Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
The D&H - Rocky Mountain Empire
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Thursday, September 22, 2011 8:32 PM
In honor of reaching my 500th post here I bring you my HO Dream / Nightmare; you know the one, BIG DREAM, little space...
Now those that know me from another forum have seen this topic before so this is just a repeat to get more thoughts from those that have not seen my crazy design.  So, here goes my first real Model Railroader Forum topic
Well, Plan#1 for my future HO layout was a complete disaster so I went back to the drawing board. Another design idea inspired me to once again start a draft drawing to see if it might fit and through "extremely" tight, it might just be what my D&H - Rocky Mountain Empire will turn out to be.
Let's step back and review the limitations of "space" I have for a future HO train room. Awhile back we had our porch floor redone with the plan to redo this space as a "3 Season" room; as in no heat/cooling system included. So, it will be better then a garage but not as nice as a true inside room either. The overall size is approx. 24FT wide and 12FT deep.
Using the outer polls, the right most 25% is off limits for layout usage. Along the brick wall must be a "hallway" that will be approx 4FT in width. The middle 50% will have a height limit of 48IN. The left most 25%, the layout can go floor to ceiling if I wish.
So, that leaves me with roughly 212" by 92" on train layout space and 66.7% can only be 48" in height. The "dream" is to have a "loop" layout that would allow at least 1 train to run the mainline unattended and maximize the length of that mainline by "layering" the layout. My D&H roster is by design DC purchased with some DCC ready and includes a 4-6-6-4 Challenger with long passenger cars as the largest pieces that will need to transverse the loop. Though this consistent might make 18" curves, I have chosen to go with no less then 22" curves in the design and go wall-to-wall within my 212" by 92" space.
So, let me walk you through Plan#2 and be ready for a mainline that will snake and wind it way back and forth and up and down within these fixed limits...
Tags: DC , Grades , ho , Layout Design
  • Member since
    July 2006
  • 9,236 posts
Posted by galaxy on Thursday, September 22, 2011 8:52 PM
Well, at least you have a "future room" in which to do it...
I would strongly urge you to insulate the walls and ceiling thoroughly, sheetrock every wall and ceiling,  and rethink the idea of no HVAC.
SOmeone on here once said "I can't understand WHY people would spend what can amount to Thousands of Dollars on a layout and NOT do the room up into a finished space!"
They DO make wall space heaters that run on Nat gas or propane and windows designed with installing at least a window A/C is also a good idea!
I would hate to see you build a layout and have it buckle/warp due to heat and be of little use during tje long cold winters...when you will pine away {perhaps} for your layout. I tend to build/weather/detail my structures durning the long winter months. {Of course, now I am taking down my layout in the spare room}
Keeping the heat set at just the minum 50* most thermostats will register will keep things basically temperate. You can always jack it up when in there. Window A/cs DO come with thermostats in them you could set at 75*...but I would look online for those and read the dimensions so you know what size window to get!
Just some thoughts!!!!
Geeked
-G .
Just my thoughts, ideas, opinions and experiences. Others may vary.
 HO and N Scale.
After long and careful thought, they have convinced me. I have come to the conclusion that they are right. The aliens did it.
  • Member since
    July 2006
  • 9,592 posts
Posted by BroadwayLion on Thursday, September 22, 2011 9:11 PM
Mom and dad have a porch like that. Low walls, 100% screened. No windows. Not even in winter. Who is going to sit out on the porch in the winter anyway?
As for trains, my train room is 24' x 27' in what used to be a classroom on the third floor. It has plenty of windows, and nice steam heat in the winter. But I cannot work up there in the summer due to the heat.
So 10 months out of the year it is great, the other two months I can build some stuff in my basement (computer) office. At least that is air conditioned year round.
Bottom Line: Take care of your environment. Get some heat, and or air conditioning. The trains will run better for it too.
The Route of the Broadway Lion The Largest Subway Layout in North Dakota.
Here there be cats.                                LIONS with CAMERAS
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, September 23, 2011 8:34 PM
Thanks for the HVAC feedback!
