General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 10-06-2007 11:20 PM by jeffrey-wimberly. 278 replies.
Rate:
Sort Posts:
Page 18 of 19 (279 items) « First ... < Previous 15 16 17 18 19 Next >
08-27-2007 1:05 PM In reply to
Offline SpaceMouse
Top 10 Contributor
Joined on 12-27-2004
Indiana, PA
Posts 9,908
Re: weekend photo fun 8/24-8/26
I rode about 40 miles or so on a Sugar Cane train on Maui back in 2000. I don't remember the details about like what kind of steam engine it was or if it was narrow guage or standard, but we rode it.
08-27-2007 1:18 PM In reply to
Offline jktrains
Top 500 Contributor
Joined on 10-13-2006
Northeast OH
Posts 903
Jeff,
Sit down.  Honesty time.  The camera will never yield good shots for model purposes.  It simply is not design for it.  The specs of the camera that lead me to this conclusion becuase of the following:
F-stop fixed at f2.8 - this will result in a very, very short depth of field, espcially for objects close the the lens.  This means that your focus will need to be spot on the subject.  This is why in your pictures there is a large amount of perspective with very little of it being in focus. Also, you have no ability to adjust the f-stop setting.
Shutter speed is limited to 1/60 - 1/1500 sec.  For interior photography you need either a lot of artificial light or a tripod to hold the camera.  On most SLRs the flash synced shutter speed is 1/60 sec.  This camera is at the bottom of the rande for slow shutter speed.  Many of my pics posted this weekend were in the 4-6 sec exposure range for dark scenes and 1.5" for average lighting from the room.  About the slowest a persona can hold a camera still for is a 1/30 shutter speed, maybe 1/15 if you're leaning against something.
While you're using flourescent lights, they don't provide enough light, for this camera, by the time it reaches the subject.  Light follows an inverse quare law, that means the when you move the light source from 1' away to 2' away from the subject the amount of light falling on the subject is reduced by 1/4 not 1/2.  Therefore you need not twince the light but four times to light for it to be equal.
Exposure setting is auto and can not be adjusted.  This means that since the f-stop is fixed the only way the camera can get the right exposure is to adjust its shutter speed automatically.  Because of this all of your pics with have the same basic exposure or at least be underexposed due to a lack of light.
White Balance is auto which is also bad.  You flourescent lights output of light is at a certain temperature.  While you may not notice the difference, a camera will.  I took a series of pictures using a simply desk light as the light source.  In one set I used a regular incandescent bulb (60watt) and the other set I used Daylight adjust compact floursecent bulb.  The camera was set on auto white balance.  There is a marked difference in the overall color shift between the two bulbs.
Bottom line is that this camera is meant for outdoor use.  I can't see in the specs of the camera itself where it even has a flash built in.  You will never get satisfactory results when used for close-up photography.  Save it for railfanning or overall layout shots.
After checking a few internet sites you can get a decent digital camera that should provide good pics for around $75-100.  These are cameras with a macro setting, automatic and manual exposure settings, anywhere from 3-6 megapixels, good f-stop range and a focus range down to as close as 4".  While I know you have limited resources, the cost of one of these cameras is in the range of a new loco such as a Bachmann DCC equipped one.  IMO a good trade off given your desire to post pics.  One less loco for hundreds of better quality photos.
08-27-2007 1:30 PM In reply to
Offline UP2CSX
Not Ranked
Joined on 06-20-2007
Prattville AL
Posts 741
I think your calculation is a bit off it comes out to .1 megapixel.  A megapixel is 1,000,000 pixels.  Jeffs camera is 101376 pixels.  The photos he is putting online have been enlarged and are 25 DPI.  What Jeff needs is a better camera.
Dang it, I had a feeling I was screwing up that calculation. I know less about math than I do cameras. Smile [:)] You're right, at .10 megapixels, it's amazing that Jeff's pictures don't look like a giant blur. I hope the other camera he has will do better.
08-27-2007 2:11 PM In reply to
Offline SteamFreak
Top 200 Contributor
Joined on 07-13-2006
New Joizey
Posts 1,872
 loathar wrote:
I could swear I just saw a program on that old sugar train. I thought it showed that they restored part of the line and were running tourist trains on it. (Confused [%-)] I could be wrong.)
