Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 04-10-2009 7:46 AM by jalajoie. 72 replies.
Rate:
Sort Posts:
Page 1 of 5 (73 items) 1 2 3 4 5 Next >
09-02-2007 10:57 AM
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,074
Tutorial: Using Decoder Pro WITHOUT a connection to your layout. PHOTO-INTENSIVE
Here is a quick tutorial on how to use Decoder Pro WITHOUT a connection to your layout.
1.  You need to download the latest version of Java
http://www.java.com/en/
2.  After installing java, you will need to download Decoder Pro
http://jmri.sourceforge.net/download/
After downloading, install and you will see 2 icons appear on your desktop.
Decoder Pro is for programming your decoders and Panel Pro is for operating your switches (wont be covered in this Tutorial).
Double click on the Decoder Pro Icon and then a preference dialogue will appear.
If this dialogue doesnt appear, click on EDIT and then PREFERENCES.  That will bring you to the connection dialogue.
From the LAYOUT CONNECTION drop box, scroll down to LOCONET SIMULATOR.  Click on Save.  Decoder Pro will now restart.
When DP has restarted, click on Service Mode Programming (we wont bother with Operation mode as this is the mode you use when you have a connection to your layout).
When you click on Service Mode Programming, you will notice a drop down list of pretty much every decoder ever produced.  To select your decoder, click on the MFG, then choose from the daughter lists.  In this case, we are looking for a BLI RSD15 decoder.  We need to know that the decoder is produced by QSI and that the version number of the decoder is 7.
Before we can see our decoder, we need to select 'COMPREHENSIVE" from the programmer format.  This will show us all the decoder options.
Once that is selected, click on "OPEN PROGRAMMER".
You should then see this screen:
Notice the different tabs up top and such.  They have grouped the different aspects of the decoder into easy to navigate pages.
Now, the reason for this tutorial.  We want to make changes to the decoder and we would like to know which CVs we need to change in order to program our locos through our DCC system.
Your first step is to wipe the slate clean.  To do this, click on "WRITE ALL SHEETS".
You will notice that everthing that was yellow is now window's grey.
Now we can make changes and when we do, the box that we have changed will turn Orange.  For example, lets set this decoder to have an address of 1365 with no analogue conversion and with normal operating direction.  Notice how the boxes all have changed color....this is important.
Note that all the boxes will change color if you fill in a box that effects them.  By filling in a 4 digit address, we have changed CVs 17, 18 and 29.
Now that we have color change, we would like to know which CVs we want to adjust to achieve our changes.
On the top tabs, you will see a CV tab.  This tab lists all the 'RAW' CVs for this loco.  Click on this tab.
The CV page will then show up.
When we scroll down, we can see which CVs we need to change as they are also in Orange.
Thats it!  Now, if you want to change any other options in your locomotive, just click on 'WRITE ALL SHEETS' and start over.
Have fun and I hope this helps.
David B
09-02-2007 11:31 AM In reply to
Offline tstage
Top 10 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,684
Re: Using Decoder Pro as a tool. The DCCer's best tool.
Good stuff, David! Thumbs Up [tup]  Even though I don't have an extra computer (or port...yet) to hook one up to my DCC system, I am looking forward to that aspect in the future at some point.  This thread will be helpful for when that time does come.
Thanks for the effort in putting this tutorial together. Smile [:)]  We need more of these sorts of threads.
09-02-2007 11:36 AM In reply to
Offline C&O Fan
Top 200 Contributor
Joined on 10-20-2006
Texas
Posts 1,938
Very Nice of you David to do a Tutorial on DP
I use it and love it ! Sure saves punching all those numbers by hand and the support from the
users group at http://groups.yahoo.com/group/jmriusers/
Is first class! Great bunch of Guys !
09-02-2007 11:50 AM In reply to
Offline ShadowNix
Top 500 Contributor
Joined on 08-01-2005
Tacoma, WA
Posts 854
Sweet, so basically, Dave, you use this tool as a way to know what CV's to punch down in the basement (or wherever) where your programming track is, correct?  That is a GREAT idea (so I won't be flipping thru like 10000 pages of manuals!
Brian
09-02-2007 11:58 AM In reply to
Top 50 Contributor
Posts 5,074
Exactly.  No guessing involved.  Make changes, then program CVs.
David B
09-02-2007 2:39 PM In reply to
Offline ShadowNix
Top 500 Contributor
Tacoma, WA
Posts 854
Great... hey Dave, I haven't dug into it yet (I downloaded it ), but I was wondering, what are the spec's required for the Java... could I run it on an old Pentium III notebook or so?
Brian
09-02-2007 2:40 PM In reply to
Top 50 Contributor
Posts 5,074
You should be able to.  The  computer that is hooked up to my layout is a PIII 833 or 866...cant remember.....and it runs it just fine.
David B
09-02-2007 8:23 PM In reply to
Offline NSCOALDRAG
Not Ranked
Joined on 07-23-2006
Posts 14
Hi All,
I use this program but wanted to add that my computer is a new one without any db 9 outputs. I needed a db9 to usb adapter and they are 40 bucks at circuit city or radio shack. I got mine from e-bay for 10 bucks including shipping. Just make sure what you order comes with software. mine did .
09-03-2007 10:48 AM In reply to
Top 50 Contributor
Posts 5,074
Sameless bump......
David B
09-03-2007 2:39 PM In reply to
Offline scubaterry
Top 500 Contributor
Joined on 12-18-2004
Gainesville area
Posts 1,350
Re: Tutorial: Using Decoder Pro WITHOUT a connection to your layout. PHOTO-INTENSIVE
Thanks, good info.
Terry
09-04-2007 9:32 AM In reply to
Top 50 Contributor
Posts 5,074
Has anyone tried this yet?  I want to see if any 'issues' came to the surface...
David B
09-04-2007 1:48 PM In reply to
Offline C&O Fan
Top 200 Contributor
Texas
Posts 1,938
Bump
This is good and should be seen by all !
09-04-2007 4:17 PM In reply to
Offline jwils1
Not Ranked
Joined on 11-10-2002
Thornton, Colorado
Posts 647
I tried it and it works great.  Thanks David.
09-04-2007 4:19 PM In reply to
Top 50 Contributor
Posts 5,074
Good to hear!
David B
10-26-2007 9:48 PM In reply to
Top 50 Contributor
Posts 5,074
Monthly Bump
David B
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
