Trains.com
How do you get rust off track
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Friday, July 13, 2007 7:21 PM
What is the best wat to get light rust off track if at all. Its the old tube track not fast track. And should I use some sort of oil on track when i store it?  Thanks Jared
  • Member since
    June 2006
  • 1,279 posts
Posted by magicman710 on Friday, July 13, 2007 7:51 PM
Use sandpaper.
"Lionel trains are the standard of the world" - Jousha Lionel Cowen
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Friday, July 13, 2007 8:44 PM
Do use a oil to help prevent rust at all?
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Friday, July 13, 2007 9:16 PM
Try a Scotch Brite type of pad with a little WD40.  Clean and then wipe off the track. If the track is in place on a layout, sandpaper particles may end up in the gears of a locomotive.
I have Scotch Brite wheels for a Dremel tool.  I have used them to clean wheels of cars and they do a great job.  I think they would also work well to clean crude and rust off of track.  I bought the Scotch Brite wheels at a train show from one of those guys that sells all sorts of hobby tools.
Celebrating 18 years on the CTT Forum. Smile, Wink & Grin
Buckeye Riveter......... OTTS Charter Member, a Roseyville Raider and a member of the CTT Forum since 2004..
Jelloway Creek, OH - ELV 1,100 - Home of the Baltimore, Ohio & Wabash RR
TCA 09-64284
  • Member since
    November 2006
  • 1,326 posts
Posted by DMUinCT on Saturday, July 14, 2007 8:23 AM
Buckeye has got it right!
Remember, if it rusted, the tin plating is gone and it will re-rust if not maintained.
Don U. TCA 73-5735
  • Member since
    March 2004
  • 760 posts
Posted by eZAK on Saturday, July 14, 2007 11:14 AM
If it is only lightly rusted I would Not use any abrasives!
Try brake fluid on a rag instead!
Relax, Don't Worry, Have a Home Brew!</font id="size2"> Pat Zak</font id="size3">
  • Member since
    April 2004
  • 886 posts
Posted by Dave Farquhar on Saturday, July 14, 2007 2:11 PM
I've cleaned a lot of rusty track. My favorite is a scotch-brite pad (the finer the better) with white vinegar. Rust dissolves in vinegar pretty readily. Light rust goes away with vinegar on a rag. I used sandpaper on one batch but it re-rusted and got dirty a lot more easily. Spray a little WD-40 on if you're going to store for a long time, then wipe it off with a degreaser before use.
Dave Farquhar http://dfarq.homeip.net
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Saturday, July 14, 2007 3:04 PM
Dave as you know I have been a fan of your writings for some time. You were able to place into words something that I have been thinking of for a few weeks. In a strange way that was closure on that whole twisted event. Great job dave.
Now for cleaning the track please don't use steel wool. Since the track is cheap I try to weight the effort against replacement if it is badly rusted. I find once the coating is badly worn the track will build up with dirst fast and rust even faster.
  • Member since
    January 2007
  • 315 posts
Posted by USNRol on Saturday, July 14, 2007 3:46 PM
Some of you may think this is a hell of a lot of effort for some old tubular but anyway...
I've been using this:
It's a cheapo old B&D grinder with a burnishing wheel.  The wheel is a gummy feeling rubber of some sort, but at high RPM on this grinder it makes really short work of some pretty nasty looking track.  I've been buying used lots of 027 tubular off ebay and you wouldn't believe some of the track you'll get.   Anyway I was doing this by hand using 600 grit sandpaper folded up into a 1 inch square.  It was doing almost as good a job, even getting a good burnish by rubbing quickly and allowing the paper to gall up a bit, but my fingers were hurting after about 2 sections of track! Banged Head [banghead]
Here's a before and after of the same piece of track.  BTW I pull the pins out and clean them up on the wheel too, then reinsert them.
Before:
After:
Since I've figured this method out I'm actually looking forward to cleaning all my track. Laugh [(-D] The finish this wheel leaves on the rail head is very shiney and smooth and therefore resists corrosion and dirt/grime build-up very well.  Also maintenance cleaning is easy as pie with a good rag soaked in goo gone or your favorite vinegar!
Good Luck!Wink [;)]
Roland
  • Member since
    July 2006
  • 1,615 posts
Posted by chuck on Saturday, July 14, 2007 7:28 PM
You can try to use RailZip to try and protect the track.  If it's rusting repeatedly,  replace it.  Tubular is pretty cheap compared to your time.