Edit-Nope! I was right!
http://www.gomauicard.com/attractions/Sugar-Cane-Train.html
SEE! It IS paradise!
WHEW! Zak had me worried. And steam no less! Big Smile [:D]
08-27-2007 2:21 PM In reply to
Offline rayw46
Not Ranked
Joined on 02-19-2003
Georgia, USA
Posts 489
Loathar and Gappleg, someone, I can't remember who, produced a tape about the Hawaiian Sugar Cane Train which as you discovered, is now a tourist railroad.  Several years ago I checked the tape out of my local library.  Maybe it was on the History Channel or A&E at one time.
Ray
08-27-2007 2:35 PM In reply to
Offline wedudler
Top 500 Contributor
Joined on 09-16-2004
Germany
Posts 1,213
Westport Terminal RR made some advertising at the bridge over Commerce St.
Wolfgang
08-27-2007 2:58 PM In reply to
Offline Bapou
Not Ranked
Joined on 09-12-2006
Posts 577
Well now that I have a photobucket account here does nothing:
This is the Grim reaper bought in Germany on my diorama.
This is done with just a flashlite, and gravestones from Germany.
Here is one more:
That is just an ALCO S1-4 on the diorama.
08-27-2007 7:10 PM In reply to
Offline Bapou
Not Ranked
Posts 577
Just wanted to make sure you guys get the last pic here.
08-27-2007 7:18 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,323
I've been doing a bit of layout work today. Remember all the exposed plaster where the crossovers are?
I put some glue mix down and sprinkled liberally with WS green blended turf.
After it's dried I'll clean up the excess and work on putting some ballast in.
08-27-2007 7:29 PM In reply to
Offline ac4400fan
Not Ranked
Joined on 03-12-2005
Arizona. Born And Raised In Chicago ILL.
Posts 727
Jeff thats a nice shot! how are you going to work the ballast in? Looks good my friend
Carl.
08-27-2007 7:33 PM In reply to
Top 10 Contributor
Sundown, Louisiana
Posts 13,323
A little glue wash between the ties and down the sides of the road bed followed by a layer of fine ballast applied with a straw. The turnouts of course will be left clear.
08-28-2007 12:40 AM In reply to
Offline SD60M
Not Ranked
Joined on 04-22-2007
Memphis, Tennessee
Posts 416
 jktrains wrote:
SD60M
First of the C30-7 is an Atlas, not a BLI.  I've installed an NCE DA-SR in it for DCC.  The rotary beacon is a Details West beacon with a grain of rice bulb inserted inside the amber plastic lens.  It is then connected to the decoder and programmed for a rotary beacon.
I've seen some of your videos on youtube.  Based on them, your other postings and your avatar, it looks like your SD40-2s are BLI units.  The problem with BLI and other sound equipped locos is that there are no extra lighting functions on the decoder.  As far as I can figure the only way to add such an effect on them is the add a separate decoder than can provide the lighting effects.
The beacon isn;t hard to do, just takes patience.  It makes for a really neat effect to have 3 or 4 or 5 of them on in a dimly lighted room.
jktrains
Actually my C30-7 is an atlas unit. My SD40-2 is BLI the other loco is a P2K SD45 and most of my fleet is made up of athearn rtr units. BTW is there a way to make the beacons work without DCC? If so please let me know.
-Kade
08-28-2007 12:49 AM In reply to
Offline Hoople
Top 500 Contributor
Joined on 07-25-2006
Seattle WA
Posts 1,230
Hey guys, I think WPF has ended. It's 10:30 PM on monday here... I think it should be over with.
08-28-2007 1:20 AM In reply to
Offline CNW 6000
Top 75 Contributor
Joined on 12-19-2005
MP 175.1 CN Neenah Sub
Posts 3,686
 SD60M wrote:
 jktrains wrote:
SD60M
jktrains
-Kade
I've seen battery powered ones, not sure who makes them tho.
Who cares if the weekend is over if we're having fun?
08-28-2007 6:25 AM In reply to
Offline Tom Bryant_MR
Top 500 Contributor
Joined on 01-30-2005
Cedar Park, Texas
Posts 952
A straw ?  Now that's a neat idea.  I've been using a plastic spoon.  At 1/87 scale, the spoon is like a snow shovel.  I've got to try the straw.
Regards
-Tom
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
