Trains.com
Locomtive Tonnge Rating
  • Member since
    September 2013
  • 2,505 posts
Posted by caldreamer on Sunday, March 13, 2011 12:26 PM
If  a train ws  at or very near the tonnge rating of a locomotive (for exampe:  An SD40 is rated at 1015 tons for the territory and the train weighs 1010 tons) would the railroad assighn an additionl engine to ensure that it could pull the train over the route or would they take their chances?
  • Member since
    December 2001
  • 8,156 posts
Posted by henry6 on Sunday, March 13, 2011 1:11 PM
Yes.  Seriiously, yes.  Depends on power availability, needs, crew's acumen and skills, type of cars, type and age and  condiition of locomotives, weather conditions, return needs.  So they might or might not.
RIDEWITHMEHENRY is the name for our almost monthly day of riding trains and transit in either the NYCity or Philadelphia areas including all commuter lines, Amtrak, subways, light rail and trolleys, bus and ferries when warranted. No fees, just let us know you want to join the ride and pay your fares. Ask to be on our email list or find us on FB as RIDEWITHMEHENRY (all caps) to get descriptions of each outing.
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Sunday, March 13, 2011 1:38 PM
First off I would hate to see the territory where a SD40 is only rated for 1015 tons.
Secondly the locomotive utilization people believe they have done their job properly when they assign the locomotive rated for 1015 tons to the train that is 1014 tons.  The answer you get when you say that it is too close to the rating is....It's not over the rating so run the train.
Power utilization people don't care who is operating the throttle, sanders and brakes...all they care about is that the engine is rated to a number and that number is equal to or greater than the tonnage of the train.
Local field operations people may want more power on the train, but unless they actually have control of the power assignments (and most don't) the train will be operated with the power assigned and local field opeations will have to deal with the outcome - good or bad.  If the outcome is bad, local field operations will have to either find another train to shove, doublehead or give up power to get the stalled train moving.  If no other trains are available for assistance then the stalled train will have to double the train up the grade it stalled on.
Never too old to have a happy childhood!
  • Member since
    December 2001
  • 8,156 posts
Posted by henry6 on Sunday, March 13, 2011 2:13 PM
Balt, the question was hypothetical.  The locomotive could be a Lionel or EMD or whatever.  The tonnage rating was X and the train tonnage was X-15 or whatever.  No, power dispatchers and computers don't take crew and skill into account.  But railroaders do.
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Sunday, March 13, 2011 3:11 PM
In as much as this is the world I work in day in and day out....what you are getting from me is what REALLY happens....good, bad or ugly....them is the facts Jack!
  • Member since
    February 2005
  • 2,366 posts
Tonnage Rating
Posted by timz on Sunday, March 13, 2011 4:30 PM
No one should imagine that "tonnage ratings" are carefully worked out, and that if an SD40-2 is rated at 1015 tons from point A to point B then you can count on it making the grade with 1014 tons. The odds of it being successful may be 98%, but more likely they will be 90%, or 80%, and they might be 50% or less. On most railroads "tonnage ratings" are just for show, and dispatchers use their own experience to assign power.
  • Member since
    June 2001
  • 13,681 posts
Posted by CShaveRR on Sunday, March 13, 2011 5:56 PM
In The Railroad--What It Is, What It does, John Armstrong said that trains would be sent out at times slightly in excess of the tonnage ratings of their power, and they would just hope that they could make it (of course, I read this in the book's first edition--that was four editions ago, and may have bee adjusted since then).
In my job with the railroad, I didn't have to worry about powering the trains we classified for.  I recall that underpowering was often an issue back in CNW days, just because we never had enough.  Getting all of those widenose GEs toward the end of the line helped a lot.
UP used to have a standard horsepower-per-ton figure for each type of train.  They've since gone to tons-per-equivalent-powered-axle (so when's an axle not an axle?).  This is supposed to be more accurate than hp/t, and more efficient, though I saw evidence of complaints soon after that system was instituted.
I don't recall ever seeing tonnage ratings covering specific subdivisions for each locomotive model on UP--Heaven knows they have some grade variants around the system!  Wonder whether Jeff can offer some insight...
Carl
Railroader Emeritus (practiced railroading for 46 years--and in 2010 I finally got it right!)
CAACSCOCOM--I don't want to behave improperly, so I just won't behave at all. (SM)
  • Member since
    February 2005
  • 2,366 posts
UP Tonnage Rating
Posted by timz on Sunday, March 13, 2011 6:25 PM
CShaveRR
They don't call them that, but the Spec Instr do give (in effect) the tonnage ratings for each type on each hill.
  • Member since
    December 2001
  • 8,156 posts
Posted by henry6 on Sunday, March 13, 2011 6:45 PM
Usually freight railroads will publish tonnage ratings per locomotive or per unit lash ups for given segments of it route and by direction.  Some will give ratings for certain cargoes, cars, train make ups, weather  (temperature and precipitation) conditions.  But while these are written rules, there always is the rule of thumb and the rule of immediate predicament that may over rule that which is written.
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Sunday, March 13, 2011 7:43 PM
The following is a tonnage rating table for a inter-divisional train that proceeds over multiple crew districts and operating divisions...
