Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Painting brick structures
  • Member since
    November 2006
  • 17 posts
Posted by ronanders on Friday, June 10, 2011 10:58 AM
What is a good color in a paint spray can to use for brick in it's various colors?
  • Member since
    March 2007
  • 1,719 posts
Posted by Train Modeler on Friday, June 10, 2011 12:31 PM
dark red is the most obvious.   But coming back with a mortar colored wash and then wiping off helps make it look real.   LOTS of ways to model brick and mortar.   The key is to model both, not just the brick
Richard
  • Member since
    January 2007
  • 3,290 posts
Posted by gandydancer19 on Friday, June 10, 2011 12:53 PM
I agree.
Most of my brick buildings are each painted a different shade of red or tan.  Once the white or gray wash is applied for the mortar, the shade of the red on the building changes.
Even if you painted two building the same red, and then used a white mortar wash on one, and the other used a gray mortar wash, they would look slightly different.  And that is what you want to wind up with.
Elmer.
The above is my opinion, from an active and experienced Model Railroader in N scale and HO since 1961.
(Modeling Freelance, Eastern US, HO scale, in 1962, with NCE DCC for locomotive control and a stand alone LocoNet for block detection and signals.) http://waynes-trains.com/ at home, and N scale at the Club.
  • Member since
    December 2001
  • 3,139 posts
Posted by chutton01 on Friday, June 10, 2011 1:16 PM
gandydancer19
Note of caution:
Benita Jameson
One word of caution when using any of these methods for mortar lines – avoid using white or any very light color. This can give an unwanted pink look to your building.
Detailing and Weathering Structures - Take your structure from STANDARD to STELLAR
This has actually happened to me, when I used a bright white morter wash over my usual Rattle Spray Can Dark-Red Primer brick coat - the results looked off (pinkish). I believe in addition to the NRMA discussion linked above, there was an article in MR last year discussing this too, and the suggestion was to use a grey-white or off-white color.  I believe the pink color will be most noticible in images, and not sure how much weathering the walls (with a dark wash) will counteract the effect.
Also, remember light brick color (tan or beige) = dark grey/weathered black morter colors.
  • Member since
    August 2006
  • 3,130 posts
Posted by dstarr on Friday, June 10, 2011 1:51 PM
ronanders
Red auto primer from Krylon or Rustoleum.  It's a good red brick color, and it dries dead flat.
  • Member since
    November 2003
  • 594 posts
Posted by robert sylvester on Friday, June 10, 2011 4:12 PM
ronanders:
I have been painting buildings for a long time and the list of paints is long. I really like either spray paints from Wal Mart or Lowes; colors of brick, rust, burnt colors. I also use Acrylics from Wal Mart or Hobby Lobby, again in bottles that are the squeezable ones, Like "Apple Barrel", the color is up to you.
I first clean the plastic walls with soap and water. I paint before I put the kits together, including the windows, put is the sheet plastic for windows and even pain shades or curtains. After the paint has really dried I take sheet rock mudd, a small amount on a cloth towel and wipe it over the wall. Then with a damp towel I wipe of the excess leaving the mortar cracks with the mudd. There are other ways to do the concrete but I like the way I just described. I have tried to present some pix.
Thanks,
Robert Sylvester
WTRR
http://i100.photobucket.com/albums/m6/robertsylvester/100_0948.jpg
[http://s100.photobucket.com/albums/m6/robertsylvester/?action=view&current=100_0910.jpg
  • Member since
    April 2003
  • 4,261 posts
Posted by Medina1128 on Saturday, June 11, 2011 11:43 AM
Another tip is to paint the inside of the building. I paint with grey primer, then a lighter finish coat. This color is the desired interior color. This prevents your building from having that "glow" when you install interior lighting.
  • Member since
    July 2006
  • 4,565 posts
Posted by cowman on Saturday, June 11, 2011 12:23 PM
Welcome to the forums.
As mentioned there are many colors of brick and many ways to model them.  Rattle can spray primers work well and different makes are slightly different colors.   By using the different brands and different methods of shading, you have a nearly limitless variety of colors, just like the real thing.