Tin oxide is conductive, but slippery.  The microfiber cleaning cloths are pretty good at removing the oxide without damaging the track, they are even less abbrasive than Scothbrite.  As others have noted, do not use sandpaper or steel wool.  These will remove the protective plating AND leave debris that can cause even more trouble.
When everything else fails, play dead
  • Member since
    October 2004
  • 7,607 posts
Posted by laz 57 on Saturday, July 14, 2007 8:11 PM
Before:
After:
Good Luck!Wink [;)]
Roland
Great fix, EXCELLENT IDEAR,  thanks got a few old motors lying around here going to give that a try.
laz57
  There's a race of men that don't fit in, A race that can't stay still; Robert Service. TCA 03-55991
  • Member since
    April 2006
  • 201 posts
Posted by lionel2986 on Wednesday, July 25, 2007 12:00 PM
Is there anything that can be done to recoat the track with tin plating? Is it worth it? If not, are there alternative solutions besides replacing the track?
Will Scotch Brite remove the tin plating (assuming its still on the track)? If a track is heavily rusted, will a wire wheel be a better option?
Finally, will all these wheels and bits that are designed for dremels work with hand drills?
  • Member since
    July 2003
  • 8,059 posts
Posted by cnw1995 on Wednesday, July 25, 2007 12:25 PM
I spent an entire Saturday this past winter using a dremel with a wire wheel to go over (really) rusty track. Instead of trying to get the rust off every bit, I concentrated on the top and side where a train wheel would make contact. My basement is pretty dry so far the rust hasn't come back and the track conducts electricity well.
I figure 'rail grinding' works well for the prototype as well.
Doug Murphy 'We few, we happy few, we band of brothers...' Henry V.
  • Member since
    April 2004
  • 886 posts
Posted by Dave Farquhar on Wednesday, July 25, 2007 4:40 PM
Re-plating the track will cost more than replacing it would. The starting price for plating kits is $40 or $50 and you're likely to need at least one or two more bottles of plating solution. Pretty soon you're up against the $100 mark, and $100 buys a lot of tubular track.
If track is rusted heavily enough that a Scotch-Brite type pad can't do the job, I would replace the track. I used a wire wheel in a drill to clean some track, the first time I tried, but I wasn't very happy with how it ended up. The track ended up with a lot of pits and grooves in it, so it was a lot harder to keep clean.
The less aggressive you have to be with the rust, the better. You also don't want to spend too terribly much in the way of tools and time to do it. Used tubular track in usable condition is extremely cheap. I can usually find all the O27 tubular I want at train shows for 25 cents a section. O31 tubular costs more, but probably around 50 cents a section. I've also bought used O27 wide curves and long straights for $1 apiece.
  • Member since
    December 2005
  • 265 posts
Posted by LS1Heli on Wednesday, July 25, 2007 5:53 PM
Rusted track is more of a hassle. You want good conductivity and you want trains running on a smooth, clean, original finish.
The best method of cleaning rusted track is to throw it in the garbage and buy new track.
  • Member since
    February 2007
  • 146 posts
Posted by rustycoupler on Wednesday, July 25, 2007 9:03 PM
 throw it out and get real trax.
  • Member since
    July 2006
  • 1,474 posts
Posted by RR Redneck on Wednesday, July 25, 2007 9:11 PM
Forget that! Just break out the sandpaper.
Lionel collector, stuck in an N scaler's modelling space.
  • Member since
    December 2005
  • 265 posts
Posted by LS1Heli on Thursday, July 26, 2007 5:15 PM
Thats what I could never understand. There is so much tubular track out there that it is almost worthless yet year after year people sill spend hours and hours cleaning, money on grinding wheels, etc.
Throw it out! Buy new track! Is it that expensive??
  • Member since
    October 2004
  • 5,434 posts
Posted by Blueberryhill RR on Thursday, July 26, 2007 9:07 PM
Well.......I guess we are all entitled to our opinions....But, personally, I would rather keep my PW Lionel track, stamped " Lionel NY ", if it is rusty. Clean it up and use it. Just my opinion.
Chuck
Chuck # 3 I found my thrill on Blueberryhill !!
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, July 26, 2007 9:54 PM
Yep, I also like the fack its the same track my dad ran his, now my trains on as i kid!
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