 ARRE TIME MILE  SD40  SD50 C408 ES4D S70A C44A   C44AH
Point1 0120 0084   5800  6900  7500  8100  9550 10150  11000
Point2 1000 0203   5800  6900  7500  8100  9550 10150  11000
Point3 2000 0172   5400  6400  7000  7550  8900  9450  10250
Point4 0545 0125   5150  6100  6650  7200  8450  9000   9750
Point5 1655 0149   4350  5150  5650  6050  7150  7600   8250
Point6 0345 0182   2800  3300  3600  3900  4600  4900   5300
Point7 1345 0142   5000  5950  6500  7000  8250  8750   9500
As can be seen, different territories have different ratings.  If the intent is to run the train from origin to destination without changing either train consist or locomotives enroute then power has to be assigned in accordance with the requirements of the lowest rated 'Point6' territory.  A 6000 ton train can easily be handled with 2 SD40's over all territories except the Point6 territory; additional power must be added to handle the train for the entire route.  Adding or removing power from a existing train will generally result in approximately one hour delay; that presumes that additional power was actually available and waiting when the train arrives at the start of the Point6 territory.
In the days of CR, MILW & RI and their deferred maintenance of everything...it was common to use 6 engines on a train that required 3 in the hopes that at least 3 of the 6 would get the train to destination....Today's Class I carriers DO NOT operate in that manner; they expect a locomotive that is rated for 5000 tons on a territory to handle that 5000 tons as long as the locomotive is operating normally.  If enroute defects reduce the tonnage capability of the locomotive then suitable remedies will be formulated to get the train to destination; it is not unheard of for a train to be delayed 8 - 12 - 24 hours or more while efforts are made to get additional power to a train that has had engine failure on line of road.  Most trains operating need all the working engines in their consist to complete their run.
Locomotives, besides right of way investment, are the largest Capital Investment that the carriers make - they expect the utilization of this investment to run and return profits to the company.  Unnecessarily overpowering trains is wasting that capital investment and reduces that amount of $$$ that goes to the bottom line.
  • Member since
    November 2003
  • 2,289 posts
Posted by carnej1 on Monday, March 14, 2011 11:09 AM
CShaveRR
 Isn't  the "tons-per-equivalent-powered-axle " rating a way to differentiate between AC and DC motored power? I.E AC traction locomotives count as more than 6 axles in figuring the power rating?
"I Often Dream of Trains"-From the Album of the Same Name by Robyn Hitchcock
  • Member since
    February 2005
  • 2,366 posts
Posted by timz on Monday, March 14, 2011 12:18 PM
Yes, UP says an  ES44AC engines is worth 12.1 equivalent axles-- but they rate a DC SD70 at 10.4 axles. Don't bother trying to figure out why they use that terminology; in the end, each engine has tonnage ratings for each of UP's hills.
An ES44 on a coal train is alleged to be able to manage 6500 tons east from the Powder River mines; the climb from Lost Springs includes four miles of nearly continuous 1%, so no one would be astonished if they didn't make it. Anyone know what a typical train there actually has?
  • Member since
    October 2006
  • 9,810 posts
Posted by Paul_D_North_Jr on Monday, March 14, 2011 1:35 PM
Somewhere here on another thread within the past year or so Railway Man had an explanation and commentary on tonnage ratings and how power was assigned during his experience.  I won't attempt to recall and repeat it here - but it would be worth seaching for.
My understanding is that the Tonnage Ratings are based only on expected Tractive Effort from the locomotive class, at the assumed standard rail adhesion - is that correct ?  In contrast, the Tonnage Rating is not based on HorsePower, which is more for speed considerations (as in HP/ ton - see the other current thread for that).
Further, the Tonnage Rating is based on the lower "continuous" rating of the current through the motors (to prevent them from damage) if the grade is long enough or if the train is anticipated to be slow enough to be there long enough to invoke it; otherwise, a higher "short-term" motor rating might be used instead as the basis for the Tonnage Rating.
Also, the Tonnage Rating is based on the train being on the Ruling Grade at the time, which presumes that the Ruling Grade is long enough to fully engage the expected 'normal' train*, and that there aren't any shorter "momentum grades" involved.  (*That's one part of the definition of Ruling Grade.)
Anything else to add to this ?
- Paul North.
"This Fascinating Railroad Business" (title of 1943 book by Robert Selph Henry of the AAR)
  • Member since
    May 2004
  • 5,921 posts
Posted by MP173 on Tuesday, March 15, 2011 6:48 AM
Do locomotives lose efficiency over time?
In other words, at a certain time (new or after major overhaul) if a locomotive is rated at "x", will it lose that efficiency over a period of time?
Ed
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Tuesday, March 15, 2011 6:53 AM
While they may....it will NEVER be reflected in the published tonnage ratings.
MP173
Ed
  • Member since
    December 2001
  • 8,156 posts
Posted by henry6 on Tuesday, March 15, 2011 7:13 AM
MP173
Ed
Yes.  But as Balt points out it at least takes a while before the timetables catch up.
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Tuesday, March 15, 2011 12:42 PM
Engines go to the scrapers with the same tonnage rating that they had the day the left the builders shop.
henry6
 MP173:
Ed
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
Newsletter Sign-Up
By signing up you may also receive occasional reader surveys and special offers from Trains magazine.Please view our privacy policy