The room design is due to City Code, Taxes, and Budget.  A Porch and a Enclosed Porch are mostly treated the same and neither require anything beyond a simple slab foundation.  Moving up to a "3 Season" room the foundation now moves up to an 18"-24" concrete foundation along the outer edge to support "real" walls, windows, doors like a real room addition but can not be connected to the central HVAC and taxes increase.  A room addition requires even more structural requirements and can be part of the central HVAC and taxes go up even more.  So, we looked at budget not only for the construction but the long term tax implications.  A "3 Season" can have a window cooler as well as a self contain heat source so I'm not majorly concerned about the room getting to cold or hot but not as controlled as the house.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, September 23, 2011 8:36 PM
212" by 92"
Based on these limits, I have chosen to use 2 "Stacked" Helix's and have the layout go as low as 24" off the floor so access will be "tight" to say the least. As you can see, side access is extremely limited so I also have reserved a access opening from below to get to a few areas as well.
So, roughly below is the shaded area of what I will build layer on layer onto. The top of this image represents the "Outside"/"North" wall. The bottom is the "Brick"/"South" wall which the last 4FT is off-limits. To the "Left"/"West" is the 25% area that is off-limits. The "Right/East" most 25% can be floor-to-ceiling while the remainder will have a 48" maximum height.
I dread the NE corner for derailments as it won't be easy to access...  Crying
Time to start stacking layer-on-layer with Level#1...
Tags: Layout Design , ho , DC , Grades
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Saturday, September 24, 2011 3:11 PM
Level#1 - Hidden Staging / Reverse Loop
OK, here is the Level#1 track plan where the vast majority will be hidden from view. Five tunnel portals are planned all in the middle area. The "left" side will have a access door(s) to get to the track as it turns around the western Helix or maybe a shelf style opening but remember, we are just 2FT from the floor at this point and it would only be visible from the side.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Sunday, September 25, 2011 7:57 PM
A 3D view of this layer without topography over it would look like...
The Helix in this view is to move the train vertically between Level#1 and Level#3 where Level #2 is reached via the grade along the back wall. The Hidden Staging is somewhat accessible via the long opening below the layout.
Start visioning a train heading out of the staging yard in a clockwise direction. To move to Level#2 or Level#3 it will go into the reverse loop and either switch to the Helix to head to Level#3 or to the back grade to Level#2. This means the maximum train consistent is limited to the reverse loop size otherwise the engine will run into it's own train.
Tags: Layout Design , ho , Grades
  • Member since
    February 2005
  • 12,914 posts
Posted by tomikawaTT on Monday, September 26, 2011 3:18 PM
Since your layout space will not be held to rigid temperature/humidity standards, you might consider building your benchwork with steel stud material.  It simply ignores humidity, and won't change into unlikely shapes the way forest products sometimes do.
As for the two humonguhelices, you might consider `herniating' them here and there, sceniced to resemble that Andes Mountain `Road of Death.'  That way you can keep tabs on the climbing or descending train.
There actually is a prototype for such a helix - Tzu-Li-Shan, on the Alishan Forestry Railway (Taiwan.)  Three turns around a mountain spur, plus a (sort of) figure eight at the top, all on an un-compensated 4% grade.  It's an adventure!
  • Member since
    July 2006
  • From: 4610 Metre's North of the Fortyninth on the left coast of Canada
  • 9,245 posts
Posted by BATMAN on Monday, September 26, 2011 3:59 PM
I agree wholeheartedly with chuck as far as using steel studs, it's the way to go. On top of that I would also use foam for a table top. As far as your helix is concerned I would use plastic strip molding 1" x 1/8" x 8' long and build it spline style. With where the layout is going to be located I would use as little wood as possible.
Just my My 2 Cents
        BrentCowboy
Brent
"All of the world's problems are the result of the difference between how we think and how the world works."
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Monday, September 26, 2011 8:35 PM
Great Point!!!!!!!  Thumbs Up  Thumbs Up  Thumbs Up  Thumbs Up
Something too I think the design will require is that it be on wheels to move away from the corner
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Monday, September 26, 2011 8:41 PM
A 3D view of this layer with topography over it would look like...
With this view I have shown the Western/Left side open as a optional shelf layout look but again remember it will only be viewable from the side. As you can also see, there is a small "Walk-In" within the middle of the layout.
That's the Level#1 plan...
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Tuesday, September 27, 2011 8:33 AM
Level#2 - Tunnel District
With Level#1 starting from a height of 24", Level#2 will sit vertially above it starting from a height of 31.5" and slightly offset in the center showing the visible section of Level#1 below it. Again, you can see the same two circle access holes for the Helix's and the dark yellow is shown where the access hole is on Level#1 to the hidden staging yard. The Western/Left side is vertially stacked so the only way to see the optional shelf on Level#1 is truly from the side. There will also be a shelf scene on this level on the Western/Left side that will have an old D&RGW steam era feel to it that will also be only visible from the side as Level #3 will stack on top of this yet too...