Good luck,
Richard
  • Member since
    January 2004
  • 13,375 posts
Posted by doctorwayne on Saturday, June 11, 2011 1:29 PM
ronanders
Well, unless you're simulating glazed brick, any flat paint in a colour that looks to you to be similar to the colour of your prototype.  As noted, mortar colour and weathering will have a pronounced effect on the final appearance.
Personally, I find Floquil Reefer Orange (not available in a spray can, but there are lots of similar oranges available) to be very representative of some brick in my area of southern Ontario.
Any of the red primers or boxcar colours also work well, and any of these can be varied by changing the mortar colour and/or that of the weathering:
  • Member since
    April 2003
  • 4,261 posts
Posted by Medina1128 on Saturday, June 11, 2011 7:56 PM
Wayne, your brick buildings look awesome!
  • Member since
    September 2003
  • 5,449 posts
Posted by mobilman44 on Sunday, June 12, 2011 6:53 AM
Hi!
It's always a pleasure and inspiring to see the good Doctor's work!
I've done a lot of brick and mortar painting over the years and using oil and acrylic paints, via mostly brush.  On some I did the mortar wash first and then dry brushed the brick surfaces, and on others painted the bricks and washed the mortar - wiping it off soon after.   IMHO, the model brick walls are all different, and some give better results with one method as opposed to the other.  Soooo, I would test a piece first.
On colors, a variant of red/brown mix is by far the most common color for face brick.  But for sides and other surfaces variants of grey/brown/white are more common - especially in the big cities and on larger structures (face brick cost more $$$).
Most every brick structure I have painted is with a custom mix, just to give the structure a different shade from its neighbor.
Lastly, as you should already know, painting the brick and mortar different colors is a sure way to make even the cheapest structure look really good!
ENJOY  !
Mobilman44
Living in southeast Texas, formerly modeling the "postwar" Santa Fe and Illinois Central
  • Member since
    January 2004
  • 13,375 posts
Posted by doctorwayne on Sunday, June 12, 2011 10:15 AM
Thanks for the kind words, guys. Big Smile
As mobilman44 notes, painting any brick wall will improve the appearance, simply by removing the unrealistic sheen of the plastic.  Adding mortar detail helps to "pop" the detail that's cast into the walls, and weathering ties it all together.  A spray can (or airbrush) is a good way to apply the base coat, be it the brick colour or that of the mortar, but beyond that don't be afraid to use a brush or other techniques to complete the job.  Some of my brick structures have mortar applied as a wash (sometimes several washes), some got pre-mixed drywall mud, applied with a rag over my fingertip, and others were sprayed with the mortar colour, then the bricks were dry brushed.  The comment about face brick is right-on, too, and I'll utilise that detail when I get into building some commercial districts in the towns around the layout.
And, if your first efforts don't come out as well as you'd hoped, don't be afraid to re-do them.  I have at least one structure on the layout that will be re-done, as I'm not too pleased with my colour choices.
The colour is alright, I think, but not for this particular town.
  • Member since
    February 2010
  • 607 posts
Posted by Colorado_Mac on Sunday, June 12, 2011 11:55 AM
doctorwayne
...I find Floquil Reefer Orange...to be very representative of some brick in my area of southern Ontario...
Wayne makes a very good point.  Bricks are one of those things that are "region-specific".  They were (and I think still are) mostly made locally, so the color(s) depend heavily on the soil available in that area.  Do some searching for images and you will see what I mean.
The comment about auto primer is also spot-on; those dry so flat is is almost scary.
Sean
HO Scale CSX Modeler
  • Member since
    May 2009
  • 91 posts
Posted by cadman11 on Sunday, June 26, 2011 3:09 PM
Re-painting is always an option. On one occassion I was not happy with the airbrushed color I had mixed so sprayed the entire structure with Tamiya primer gray. Next had the idea of scraping off the primer wjth a chilsel blade and was totally surprised at the result. A very nicely weathered brick warehouse structure. Who would have known except by accident.
Thom
Tags: Weathering
Thom Owen
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
