Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Which DCC Starter System do you like “best”?
  • Member since
    February 2002
  • 517 posts
Posted by jwmurrayjr on Friday, June 10, 2011 7:27 PM
My HO layout has been packed in crates for over3 years and finally I have a room to unpack it into.  I started the layout in 2001 and was using the Atlas system with a Commander and 2 Hand Control tethered throttles.  The layout has 3 plugs for walk-around control using the throttles.  I usually “operate” alone but would like to let guests run trains too.
I think that I would like to upgrade to a system that accommodates 4-digit addressing (Why anyone ever thought 2-digit addressing was a good idea beats me.)  Also the newer systems have many for functions and features.  Not that I’m really up-to-date on any of the new systems, but they were much more advanced than Atlas when I put my MRR into storage 4 years ago.
My layout is not large and I would probably never run more than 3 locos at a time (Small steam mostly).  That’s why I’m asking about “starter” systems but maybe a starter system is not what I will need.  I’m thinking of NCE but would like to know what folks that have used various systems like about them (I like the NCE throttle layout and “user interface”.)  I don’t want anything that is complicated to use.  That’s why I started with DCC instead of cab control in 2001.
I’m pretty sure that I’ll stick with the Atlas system until I get the layout reassembled and up and running so there’s no urgent need in my mind at this time.
If you would take some time and tell me which system you would recommend and why, I will really appreciate it.
As usual, thanks for your help,
  • Member since
    July 2003
  • 5,743 posts
Posted by simon1966 on Friday, June 10, 2011 7:49 PM
If I remember correctly, Lenz developed the Commander system for Atlas.   Now the Commander is going to have very limited value on the re-sale market so you might want to investigate if the Commander throttles are compatible with a current generation Lenz system.   It could be a very nice way for you to get some extra throttles, essentially for free!   I think this would be an avenue worth investigating.
As far as other starter systems are concerned then in addition  to Lenz, NCE, Digitrax and MRC are the most commonly used here in the USA.   All have strengths and weaknesses.  Given that you have the intention of waiting some period of time before making  choice, I would simply use the intervening time to think about the features that are important to you.  For example, you mention guest operators, how many do you think you would have at one time.  If it takes you a year to get back up and running, who know what new stuff will be on the market then.
In answer to your very specific question, well I like the Digitraz Zephyr Xtra best.  It is the only starter set capable of doing all the things that I want and need a system to do.   2nd choice would be the NCE PowerCab, but I would have to add all the extra cost options to it, to get what I need and frankly if I was to go NCE would go direct to the Powerhouse Pro.  I am not a big fan of MRC as the company has a very spotty history in DCC and I do not like the fact that their PC interface does not support the JMRI software, which I use almost daily.
Simon Modelling CB&Q and Wabash See my slowly evolving layout on my picturetrail site http://www.picturetrail.com/simontrains and our videos at http://www.youtube.com/user/MrCrispybake?feature=mhum
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Friday, June 10, 2011 11:42 PM
 2 digit addressing originally allowed 99 locos. AT the time, most available command control systems had limits like 16 or 18 locos, 99 was a big jump. Plus that's what the base Lenz protocol allowed. Actually it was 127, but Lenz was lazy and didn;t want to put more than a 2 digit LED readout on their throttle. That's why to this day, a short or 2 digit address on Lenz is 0-99. This hole in the protocol leads to the only incompatibility in DCC. A loco on a Lenz system that has the address of 105 is a long address. but it won;t run on Digitrax. It will work on NCE> A loco with the address 105 on DIgitrax is a short address, and will work on NCE, but not Lenz. NCE can also use 005 as a long address which is NOT the same as 5, short address. 005 long address on NCE will not work on Lenz or Digitrax. Basically, Lenz and Digitrax take as absolute the definition of short address vs long address, adn never the two shall overlap. Except that Lenz contiues to use legacy 99  at the highest short address.
