Trains.com
Lionel electronic reverse board in a MTH Steamer
  • Member since
    June 2011
  • 440 posts
Posted by RRaddict on Tuesday, January 24, 2012 12:25 PM
I purchased one of those MTH Steam Locomotives on Ebay that someone took all the electronics out of it.  A new Proto Unit is out of the question as it would be more than a new locomotive.. I have a cheapo Lionel steamer  that  has an electronic e unit I want to remove and put in this MTH steamer.  Does anyone know if it is possible to do this?
Thanks,
Kevin
Can't stop working on the railroad!
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, January 24, 2012 1:48 PM
I couldn't say whether your electronic Lionel e-unit will work with that locomotive.  But I bet an electromechanical one would.  I replaced (and sold) the electronics from an MTH Big Boy and a GTEL with electromechanical e-units.  Surprisingly, there wasn't room in the Big Boy for a regular vertical e-unit; so I used a horizontal one (with a spring inside), either a 671-50 or a 726-51,
Bob Nelson
  • Member since
    June 2011
  • 440 posts
Posted by RRaddict on Tuesday, January 24, 2012 2:12 PM
Bob I don't have a clue on the mechanical e-units as I wouldn't know where to put that lever.  The electronic e-unit is in a locomotive that is much smaller than the MTH locomotive so hopefully when I open it up I can make heads or tails out of it.  I know power and ground have to be hooked up but the wires that connect to the motors I am not sure of.
Thanks
Kevin
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, January 24, 2012 3:12 PM
You don't actually need the lever.  You can substitute an SPST switch, presumably whatever switch you might use to turn the electronic e-unit on or off.  In fact, the horizontal e-units that I mentioned don't have the lever.
I assume your MTH locomotive has a DC can motor; so you would need a rectifier too.  But that would be quite small and easy to fit into the locomotive, I am sure.
Bob Nelson
  • Member since
    June 2011
  • 440 posts
Posted by RRaddict on Tuesday, January 24, 2012 3:17 PM
Bob I forgot about the rectifier which I already have both but dont know how to hook it up.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, January 24, 2012 3:29 PM
With the electronic e-unit, you probably don't need it.  I would expect there to be one already included in the unit.
With the electromagnetic e-unit, connect the (bridge) rectifier's ~ terminals, one to the frame (outside rails) and one to the pickup.  Connect the - terminal to one end of the e-unit coil and to the green wire.  Connect the + terminal to the other end of the e-unit coil and to the red wire.  Connect the blue and yellow wires to the motor.
Bob Nelson
  • Member since
    November 2010
  • 993 posts
Posted by gunrunnerjohn on Wednesday, January 25, 2012 8:18 AM
You can buy a new electronic reverse from many of the parts dealers for around $15.  It's a simple four wire affair, two to the motor, and two to the pickups.  No additional parts are required, this unit takes the AC track voltage and controls the motor.
The Lionel part number is 107-100 for the electronic reverse unit.  Jeff at www.ttender.com has them for $15.
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
