Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Track Feeder Wires
  • Member since
    February 2003
  • 971 posts
Track Feeder Wires
Posted by alloboard on Sunday, December 25, 2011 1:12 AM
I once had a bunch of track feeder wires that I purchased from a hobby shop but I ran out. Where can I find those wires in HO scale that's connected to the metal rail joiners? I Googled then and found nothing. What online retailer has these so I can buy them?
  • Member since
    September 2007
  • 6,099 posts
Posted by Phoebe Vet on Sunday, December 25, 2011 2:40 AM
Dave
Lackawanna Route of the Phoebe Snow
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Sunday, December 25, 2011 5:11 AM
Alton Junction
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Sunday, December 25, 2011 6:38 AM
TA462
Why not make your own?
So true.
That's what I do.
Alton Junction
  • Member since
    January 2011
  • 893 posts
Posted by PennCentral99 on Sunday, December 25, 2011 9:36 AM
A google search of "terminal rail joiners" (the exact product name) revealed numerous hits.
As others have stated, you can solder your own.  I prefer making my own because I solder the wire parallel to the the rail joiner instead of a "T".  It makes it easier to conceal and once the ballast is down, the wire is unseen.
Inspired by Addiction
See more on my YouTube Channel
  • Member since
    December 2004
  • 21,483 posts
Posted by MisterBeasley on Sunday, December 25, 2011 10:12 AM
The pre-made ones from Atlas use very thin wire.  I make my own with 22-gauge wire instead.  I make half of them with red, and half with black so I can color-code the two rails, which makes it a lot easier to connect them properly under the layout.
I take a small section of scrap track and loosely install rail joiners on all 4 rail ends.  This gives me a solid, convenient support for the joiners.  Then I solder the wires on.  LET THEM COOL.  Otherwise, you'll find how much heat the connection will transfer to your fingers right after soldering.
It takes an iron man to play with a toy iron horse.
  • Member since
    July 2006
  • 9,592 posts
Posted by BroadwayLion on Sunday, December 25, 2011 1:47 PM
the LION just solders the feeders to the rails, almost NEVER to the joiners.
Can the be seen, well duh! subway systems have all kinds of wires hanging off of the tracks and infrastructure. I could surface mount a 12 ga wire, and it would just look like part of the scenery.
Indeed, just for the fun of it I surface mounted a huge 5.1Ω 5W sand resistor on the railroad. (It attenuates the speed on the down hill side of the main helix.)
LIONS have no problem hiding wires in plain sight.
The Route of the Broadway Lion The Largest Subway Layout in North Dakota.
Here there be cats.                                LIONS with CAMERAS
  • Member since
    February 2003
  • 971 posts
Posted by alloboard on Sunday, December 25, 2011 2:10 PM
Thanks all for the links and information.
  • Member since
    July 2006
  • 9,236 posts
Posted by galaxy on Monday, December 26, 2011 7:13 AM
Here is yet another link to the rail joiners with feeder wires attatched:
{and you won't pay the hgh $3.95 or $4.50 per}
code 100:
http://www.wholesaletrains.com/Detail.asp?Scale=HO&Item=150TRACK100&offset=50&ID=20012095
code 83:
http://www.wholesaletrains.com/Detail.asp?Scale=HO&Item=150TRACK83&offset=25&ID=20014771
{If you wnat N scale, go to the Atlas section of the N scale lisitings}
Geeked
-G .
Just my thoughts, ideas, opinions and experiences. Others may vary.
 HO and N Scale.
After long and careful thought, they have convinced me. I have come to the conclusion that they are right. The aliens did it.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Tuesday, December 27, 2011 10:31 PM
 Seriously, just make them. For the price of a couple pair of the Atlas ones, you can buy a pack of 4 dozen plain rail joiners and a spool of wire. In a couple of hours you can make a dozen pairs or more of feeders. You don;t have to be super duper neat when soldering wires to teh joiners, but it does help to have a set of those "helping hands" with the alligatoer clips o you can position the bared end of the wire and the joiner and hold them in place while your hands hold the solderign iron and solder.
                 --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Wednesday, December 28, 2011 4:16 AM
rrinker
                 --Randy
That's th truth.  It does takes three hands, or two hands and an alligator clip, to make your own feeder wires, although it is worth it.
Alton Junction
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Wednesday, December 28, 2011 10:37 AM
 It helps _ I can do them without the helping hands gizmo, but it's MUCH easier with it. I can set up 2 at a time (joiner on desk, clip of the hands holding the wire in place) witht he tool, and churn out a batch in no time. Assembly-line style - first I cut a bunch of feeder wire to length, then I strip each piece, then bend the stripped end, then line up joiners and go to work.
                    --Randy
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