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Tuesday, September 27, 2011 9:00 PM
Here is what the Level#2 track plan is. Once again invisson the train that exited the stageing yard clokcwise, used the reverse loop to turn around to the counter-clockwise direction and started up the 2% grade along the Back/North wall behind the left Helix.
The train then exits onto Level#2 via the first tunnel portal and crosses over a river on the left side onto the bottom section of shelf layout scene. The train travels along the edge of the layout along the river and exits the shelf layout back into a tunnel.
The train exists onto the main layout scene via a tunel portal heading NE towards the middle area and then turns E onto the "High Line" with the exsposed Level#1 trackage area below it. It then crosses under a steal "High Bridge" as it turns NE again before entering another tunnel portal.
The train continues to climb up an approx. 2% grade around the right Helix access hole until it exists a tunnel portal the will be the box end of a canyon. The train will then turns North and enter into yet another tunnel.
The train now travels through the tunnel under a cascading waterfall, it continues out of sight as it makes a turn the west crossing vertially over the staging yard below also behind the access hole. The train once again make an appearance on the upper section of shelf layout scene on the western end; this time passing a Depot and Water Tower with the river below it. The train once again exists the shelf layout area of Level#2 via another tunnle portal.
The train now makes it's dramatic enterence back onto the main area of Level#2 making a quick turn North and once again vanishes into a tunnel portal as it cross over the hidden access hole.
Near the Back/Middle area, the train once again appears onto the layout and turns SE onto the steal "High Bridge" that will take it over the track it has now "Looped" over as well as cross over the cascading water fall. The track cross over a tunnel portal below and turns eastward into the box canyon until it once again enters into the last tunnel portal.
At this point, the train now continues it's climb along the east wall, turning west along the north wall as it climbs it's way to Level#3. At this point, it's traveling above the hidden staging yard of Level#1 as well as above the track it used to get from Level#1 to Level#2.
So, Level#2 is in many ways one large helix twisting and turning over the entire space. The train will make six (6) visual appearences onto the layout going in and out of tunnels, crossing a river twice, over one long steal "High Bridge" as the mainline makes a "Loop" over itself and then over a cascading waterfall. All curves are planned to be 22" radii or will be flextrack set to ~22" radii or larger.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Wednesday, September 28, 2011 10:12 PM
Above is a 3D view of the tunnel district with the topography added over the trackage. Here you can see the tunnels more clearly as the are planned for Level#2.
By rotating the 3D view and adding in Level#1 you can see how the middle section of Level #1 and Level#2 combine into a larger Tunnel District scene. The cascade waterfall would reach Level#1 and pass under a section of the Level#1 trackage as well. The Western/Left side only shows the Level#2 shelf layout area as the topography covers the Level #1 optional shelf layout due to it being truly "under" the Level #2 shelf layout.
The Level#2 shelf layout area is planned to be a D&RGW Steam Era feel with a depot and Water Tower along the upper trackage with a roaring river below that the trackage also travels along it's edge. Oh the Railfan photo ops that can happen here...
I wonder if folks noticed some of the Colorado RR location terms that I used in descibing Level#2. See, this design is not D&H Proto but what might have happened if the D&H would have been created in the Colorado Rockies and various locations were all mushed together into a single area.
By also planning Level#2 this way, I hope to have mostly avoided the "tail chaser" look of squizing a HO layout into such a small space by having the train vanish from sight and reappearing at different locations / heights using topography to it's fullest.
That's the Level#2 plan...
  • Member since
    August 2009
  • 17 posts
Posted by brooklyn harbor rr fan on Thursday, September 29, 2011 9:06 AM
A SUGGESSTION FROM FLORIDA.
WHEN CONFRONTED WITH WALLING IN AND ADDING HVAC TO MY LANAI (PORCH), EVERYONE TOLD ME HOW EXPENSIVE THE ADDED TAXES WOULD BE.
WRONG!  CONTACTED LOCAL TAX ASSESOR WHO WALKED ME THROUGH THE PROCEDURE FOR ESTIMATING TAXES AFTER COMPLETION OF ENCLOSURE.
