General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-22-2007 5:49 AM by Kent. 19 replies.
Rate:
Sort Posts:
Page 1 of 2 (20 items) 1 2 Next >
07-11-2007 3:23 AM
Offline Tracklayer
Top 150 Contributor
Joined on 08-25-2005
Southeast Texas
Posts 2,210
A Tooth Pick Is A Modellers Best Friend...
Hello all.
I was out in the shop earlier tonight when I came across a box car that had the wrong built date on it. At first, I thought I'd just let it go and run it as it was, but then as things like that always seem to do, it started bugging me, so I started trying to figure out a way to erase it. In the past, I've seen a number of methods for removing decals, but instead of those, I decided to try a sharp tooth pick and a little spit (not to be gross) and carefully but quickly rubbed the tiny numbers off of the car without doing any damage to the paint.
If someone else has already posted this method/idea, I sincerely apologize for wasting your time.
Tracklayer
07-11-2007 8:06 AM In reply to
Offline ranchero
Not Ranked
Joined on 05-28-2006
Posts 217
Re: A Tooth Pick Is A Modellers Best Friend...
toothpick are one of MR best kept secret in my opinion. You can use them from stirring paint, for checking consistency of plaster, as a sculpting tool, you can use it for painting tiny detail , you can file them to fit as shim anywhere, in a pinch you can use them instead of insulating joiner. Toothpick can also be used as load in N scale and Z , can be use for small lumber in HO. you can  put masking tape and use it as a painting handle for small parts. burn a few toothpick and use the ashes to weather models, you cn use their sharp tip to gently scrape paint splatter, its an excellent glue applicator as well as grease/lube...the flat one can be use to build shipping pallet for pennies.thats only the tip of the iceberg. , if there ever was a tool id have a hard time living without, toothpicks would be right up there with my atlas and zona saws and my ole metal caliper.
 they are cheap, plentyful and if you break one...so what, 99999 more in the box...
all hail the mighty toothpick, puny in size but large in applications
07-11-2007 9:22 AM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 9,982
The plastic ones are great to use as styrene rods too. Good for plugging unwanted holes.
07-11-2007 9:54 AM In reply to
Offline pcarrell
Top 25 Contributor
Joined on 02-17-2005
In the State of insanity!
Posts 7,976
Behold, the lowly toothpick!
07-11-2007 10:23 AM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-12-2005
Southwest US
Posts 7,240
Funny that nobody mentioned sticking one (with a dab of glue on the end) in a stripped-out screw hole.
Only one of the thousands of possible applications.  Another is as the basis of the boom on a light-duty jib crane.
Have fun thinking of more!
Chuck (modeling Central Japan in September, 1964 - box of toothpicks handy)
07-11-2007 10:27 AM In reply to
Offline TA462
Top 75 Contributor
Joined on 06-07-2004
PORT HOPE, ONTARIO
Posts 3,587
I've probably used 100's of them while building model cars.  I use them to hold up trees on the layout as well.  I drill a hole in the bottom of the tree, glue in a toothpick and push it into place in the foam.  It makes for a very sturdy tree.
07-11-2007 2:00 PM In reply to
Offline Cox 47
Top 150 Contributor
Joined on 12-17-2003
East central Illinois
Posts 2,282
Always have some on the work bench......Cox 47
07-11-2007 2:24 PM In reply to
Offline Tracklayer
Top 150 Contributor
Southeast Texas
Posts 2,210
Now that's what I'm talking about...
Tracklayer
07-11-2007 3:55 PM In reply to
Offline inch53
Top 200 Contributor
Joined on 02-03-2005
hillbilly hide away and campground C, M-ville,ILL
Posts 1,941
I got a piece of scrap wood n drill some holes bout toothpick size for painting them. Then I use them for wooden fence post or post along roadways and parking lots. Stick a few more in the block and they're also good for holding plastic tubing upright for painting
07-11-2007 4:20 PM In reply to
Offline Heartland Division CB&Q
Top 150 Contributor
Joined on 01-25-2007
Kentucky
Posts 2,712
As Inch just said, toothpicks can be used for fence posts.  My rural style wire fence is from toothpicks and thread.  It is only about 3/4" in front of my back drop, and it adds the illusion of distance.
It's easy to make. Use round type toothpicks. Paint or stain dark brown.  Cut each tooth pick in half creating two fence posts per toothpick.  At this location I had some styrofoam under the ground foam. So, It was easy to poke the sharp end of each half-toothpick into the scenery. Next I simply wrapped thread around each fencepost while stretching it the length of the fence.
With all the stuff in the foreground, any imperfections with the fence are not noticeable.
07-11-2007 7:52 PM In reply to
Offline mlehman
Not Ranked
Joined on 09-04-2003
Posts 732
Toothpicks, flat, round, or one of the fancy varieties, are great for a multitude of uses.
Then, sometimes, you need something just a little bigger...
Behold the lowly popsicle stick!
Once you've bought the big box of 500 (or whatever size they come in at the craft store), you're set for life, unless you start building something with them.
In my mind, the popsicle stick is just a mega-toothpick, in terms of the many useful purposes it provides.
07-11-2007 9:25 PM In reply to
Offline Rangerover
Not Ranked
Joined on 08-15-2006
Posts 264
Im glad your fence isn't nice and neat! It's great the way it is, it looks real! Jim
07-12-2007 4:41 AM In reply to
Offline jeffers_mz
Top 500 Contributor
Joined on 11-05-2005
Posts 1,226
Toothpicks rule.
Good for poking cats when they jump in your chair prior to some op time, and good for trestlework under a mining sluice.
Buy two boxes.
Also, pick up any and all packages of small wood you find at craft or art stores. He who dies with the most stock lumber, wins.
07-12-2007 6:03 AM In reply to
Offline denny99
Not Ranked
Joined on 03-24-2003
Saronno, VA - Italy
Posts 88
larger toothpicks can be used for uncoupling, too. Cool [8D]
07-12-2007 8:03 AM In reply to
Offline dknelson
Top 50 Contributor
Joined on 03-20-2002
Milwaukee WI (Fox Point)
Posts 4,605
In addition to their many model railroad and household uses, toothpicks are also astoundingly useful in prying bits of food from between your teeth.  try it, it works like magic.  Who would have thought ....
Dave Nelson
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
