Trains.com
steady power for 0-27 switches
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, November 29, 2006 8:03 PM
I modified my lionel switch per the artical in classic toy trains issue dated feb.2006. Page 61.
I am using a cw-80 xformer accessory output(14volts).When I ground the the u post to track ground
the track voltage jumps to 14 volts.The switch does not work.I have two other cw-80 xformers
one of them will make the switch work.How do I correct the grounding problem for the two
that are not wired for common grounds.
  • Member since
    January 2003
  • 1,758 posts
Posted by ben10ben on Wednesday, November 29, 2006 8:14 PM
As I recall, it was a big deal when the CW-80 first came out that it didn't have a conventional common ground as past Lionel transformers have been. I believe that you may be able to make it work by hooking the black post to the center rail, and the red post to the outer rail, but I mcould be wrong about this.
Ben TCA 09-63474
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Wednesday, November 29, 2006 9:10 PM
You're right, Ben.  Terminals A and B are connected together internally and should be connected to the outside rails.  Terminals U are not connected together, despite having the same label.  One of them should be connected to the center rail and the other to the new turnout common.  The functions of the bell and whistle will be swapped when the transformer is used this way.
There was a recent report on the forum that Lionel had fixed this problem in recent production.
With O27 turnouts powered from an accessory voltage, there is a danger of damaging the solenoids if a train stops on the control rail.  A cure for this is to use DC instead of AC, through a series resistor and then across a shunt capacitor.  The charged capacitor provides enough energy to operate the turnout; but the charging resistor can't supply enough current continuously to damage the coils.  I use 100 ohms and 5000 microfarads.
Bob Nelson
  • Member since
    December 2005
  • 3,233 posts
Posted by ADCX Rob on Wednesday, November 29, 2006 9:22 PM
The simple answer: the red posts on the CW-80 are common, not the black(black U under"B" is the accessory output, black U under "A" is the track power) ...wire your switches this way and you will get the desired effect.
The Whistle & Bell button functions will be switched.  This is addressed in several of the set manuals shipped with the CW under the "phasing" section of the instructions.
You have opened a Pandora's box here - the not-so-simple answers will follow!
Rob
Rob
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