YES, MY TAXES WENT UP BUT THE TAX COST WAS MINIMAL AND THE BENEFITS MAXIMUM.
SUGGEST YOU DO THE ANALYSIS FIRST, AND SEE IF YOUR BUDGET CAN ACCEPT IT.
ALBERT OLSEN
PS ENJOYED YOUR VIRTUAL MUSEUM OF THE D AND H.
MY WIFE IS THE GREAT- GREAT-GREAT GRANDAUGHTER OF L.F. LOREE AND AM ALWAYS INTERESTED IN READING ABOUT THE RAILROAD MOST ASSOCIATED WITH HIM.  GOOD JOB!!!!!
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Thursday, September 29, 2011 10:24 AM
Thanks Albert!  The D&H Virtual Museum is something I enjoyed doing and hope to add several hundred more photographs to it when I get time to work on it again.  It's always neat to hear from folks that enjoy using it!
As for my future HO Model Room, it's not just taxes; for a true Room Addition there are Foundation / Wall / Roof / etc. requirements to meet our City/State Code that adds allot of expense so we decided to go with a "3 Season".  This means the room can't be part of the central HVAC but can have it's own room Heat/Cool source.  Right now we have only done the "3 Season" room foundation requirement based on budget but I hope the walls will go up in a few years.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, September 30, 2011 8:46 AM
Level#3 - North Yard
The design once again stacks another layer over the two just described...
To quickly recap, our "train" pulled out of the hidden storage yard (Base @ 24") clockwise on Level#1, entered the reverse loop, and then used the back wall trackage at a 2% grade to climb to Level#2 (Base 31.5") in a counter-clockwise direction. From there, the train snaked it's way through several tunnels and trestles as it climbed through (not around) the Rocky Mountains. At the end of our travel up the Tunnel District, we were once again out of sight along the back wall using trackage climbing to Level#3 (Base @ 43") moving in a counter-clockwise direction; right over the top of the track we entered Level#2 as if on a giant helix.
On this image, you are seeing Level#1 in Gray, Level#2 in Yellow, and now Level#3 in Blue that basically shows the limits of where most the track will be placed for this level.
Tags: Layout Design , Helix , ho , DC , Grades
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Saturday, October 1, 2011 7:43 PM
Here is planned trackage for Level#3. Our "train" just reached this level in the NW corner (upper left) and will make a right (south) turn to exit onto Level#3 via a double tunnel portal. You will quickly notice that Level#3 is basically two reverse loops that join together via a narrow straight away along the back wall.
A Roundhouse is placed on a "hatch" that sits over the top of the Helix on the left side that the train has still not used yet. To fit the 48" limit, the trackage is basically level now at 43" above base leaving 5" of height for builds; not much! So, structures at this level will have to be low profile and more of a "yard" theme.
As the "train" enters onto Level#3 via the double portal West/Left of the Roundhouse, it makes a slow wide swing to the front of the layout and then turns do North and crosses over the Level#1 access hole way down below. Obviously this is closed on Level#3 but to show it's location I drew it to keep access areas visiable. Now the train swings east over a narrow straight away towards another reverse loop. Here the train can go either way but for layout design lets go straight and enter into another tunnel portal just above the right helix access hole. The train remains out of sight as it pass though the NE corner of the layout as well as along the eastern wall until it exists that tunnel in the SE coner. The train now can exit the reverse loop and head for the Roundhouser track, the track that will take us onto the right Helix and/or use the other reverse loop and come back over the narrow straight away again...
Let's loop back around again but this time turn to the right rather the go straight. By doing so, we can now head towrds the switch that takes us to Level#4. See, on the right side of the layout, I don't have the 48" limit so we will climb once more; but, let's not get ahead of ourself. Instead, let's go now to the topography of Level#3 and see how it's tied into Level#2 and Level #1 below it...
