoder.  If there is, then your done something wrong.  If it is from a resistor used for lights, then you've used the wrong watt resistor.  If the motor gets that hot then there is probably something binding or rubbing.  Decoders are designed to handle a certain load and generate a minimum of heat.  It should never be enough to melt plastic or require surgery to a shell to dissipate it.
10-02-2007 7:31 AM In reply to
Offline spectratone
Not Ranked
Joined on 10-27-2005
California City
Posts 208
Wouldn,t upswept Zoomies work better than downswept headers? And a large scoop instead of velocity stacks? I think We,re almost there. I like the chrome.Thumbs Up [tup]
Mark.
10-02-2007 8:20 AM In reply to
Top 10 Contributor
Sundown, Louisiana
Posts 13,313
Look, it's my equipment and I'll do with it as I please. You don't want me chopping on it, then buy it. I'm not going to waste time wishing for detail parts that I can't get with money I don't have. Some like to dress their locos up, others, such as myself, take a more utilitarian approach. The only visible damage is to the dynamic brake housing, which is easily replaceable. And yes, the cheap Bachmann decoders run hot and will burn up if the heat is not vented away. I can easily replace the brake housing once I get a cooler running decoder. I cannot however fix a bunch of holes in the body. I am not an idiot so quit trying to make me look like one with your remarks. I didn't tell anybody that my approach to the heat problem I was having is the one they should use, I simply said it's the one that I used in this case. If they want to do the same, that's up to them, not you. You have no right to tell me what I can and can't do with my equipment. You don't like what I'm doing to it? That's fine. I know what I'm doing, that's why the only visible area that's damaged is a small easily replaceable part.
10-02-2007 8:52 AM In reply to
Offline cf-7
Not Ranked
Joined on 05-14-2006
Posts 36
That's what I like about this thread every week; there is something for everyone.  Always great photos and also a little humor too.  Great stuff!
10-02-2007 8:55 AM In reply to
Offline Mark R.
Top 500 Contributor
Posts 906
Jeff - Allow me to offer a little constructive critism. You, my friend, are you own worst enemy. Take a moment before you post your pictures and ask yourself - "would folks really like to see this ?"  Sure, your method of creating an "exhaust" for your heating problem probably does help somewhat, but you admit yourself it wasn't the best approach. Same goes for your masking tape installation. Instead of posting pictures of everything you do, hold off until the project is done properly and worthy of sharing, otherwise it's nothing more than an invitation to comments like you've been getting.
Remember as well how much trouble you had taking pictures with your $10 special. We understand your financial situation and that everyone likes to share their work here and we accepted your poor quality pics for what they were. The problem wasn't the bad pictures - everyone is entitled to participate - but even the high quality posters don't post every picture they take. The endless strings of bad pics were just an invitation to critism for a while there.
I won't post any pics unless the project is complete and worthy of sharing. Take a good look at what you're about to post and judge your own reaction on what others might think .... don't like the negative comments ? - don't provide reason for them.
Mark.
10-02-2007 9:29 AM In reply to
Offline Driline
Top 200 Contributor
Joined on 07-04-2006
Bettendorf Iowa
Posts 2,043
http://i13.photobucket.com/albums/a276/cmstpp/rail/Model%20RR/random080.jpg
http://i13.photobucket.com/albums/a276/cmstpp/rail/Model%20RR/random078.jpg
http://i13.photobucket.com/albums/a276/cmstpp/rail/Model%20RR/random079.jpgThis is my new GP40. I picked this one up for my B-day a couple of days ago. I am going to give it some treatment but not as much. It's a "newer" locomotive in the Milwaukee Roads eyes.
James
James those are some great looking locomotives you have there. I've always had a soft spot for the Milwaukee Road Orange and Black scheme. I used to watch the trains run here locally until they stopped in 1978? (Eastern Iowa, Western Illinois area). Here's a pic of my unit. Is that N scale or HO you are using?
And here's the real deal, albeit a GP38-2 instead of an SD40, but what the heck....
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
