Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
How to test a decoder and not let the smoke out?
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Sunday, July 15, 2012 8:59 AM
 OK, I BBQ another decoder! Grumpy
 Engine is my Proto 2000 SD 7, this is the third decoder it has cooked. Other day I tested the motor and free wheeling it was pulling 1 amp and was running real slow, stall was little over 1.5 amps.
 Replaced it with another motor. Free wheeling it was pulling .09 amps and stalled at .80 amps. Installed the motor with drive train hooked up, pulled .45 amps and stalled at .85 amps. So I am good to go!
 Set it up on my PR 3 and used Decoder Pro to read and write the CV's, went with out a hitch. Big Smile
 Set it on the track, gave it power and Poof, let the smoke out? Bang Head
 Just tested the motor in the chassis again, still pulls .45 amps and stall's at .85 amps. So it is not the motor or drive train.
 Engine still has it stock light board, I am going to pull it and hard wire the next decoder.
 The SD 7 came DCC ready and ran for 3 years before it became a problem.
 If I had a wire grounded, would Decoder Pro still read the CV's?
 Is there a safe way to test a engine and if there is a problem that will not let the smoke out?
 Thank You folks for the coming answers.
 Ken Chef Cooking Decoders Again
I hate Rust
  • Member since
    April 2011
  • 54 posts
Posted by Fire fighter Mike on Sunday, July 15, 2012 9:17 AM
Normal 0 false false false EN-CA X-NONE X-NONE MicrosoftInternetExplorer4
Well I'm kinda new to this but this is what I have done
"A separate low-current programming track is needed only for first time programming of locomotives with user-installed decoders.
The low current to the programming track protects the decoder if the installation was performed incorrectly.
To create a programming track, connect a resistor in series with one track wire to an isolated section of track (figure 14). A 100 ohm
10W Wire wound Resistor (Radio Shack Catalog # 271-135) is recommended (figure 14)."
By reading your post though you know your amp draws and stuff so I'm assuming that you already have a programming track. This is what I do and I've never had an issue.
Your obviously way more advanced into DCC than I am but thought I would throw my thoughts out there just in case
My 2 Cents
  • Member since
    January 2007
  • 3,290 posts
Posted by gandydancer19 on Sunday, July 15, 2012 10:25 AM
Any time after I just instal a new decoder in anything, I put it on my programming track and see if it will read back.  I use an NCE Power Pro, and if it doesn't read back or just times out, something is wrong.  If it does read back AND will program correctly, then it's good to go.  I haven't had any problems with decoder installs since doing things this way.  AND - I have found some mistakes and got them corrected before I put the loco on the main by doing things this way.
Elmer.
The above is my opinion, from an active and experienced Model Railroader in N scale and HO since 1961.
(Modeling Freelance, Eastern US, HO scale, in 1962, with NCE DCC for locomotive control and a stand alone LocoNet for block detection and signals.) http://waynes-trains.com/ at home, and N scale at the Club.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Sunday, July 15, 2012 11:35 AM
 Elmer and Mike. That is why I used Decoder Pro first. I could write then read the CV's I wrote. Was pretty sure I was home free. Then I got my Chef hat out and started cooking!
 Guess I am going to try out Digitrax No Fault Warranty.
 Ken
I hate Rust
  • Member since
    July 2008
  • 1,206 posts
Posted by mfm37 on Sunday, July 15, 2012 11:37 AM
You can build a current limited test track by using a 100ohm 1/2 watt resistor in series with one of the track power wires. That will save your decoders while testing. However, your problem seems to lie in keeping the motor brushes or functions isolated after testing. Normally, if the decoder programs, it is isolated. A short between a motor brush and the rails or a function lead and rails will result in no programming. D The decoder would not be damaged if using a current limited programming track. It just simply will not program.
I would have a good hard look at the installations. Could the motor be torquing up and causing a momentary contact?  Maybe some extra space is required between the frame and motor brushes to allow for movement?
Martin Myers
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Sunday, July 15, 2012 11:57 AM
 Dunno what all the extra stuff would accomplish - using the PR3 first IS a current-limited program track. Normally you should not be able to get good reads and writes if there is a wire crossed, like a track wire contacting a motor wire, but it's not 100% foolproof.
 There is always the possibility that the decoder was just defective, and was able to handle the reduced power of the program track but once full power was applied - poof. That's what warranties are for. They make these by the thousands, and the individual components posibly int he millions (since the circuit chips aren't used just for DCC - otherwise decoders would be a LOT more expensive), so to have one slip through sub-par now and then is somewhat expected. Not to mention the new lead-free standards require the board and components to be subject to a much higher heat level during the manufacturing process - compontnes rated for ROHS are supposed to be able to withstand this increased temp in a non-operational mode (ie, when the board is made) but if there was any attempt to use up any old pre-ROHS inventory of chips, you cna have issues caused by the process as well.
                       --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Sunday, July 15, 2012 12:13 PM
 So I may be right, if Decoder Pro could read the decoder there good chances I did nothing wrong. Makes me feel a little better.
 When I put it on the main, I had no lights. I moved it a little thinking the wheels may have been dirty. Motor moved then poof. Last a 10th of a second if that.
 Going to pull it apart and double check my install. Hopefully this time I won't Chef the decoder.
 Thanks again folks.
 Ken
I hate Rust
  • Member since
    April 2009
  • 1,468 posts
Posted by Graffen on Sunday, July 15, 2012 12:54 PM
Well that's Proto diesels..... I've had 3 of them and neither managed to let a decoder live long...... I concluded that one of them shorted at the wheel axles, one had a defect board and the third one I never manage to find what the problem was.... I have no more of those.....
Swedish Custom painter and model maker. My Website:
My Railroad
My Youtube:
Graff´s channel
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Sunday, July 15, 2012 1:55 PM
 Graffen, I have had outstanding luck with Proto's. In fact the SD 7 has around 200 to 300 hours of run time.
 Ken
I hate Rust
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Sunday, July 15, 2012 2:20 PM
 Mine have all been fine. Lots of extended run time at the club on my Geeps - but then, I rip out the factory boards and hard wire almost all of my decoders, and use LEDs.
                --Randy
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