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Sunday, October 2, 2011 7:59 PM
Level #3 - North Yard
With the 3D topography added, once again the shelf layout area(s) of Level#1 and Level #2 are not seen as Level #3 is sitting above them so the topography masks their locations. The Roundhouse (shown in Purple) sits atop a plateau that doubles as a hatchway to the western/left helix from above. The shallow hill behind the Roundhouse conceals the trackage as it heads downward to the lower levels. Height in this are is restricted to 48" and thus the trackage is at 43" to leave 5" for structures. As the "train" leaves the left side over the narrow straight away along the back wall, you can see the Tunnel District of Level#2 as well as the exsposed trackage from Level#1 deep below in the canyons. On the right side, the trackage moves outward onto a High Curved Wooden trestle where the cascade waterfall falls from this level from a river that passes behind the mointain on the right side. The High Curved Wooden Trestle rejoins the mountain side on a ledge that forms a box canyon that Level#2 travels in/out of tunnels below. The trackage then splits before entering two tunnels in the SE corner just above the trackage from Level#2. The High Curved Wooden trestle even crosses over the steal "High Bridge" as well as over trackage from Level#1 so it's a long ways down! Hidden within the mountain side on the right side is the helix to Level#4 that is accessed via the inner trackage off the switch whereas the outer trackage will take the train through the mountain and back out towards the plateau.
That's Level#3 for the most part other then talking about the two Helix's that are accessible on Level#3.
Lets head up the eastern Helix to Level#4...
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Tuesday, October 4, 2011 8:37 AM
Level #4 - Mining District
Historically the D&H was all about transpotation of "coal" and historic railroads in the Rocky Mountains were about "ore" so I had to at least work in a Minig District. Level #4 sits at a 61" basline, well above Level #3. I did this to truly break up the view so the topography of Level#4 does not touch the topography of Level#3. There is little space up here but I wanted to still maintain the 22" Radii so that any Engine/Car that travels on Level#1 thru Level#3 could also use Level#4. This means, we are still talking about a mainline route still going all the way from Level#1 to Level #4.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Wednesday, October 5, 2011 8:57 AM
Here is the trackage for Level#4 at the 61" basline allowed on the right side of the layout.
Our "train" enters onto Level #4 from the right helix from Level#3 exiting the helix in a northen direction making a turn towards the west into a switch. Our train can now choose to runs circles around Level#4 on the outer loop track going in/out of one of two tunnels that are up here. We can also take the spur and use the inner track that will be the industral access to the Mining Area and then rejoin the mainline and circle around Level#4 on the outer loop track. The "S" curve that cross over/above the helix access also acts as a reverse loop. There is 18" of straight away in the middle of the "S" curve that should keep the longer engines/cars happy! The "S" curve and/or industrial siding is our path to return to the helix to travel back to Level #3 based on direction the train travels around Level#4.
  • Member since
    April 2010
  • 163 posts
Posted by NorthCoast RR on Wednesday, October 5, 2011 12:24 PM
This plan looks intense. Keep us posted to you progress. It seems like this will be an engineering feet to bring  to reality!
I look forward to seeing your progress.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Tuesday, October 11, 2011 10:45 AM
This 3D view of topography for Level #4 does not show the topography for the other levels as it truly is design to be offset as a seperate section and thus the topographies are not joined. The Purple structure in the image is there to designate a Mining Complex to load cars with Coal/Ore from a mine up on the mountain side above that will reach basically to the ceailing of the room.
Once our "train" leaves Level #4 via the same right helix it travel on to get their, it returns to Level #3
Our "train" now exits a tunnel portal on the inner track in the SE corner, crosses over a switch, then once again travels over the High Curved Wooded Trestle, over the narrow straight away, and over to the plateau.
To continue our downward journey, our train will turn southernly at the switch and then must make a choice of using the outer trackage or the inner trackage as they are two different paths downward. The outer trackage can be used to now take the long slide through the Tunnel District of Level #2 we just travel through "OR", switch onto the inner trackage we have yet to travel over. By using the inner trackage, we will enter into the tunnel just to the right of the Roundhouse and onto the left helix that will spiral the train down to Level#1, bypassing the Tunnel District.
Since the Tunnel District is a "One Train" route and I wanted the option to run more then one train at a time, I needed a way to sneak trains between Level#3 and Level #1. So, while one train can be moving from Level#2 to either Level #3 (upward) or Level #1 (downward), another train can move between Level #3 and Level #1, bypassing Level#2 completely, via the right helix. There is no helix access from/to Level#2, trains on Level#2 just travel around the left and right helix areas. I can also keep a train running on Level#4 while another uses Level#3 (technically another yet running around Level#1) circling those levels indefinitly. Once a train enters onto Level#2 though, dispatch needs to clear Level#1 or Level#3 (based on direction of travel) of traffic; otherwise, be ready for trouble when the train on Level#2 exists onto another level!