                           --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    January 2007
  • 3,290 posts
Posted by gandydancer19 on Saturday, June 11, 2011 8:56 AM
This topic has been covered many times before with some very good information given.  Use the forum search function on the right hand side to find them.  You will be glad you did.
Elmer.
The above is my opinion, from an active and experienced Model Railroader in N scale and HO since 1961.
(Modeling Freelance, Eastern US, HO scale, in 1962, with NCE DCC for locomotive control and a stand alone LocoNet for block detection and signals.) http://waynes-trains.com/ at home, and N scale at the Club.
  • Member since
    February 2008
  • 8,878 posts
Posted by maxman on Saturday, June 11, 2011 9:39 AM
jwmurrayjr
I think that I would like to upgrade to a system that accommodates 4-digit addressing...
My layout is not large and I would probably never run more than 3 locos at a time...
That’s why I’m asking about “starter” systems...
I think you should look at the 5-DCC system made by SLF Control Industries.  MR reviewed this system in 2006.  They say it is the "closest thing to a universal train control system we've seen.  Simply purchase the starter kit, which includes a full-color instruction manual, and you're ready to begin running trains the 5-DCC way - without need of expensive decoders, a lot of wire, or costly power supplies."
Among other attributes,  the system features include one to five-digit addressing and an optional sound system "that reproduces virtually any locomotive sound you can think of."  There is an easy consisting feature.  No special installation is required.
"The system's hand throttles are compatible with all other control systems, including DC, DCC, AC, and battery operated garden railroads."
While I haven't looked for it yet, the review concluded by saying that you could see a hands-on demonstration at www.modelrailroader.com
  • Member since
    February 2006
  • 341 posts
Posted by mokenarr on Saturday, June 11, 2011 9:55 AM
I have a MRC Wireless system , like you I just wanted a simple easy to use DCC.   I have 2 cabs and 6 HO locomotives.  I use the engine number to assign a number to the decoder and the MRC will do 4 numbers quite easily.   all i want to do is run the trains and this does it fine.  Also no matter what system you get , consider wireless.  I have a n scale layout that is DC and no wireless and the difference in running them is amazing.
Old Steam loco's never die, they just lose thier fire.
  • Member since
    February 2002
  • 517 posts
Posted by jwmurrayjr on Saturday, June 11, 2011 10:26 AM
maxman
Well...Wink
http://forum.atlasrr.com/forum/topic.asp?ARCHIVE=true&TOPIC_ID=26526&whichpage=2
Yes, The video and article in Model Railroader magazine are MR's annual
April fools day jokes. Last year IIRC it was a new modular system called
"NoTrack", in light of all the rails-to-trails projects. This year it's
5-DCC (5 Digit Command Control) I sent MR an email and ask if this was an
upgrade to the 0-5-0 system :)
April fool...a bit late. Thanks anyway.
  • Member since
    February 2002
  • 517 posts
Posted by jwmurrayjr on Saturday, June 11, 2011 10:29 AM
gandydancer19
Duh.Embarrassed
Good advice. Thanks.
And thanks to you guys that have posted your advice/opinions.  I appreciate it.
  • Member since
    February 2002
  • 517 posts
Posted by jwmurrayjr on Saturday, June 11, 2011 10:37 AM
rrinker
                           --Randy
Randy,
That's interesting.  Thanks!
I believe that NCE will use my existing bus and panel connectors.  That would be good...I think.
  • Member since
    February 2002
  • 517 posts
Posted by jwmurrayjr on Sunday, June 12, 2011 12:41 PM
I've noticed that Easy DCC has some compatibility with Lenz. From the CVP site.
I'm not sure what this really means. I assume that if using Atlas, adding Easy DCC components like wireless throttles would NOT add any functionality that was not already in the Atlas Commander station.
Any comments on this will be appreciated.
Thanks,
  • Member since
    March 2008
  • 448 posts
Posted by steamfreightboy on Sunday, June 12, 2011 5:00 PM
I have an NCE power cab and love it. I think it is an excelent value and is very flexible.
sfb
"It's your layout, only you have to like it." Lin's Junction
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
