Trains.com
Bob and other electronic gurus, A TVS question
  • Member since
    March 2005
  • 5,028 posts
Posted by dwiemer on Monday, August 6, 2007 8:23 AM
Well, I am getting ready to get the majority of my wiring done and have a question regarding the Transient Voltage Suppressor that you suggest for protection.  I have a quote from a previous thread and want to verify the information:
Just place one 1.5KE36CA between the track common (outer track) and track hot (center track) at each lockon or power feed. The direction is not important as they are bidirectional. "
Would it be required to do this for each feed?  I have the "Star" wiring method as suggested for DCS, and I would think that as long as you had one TVS for each terminal feed from the transformer, you should be OK.
In the above quote, the "1.5KE36CA" is the number for a Mouser electronics TVS.  Would you suggest a different one?
Also, how temperature sensitive are these?  Do I need to use a heat sinc while soldering these?
Lastly, I have some Cole Hersee Breaker blocks (10 gang), that I am using too as added protection.  Besides the breakers and TVS, are there any other suggestions that will help me and others?
Thank you so much for your help in this and all matters.
Regards,
Dennis
TCA#09-63805
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Monday, August 6, 2007 7:20 PM
That's actually a Vishay (formerly General Semiconductor) part number, which you can get from many different suppliers:
http://www.vishay.com/diodes/protection-tvs-esd/pkg-1.5ke/
You're right that you need only one per circuit.  They are not particularly fragile.  You shouldn't have any trouble soldering them with any reasonable iron.
Bob Nelson
  • Member since
    March 2005
  • 5,028 posts
Posted by dwiemer on Monday, August 6, 2007 7:43 PM
Thanks Bob, for yet another answer.  I will order in the morning.  I tried a local electronics distributor, but they did not have them at a low enough voltage rating.  (I try to use local when possible).
Dennis
TCA#09-63805
  • Member since
    December 2005
  • 3,784 posts
Posted by dbaker48 on Thursday, September 25, 2008 2:43 PM
I understand, (I think) from Dennis' post above.  I am further assuming, that since I feed the track power from the TIU, I can put one lead into the red & black terminal AT the TIU.  Right ?
Also, if I was to install in an engine, would it also go between ground and the pick-up roller?
Thanks,
Don
Don
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Thursday, September 25, 2008 10:22 PM
I don't know about the colors of TIU terminals; but the TVS should go effectively between the center and outside rails of the track.  Thus, in the locomotive, between whatever the wheels are connected to and the pickup, as you say.
Bob Nelson
  • Member since
    December 2005
  • 3,784 posts
Posted by dbaker48 on Thursday, September 25, 2008 11:31 PM
Thanks Bob !!!  (The TIU Red is positive to the center rail, and the black is Neg. to the outside rail.)
Thinking about it a little, And I think I will put a solder a wire to the leads on the TVS, then secure them in an area not directly attached to the TIU unit.  The reason is, I assume these units could get a little hot, and don't need to have heat generated real close unnecessarily.
Don
  • Member since
    January 2005
  • 4,014 posts
Posted by phillyreading on Friday, September 26, 2008 8:49 AM
Bob, are you saying that the TVS would go across the outside & inside power wires similar to a light bulb or do you wire it in series like a fuse?  I bought a few of the TVS's from Mouser over five months ago and had trouble using one with a transformer to supply power to my switch motors. I wired it in on the power side and got nothing out of it, might the part be bad or did I wire it wrong?
Lee F.
Interested in southest Pennsylvania railroads; Reading & Northern, Reading Company, Reading Lines, Philadelphia & Reading.
  • Member since
    March 2004
  • 189 posts
Posted by Pennvalley on Friday, September 26, 2008 6:15 PM
They connect from the hot to the common wire.
Paul
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Friday, September 26, 2008 7:45 PM
In parallel, like a lamp.  If you did wire it in series, like a fuse, you wouldn't get anything through it, except any voltage spikes that exceeded its rating, that is, ironically the very spikes you are trying to eliminate.
Bob Nelson
  • Member since
    March 2005
  • 5,028 posts
Posted by dwiemer on Friday, September 26, 2008 9:27 PM
You know, as good of an idea as this is, I am suprised that the manufacturers don't have these wired into the transformers or available for seperate sale as a suggested add on.  With modern electronics that are so fragile, it would be a great thing.
Thanks again, Bob.
Dennis
TCA#09-63805
  • Member since
    January 2005
  • 4,014 posts
Posted by phillyreading on Saturday, September 27, 2008 9:30 AM
Thanks Bob!
I just looked at the packing sheet that came with the TVS units, no instructions on how to wire it, just a shipping receipt.
Lee F.
  • Member since
    March 2007
  • 210 posts
Posted by Dave Connolly on Sunday, September 28, 2008 8:57 AM
 A couple of posters mentioned running DCS. A lightbulb placed between the center and outside rail do wonders sometimes to boost the DCS signal. I know little about electronics but have read many posts on TVS and sort of understand what they do. Just curious if they have any effect at all on the signal portion of DCS such as weakening it or confusing it. I was an early adopter of DCS and from what I remember the TIU had something built in for voltage spikes. Not sure though if it was protecting itself, the trains or both. You can never have enough protection. Would like to get some feedback from those using these on a DCS layout.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Sunday, September 28, 2008 10:37 AM
The TVS looks electrically like an open circuit until the instantaneous voltage exceeds its rated voltage, which shouldn't happen unless something (like the transformer) tries to feed a voltage spike to the track.  So I would expect no ill effect from using one with DCS.
Bob Nelson
  • Member since
    December 2001
  • 899 posts
Posted by nblum on Sunday, September 28, 2008 1:29 PM
Do TVS's have any polarity considerations?  My apologies if it's already been mentioned and I missed it.
Neil (not Besougloff or Young) :)
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Sunday, September 28, 2008 2:11 PM
Not if you get the right kind, which is bidirectional.  The Vishay part number is, for example, 1.5KE36CA, where the "CA" means bidirectional.  If it has just "C" then it is unidirectional and is meant for DC circuits.
Bob Nelson
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