As trains travel downward from either Level #2 or the Level#3 helix they once again reach Level #1
A train using the Level #3 Helix will enter a grade on the inside of the hidden storage yard or via the Level #2 grade on the outside of the hidden storage yard. Both routes join at a switch along the eastern wall and exit back onto the layout via a tunnel portal. The train can now use the reverse loop to start the upward travel again OR switch towards the hidden staging yard to let another train start the journey.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Wednesday, October 12, 2011 11:04 AM
Overview
To give a 3D view perspective of Level#4 with the lower levels, you can see how much lower the other levels are from Level#4. There will be about a 4" baseboard around Level #4 to give visual seperation from Level #3.
The above image shows all four levels trackage stacked on each other without the topography to truly exspose the complexity as well as why there is only space for the three interier access holes; making the NE corner hard to reach from any angle.
This last image is to help visualize the trackage from all four levels from a 3D perspective...
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Thursday, October 13, 2011 10:38 AM
Something that someone caught when I ran this topic on another forum was I said this plan was to run DC continuously (hands-free operation) and Reverse Loops; Bang Head  What was I thinking!!!!!!!
Anyway, this next section of posts coming are the alterations I made to the design to make it DC friendly.
It's also been pointed out the Helix radii might be to tight for the planned cars so I'm not sure what I can do about that given the space restrictions.  If folks have ideas while I re-post the rest of this crazy design idea please speak up...
  • Member since
    October 2007
  • 43 posts
Posted by Champlain Division on Thursday, October 13, 2011 8:54 PM
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, October 14, 2011 9:45 AM
Level #1 (Alternative)
OK, I have reworked Level#1 to remove the required Reverse Loop for continual operation. Our "train" will still leave the Hidden Staging Yard as before (Clockwise) and join onto the Main Line and then make the big turn back towards the grade to head towards the Tunnel District on Level #2. The difference is the Main Line is no long a Reverse Loop and thus any train the enters into Level#1 from the Helix from Level#3 will can continure it's journey through Level#1 on just the Main Line without the need for a reverse loop. The Hidden Staging Yard has also changed, thier is now a Wye in the SW corner as well as a optional Reverse Loop. Through both of these Stage Yard options, I can turn around a train to go either direction on the Main Line; but, the Wye might have a tighter radii on the northerly path then 22" so I might have a restriction on what Engines/Cars can take that route. If I can adjust that curve to be ~22" radii, then I believe my entire roster can use the WYE.
Level#2 does not require changes based on Level#1 as the apporach to Level#2 via the grade on the North side has gone unchanged in location or grade. So, onto Level#3 for it's alternative design to remove it's Reverse Loop requirements.
Before
After
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, October 14, 2011 10:06 PM
Also, you can see that the layout has not changed much from the visitors view with the Level#1 Alternative alterations. Might have to rethink how I might use the WEST side shelf area now that trains will little use it; but, can still be a nice Era diorama that I can choose to pull trains through while staging operations are in effect. Maybe a modern Station design such as Denver Union Station that I can add a siding track into where passenger cars can sit without being in the way for switch/staging operations. Hmm, not a bad idea that just hit me for that spot!
Before
After
  • Member since
    December 2001
  • 4,387 posts
Posted by cuyama on Saturday, October 15, 2011 12:26 AM
I always hesitate to comment on poster's plans, because, let's face it, most don't really seem to want constructive critique.
But I would suggest in this case that it's possible that you are being misled by the CAD program showing you points of view that wouldn't be achieved.
From normal viewing angles, it seems to me that you're just not going to see very much of this at one time (if it could be built). And what you see may not appear logically connected.
That, plus the difficulty of reaching some pretty extensive and complex trackage, makes me suggest that you consider something a lot simpler in that scale and space. Just my humble opinion.
Good luck.
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Sunday, October 16, 2011 4:10 PM
No issues here as I am looking for constructive critique and yes I agree CAD can lead you down a dark path.  I don't know is this design will ever get built but at least using CAD in this way lets me play allot of "What-If" ideas without doing any real construction.  It will likely still be a few years before the walls get added to the room so lots of time to try different ideas via CAD.  Like I started this crazy topic, BIG DREAM, little space...
One idea I have to help with the access issues is to put this on wheels so I could get to the North and East sides fee of scenery by rolling this away from the walls.  I'm truly looking to build a long main line using the entire space as a gigantic helix which is why the four level idea right now...
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
